Do you use the oilbath aircleaner or an air filter of some kind? |
Oilbath |
66% |
[ 20 ] |
air filter |
33% |
[ 10 ] |
Total Votes : 30 |
kenkennedy Samba Member
Joined: April 13, 2004 Posts: 63 Location: Alberta, Canada
Posted: Fri Feb 22, 2008 8:32 am Post subject: Original air cleaner |
Can someone post or send me a couple of pics showing where all the hoses are supposed to go?? Please. |
klokard Samba Member
Posted: Fri Feb 22, 2008 5:49 pm Post subject: |
Though I have the dual set up, look at the hose attachments for the right side only as they are the same for the single air set up. Good luck.
Posted: Sun Feb 24, 2008 12:23 am Post subject: Original air cleaner |
Where does the tube on the back side of the cleaner connect??
[/img] |
mrafindley Samba Member
Joined: December 29, 2007 Posts: 642 Location: miami Florida
Posted: Sun Feb 24, 2008 7:28 am Post subject: |
The hose I colored red what does it connect to? I have a hole in the tin for it does it just stick through the hole? My 66 beetle has pre heat pipes that that hose hooks to tha runs over and draws heat off the motor any pics of that?
_________________ 73 THING
67 Beetle
http://w2.wolfsburgii.com/downloads.htm |
Van-go108 Samba Member
Joined: November 23, 2006 Posts: 2995 Location: Southwestern, NM
Posted: Sun Feb 24, 2008 8:14 am Post subject: |
I'm surprised to see that many of you guys using the oil bath. Is there any particular reason? I don't have an oil bath but a friend of mine said he had one for me if I wanted it. Years ago I had an oil bath on my 51' Chevy but I ditched it for some chrome pretty air cleaner. _________________ "Okay, so there's 6 beers and 5 of us. You know what this means don't you? 4 of you are going to have to leave."
1973 Thing
1957 Continental Mark II Click to view image |
Posted: Sun Feb 24, 2008 8:19 am Post subject: |
I never had one on mine but for some reason I can't get the oil to stop spiting out of the hose on top of the generator housing that would go to the oil bath so I bought MichaelB's of his thing project. So hopefully my engine will stay clean now. I have one on my 67 bettle and wouldn't trade for it on a cold morning _________________ 73 THING
67 Beetle
mattt Samba Member
Posted: Mon Feb 25, 2008 12:30 am Post subject: |
mrafindley wrote: |
It hooks to one of these under the engine tin.... http://www.thesamba.com/vw/classifieds/detail.php?id=521593
It's purpose is to bring warm air from under the engine into the intake to aid in warm up. The "stovepipe" goes in between the bottom engine tin and the push rod tubes. |
howiesfamily Samba Member
Joined: March 31, 2004 Posts: 858 Location: Panther City, Texas
Posted: Mon Feb 25, 2008 7:30 am Post subject: Re: Original air cleaner |
kenkennedy wrote: |
[/img] |
If you mean the one that is about the same diameter as your finger, the hose connects to a fitting on the fan shroud right there by the air cleaner. I have the fitting on the shroud but not on my air cleaner. I just have a rubber plug on the fitting to keep my cooling air from escaping. _________________ member of: Fort Worth Aircoolers Gang |
