Posted: Sat Mar 22, 2003 12:02 pm Post subject: Westy roof painting/sealing? |
I've got a 77 westy, Im planning on repainting the bumpers and pop top soon. What kind of paint should I use for the roof, and how should I prepare it and what not? Are there any certain things I should do like prime it? If you have a good color of white of a certian brand of paint that you've found to work really good, could you through that my way too. Thanks |
salvaged_pinkslip Samba Member
Posted: Sat Mar 22, 2003 1:05 pm Post subject: Westy roof painting/sealing? |
There are two articles on http://www.type2.com/
Go to the section called Library. Then select CAMPER from the alphabetical list. Scroll down to the part that says
Pop-up Tops, Camper Beds, Cots, Hammocks:
Scroll down a bit farther and you will find.
Fiberglass Pop Top Painting by Brian Hoare
Fiberglass Pop Top Restoration by John Anderson
I've bought the materials that Brian Hoare recommends, but haven't tried the job yet.
Gool luck. |
Posted: Mon Mar 24, 2003 7:33 am Post subject: Westy roof painting/sealing? |
cool cool, thanks a lot man |
Posted: Mon Mar 24, 2003 7:55 am Post subject: Westy roof painting/sealing? |
Make sure you wear a mask when sanding the fiberglass, that stuff can mess up your lungs |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19670 Location: Land of Whine and Phonies
Posted: Mon Mar 24, 2003 1:53 pm Post subject: Westy roof painting/sealing? |
Check out a local boating supply store for paint. |
