TopBud Samba Member
Joined: February 28, 2004 Posts: 1111 Location: Flagstaff AZ
Posted: Wed Feb 20, 2008 8:28 pm Post subject: Heated syncro seats |
My drivers seat is shreded and it has pinkish/orangish wires on it. After looking around I saw wires coming from the bottom. I then noticed on the steering column is a adjustable knob that has a diagram of a heated seat. it has a few settings (I think 1-5). So my syncro has heated seats that do not work. does anyone have a way or vendor that can fix them or give me hints.
I do not have the bentley yet or an owners manual. I am familiar with air cooled vw's but I could not pass up a deal on this syncro. I am still waiting on parts so I have not even driven it yet. That is why i never noticed the adjusting knob on the steering column.
I also think it is imported from Canada because it has canadian stickers on the drivers side door panel
Thanks in advance _________________ 86 bostig SYNCRO
66 convertible Karmann Ghia |
Dogpilot Samba Member
Posted: Wed Feb 20, 2008 10:32 pm Post subject: |
This company makes its for retrofit:
http://www.rostra.com/seat-heater.htm _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
ckissick Samba Member
Joined: August 22, 2006 Posts: 498 Location: Bay Area
Posted: Wed Feb 20, 2008 10:35 pm Post subject: |
I don't have an answer, but your heated seats seem to be very rare. I have them on my Tristar doka, but they don't work either. Simce I live on the CA coast I haven't bothered to fix them
Anyway, Lucas at GoWesty checked out my doka at last year's Syncro de Mayo and flipped when he saw the seat heater switch on the streering column. He'd never seen one before. That indicates to me that they are very rare. My doka came from northern Sweden so the seat heater must have come in handy.
It seems any good mechanic who is good with electronics should be able to fix it. _________________ Charlie
1950 Beetle
1983 Westfalia
1989 syncro Tristar
1966 Porsche 912
1989 Beck Spyder
2007 GTI Fahrenheit |
HeftySmurf Samba Member
Joined: June 15, 2008 Posts: 879 Location: Washington, USA
Posted: Mon May 04, 2009 6:46 pm Post subject: |
Old topic I know,
However, I picked a Syncro a little while ago and it came with a few boxes of misc parts. Digging through it today I found a wiring harness in like new condition. Where can I find 1 heater pad? I checked most sites out and it seems they come in complete sets mostly. I have the switch and the wiring just need the part that goes in the seat. What are these worth?, just curious _________________ -Lorenzo
90 GL w/ Bostig |
buildyourown Samba Member
Posted: Mon May 04, 2009 8:09 pm Post subject: |
I bought 2 new heating pads and switches off ebay for about $100.
I doubt that it would be worth your time to source original parts.
Not all heated seats are created equal. Drive a new VW or Volvo and compare it to some of the other seat heaters (ie, Mazda, Chevy)
I'm sure the newer ones work much better than anything made in the 80's.
If you've never owned a newer car with them, get some with at least 2 on positions. On/off isn't sufficient. Maybe I'm just a seat snob. |
Posted: Mon May 04, 2009 8:12 pm Post subject: |
I agree, I had heated cloth seats in my Jeep Commander that were great. All I need is the pad. I think it has 1-5 on the knob, looks cool goes on top of the steering column _________________ -Lorenzo
90 GL w/ Bostig |
tencentlife Samba Member
Posted: Mon May 04, 2009 8:23 pm Post subject: |
HeftySmurf wrote: |
Where can I find 1 heater pad? |
The link above, courtesy of the Dog-man. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
YOGIVW Samba Member
Joined: February 04, 2005 Posts: 263 Location: Olsztyn/POLAND
Posted: Tue May 05, 2009 12:14 am Post subject: |
All Swedish vanagons were equipped with heated driver’s seat. Usually if the system does not work the wires in the pads are broken. You can try to repair it but the wire will brake again in another place. The best what you can do is to find golf/jetta./ T4 at your local junk yard and cut off just the pads. Sometimes the relay is broken (number 59 ) which is located on the top of the fuse box, so check it first.
If you need the wirings with switch for your Vanagon see my adds. _________________ Pawel
Vw 1303 1979 Black&Beige convertible
VW T4 2001 Caravelle Business 2.8 V6
Westfalia James Cook 2.9TD |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1242 Location: Portland, Or
Posted: Tue May 05, 2009 7:59 pm Post subject: |
The seat back is also heated, not just the base pad. at least my Tristar is.
It's a bit toasty at level 5... _________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
Posted: Fri May 08, 2009 7:48 pm Post subject: |
Standard heated driver's seat switch:
Dual seat heater switch:
_________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
YOGIVW Samba Member
Posted: Mon Nov 26, 2012 12:56 am Post subject: |
luVWagn wrote: |
anybody know where to find those switches? i want to use one for a sub-woofer under the driver's seat |
if you need the switch for single seat checke the classifields _________________ Pawel
svenakela Samba Member
Posted: Mon Nov 26, 2012 5:17 am Post subject: |
Are those rare in the States? Every Vanagon I've owned has been equipped with a seat heater.
Usually there's nothing wrong with the heater cable. In a YM 88 this what you need to check. It's a copy from a discussion we had on a local forum. The components are the same in Golf, Passat and Jetta from the same era. You can pick the pieces you need from any model.
* There's a thermistor (NTC resistor) under the seat that can fail, specially if the controller relay is disconnected. Some circuits survives a fault, some not.
* There's a fuse in slot 16 (10 A) for the heater.
* The controller unit is in relay slot 18, that's the column most to the right. |
Mickyfin Samba Member
Joined: July 04, 2011 Posts: 96 Location: Kuopio, Finland
Posted: Mon Nov 26, 2012 9:07 am Post subject: |
svenakela wrote: |
Thanks for this, as too everyone else helping in this thread. I too have a drivers heated seat in my Syncro, they all came with this in Finland too asaik.
My seat don't work, and with only 180k or so miles, and seat in good condition, I will check that fuse.
Any idea how to check the relay? (Apart from replacing it.) |
