Official Bay Window Engine pics, pix, pictures, thread FAQ
Page: Previous  1, 2, 3 ... 28, 29, 30, 31  Next
lugo2214
lugo2214 is offline
PostPosted: Fri Feb 14, 2014 9:01 pm    Post subject: Reply with quote
This thread was inspiring
RoRo's Campeter
1973 Tin Top Campmobile
Type 4 ENG / 2.0 HYD LIFT
003 Auto Trans 😆/😣
Dual Empi 44
009 Ignition
Ice Auto Air A/C kit 50% installed
justcruzin
justcruzin is offline
PostPosted: Fri Feb 14, 2014 9:33 pm    Post subject: Reply with quote
Here's my new 1776. What can I say, I'm a girl and I like pink and purple. Very Happy
Kim
Sacramento, CA
1964 Split Window Bus
1966 Beetle Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=472933
1969 Delivery Van= http://www.thesamba.com/vw/forum/viewtopic.php?t=566282
1970 Westy Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=479538
1971 Squareback Build Thread = http://www.thesamba.com/vw/forum/viewtopic.php?p=6652459#6652459
1970 Single Cab, Samson = http://www.thesamba.com/vw/forum/viewtopic.php?p=8022609#8022609
crownline Premium Member
crownline is offline
PostPosted: Sat Feb 15, 2014 7:40 am    Post subject: Reply with quote
Kim, I love the colors looks nice and clean. Is that all powder coat? Or paint
1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL]
justcruzin
PostPosted: Sat Feb 15, 2014 1:21 pm    Post subject: Reply with quote
It's rust-oleum painter touch 2X ultra cover paint. It says paint and primer on the can although I did primer everything too. I put atleast 3 coats on most all of it. Really came out nice looking.
Kim
Sacramento, CA
notchboy
notchboy is offline
PostPosted: Sat Feb 15, 2014 2:09 pm    Post subject: Reply with quote
Cool
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
Lionhart94010
Lionhart94010 is offline
PostPosted: Sat Feb 15, 2014 3:28 pm    Post subject: Reply with quote
Kim, youre engine looks great, my 2yold daughter would go crazy if she saw it she love, cars and those are her two favorite colors :0)
Just and FYI, if your manifold heat risers do not burn off all the pink paint until it looks flat white/gray then it is not working properly and your bus will not run as well as it should
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 72 KG GT;0) 12 JSW TDI
Other owned VWs 59, 68 1500s, 69 & 71 Bugs; 72 & 73 S-Bugs; 67 Westy, 67 Deluxe, Other 71 DC
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
justcruzin
PostPosted: Sat Feb 15, 2014 3:46 pm    Post subject: Reply with quote
Thanks!
On the heat risers I knew they would burn the paint off. That is one of the things I did forget to check before installing though. I was thinking they were clear because I remember cleaning them out a while back, but after thinking about it, it was the single port we cleaned out. So far the paint is just turning color at the point it is hooked to the exhaust and up about 2- 2.5 inches up. That will be a project for later down the road. Next time we have to pull the engine I will check them. I was told if they were plugged, it wouldn't warm the carb up as fast and cause issues with the warm up. After running for a bit it would run ok with them clogged. Maybe I was misinformed? At any case, it seems to run good and only takes about 3 or 4 minutes to warm up enough to idle on its own. I think my carb isn't the greatest either though so that may be part of why it won't idle from the jump. I bought a new one and am waiting for a friend to come and install it and dial it in. I don't like doing the dialing in part. Smile
Kim
Sacramento, CA
eche_bus
eche_bus is offline
PostPosted: Sat Feb 15, 2014 4:40 pm    Post subject: Reply with quote
I just can't help myself. Wink
Lionhart94010
PostPosted: Sat Feb 15, 2014 4:41 pm    Post subject: Reply with quote
Thanks!
Kim
Sacramento, CA
Re: I was misinformed?, sorry but I think yes, due to the long intake run and the effects of vaporizing the fuel, the intake manifold can get cold even on a hot day; that may cause pour fuel mixture and could cause engine damage (my understanding is that it may cause it to run too lean(lose power and /or get to hot) and/or have un-atomized fuel droplets dilute the oil film on the cylinder walls= faster Ring/cylinder wear) (un-atomized fuel droplets, same reason why you want them working when it is started from cold)
old DKP driver
old DKP driver is offline
PostPosted: Sat Feb 15, 2014 5:02 pm    Post subject: Kim's Engine colors Reply with quote
Kim, now you need to move to Santa Cruz and drive up and down Pacific avenue with the lid open. Very Happy
Seriously, it looks really, really Good. Purple Bus
V.W.owner since 1967
vince1
vince1 is offline
PostPosted: Sun Feb 16, 2014 4:44 am    Post subject: Reply with quote
Build thread here Wink
http://www.thesamba.com/vw/forum/viewtopic.php?t=579257
my French blog http://panelvan.skynetblogs.be/
Click here for my full pix detailed 2165 engine build with beehive valvetrain.
Sorry for my poor English, I'm a French guy ... Wink
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Tcash
Tcash is offline
PostPosted: Sun Feb 16, 2014 10:07 am    Post subject: Reply with quote
Those colors pop.
Just a thought. Good Luck
justcruzin
PostPosted: Sun Feb 16, 2014 10:33 am    Post subject: Reply with quote
Tcash wrote:
Those colors pop.
LOL never thought of doing that. I just bought another oil bath at a wrecking yard, think I'll give that a try and see what it looks like! Smile
Kim
Sacramento, CA
peaceful warrior
peaceful warrior is offline
PostPosted: Fri Mar 07, 2014 10:16 am    Post subject: Reply with quote
Did a search and did not find what I was looking for. Has anyone installed a type IV engine into an early Bay (68-71)? Is there a thread about it?
I have 2.0 and 6 rib transmission from a 78 bus and a friend of mine sold me a slew of Raby parts, upright fan housing, etc. and have been toying with the idea of installing it in my 68 Westy.
Thoughts?
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
babysnakes
babysnakes is offline
PostPosted: Fri Mar 07, 2014 2:46 pm    Post subject: Reply with quote
Yes it has been done. Raby even produced a mustache bar for that conversion. I'll be doing the same with my '69 SC. My only concern is the mid point/rear tranny hanger that is not present in early bays. This just leaves the front tranny and mustache bar mounts.
Brian
Brian is offline
PostPosted: Sun Mar 09, 2014 12:09 pm    Post subject: Reply with quote
My thought would be to weld in the transmission hanger. Because both components are heavier. But I'm guessing the engine support can still hold it. I'm curious as well.
'69 Bug
'68 Baja Truck
'71 Bug
Ran when parked
nathansnathan
nathansnathan is offline
PostPosted: Sun Mar 09, 2014 12:42 pm    Post subject: Reply with quote
The conversion Jake did on the pickup didn't use a middle mount. He cited that a 914 doesn't use one either and came that way from the factory.
Jake Raby
Jake Raby is offline
PostPosted: Sun Mar 09, 2014 12:45 pm    Post subject: Reply with quote
And so does a 911... Even a 2014 GT3.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
babysnakes
PostPosted: Sun Mar 09, 2014 1:40 pm    Post subject: Reply with quote
Good to know. Thanks Nathan and Jake.
Brian
Brian is offline
PostPosted: Sun Mar 09, 2014 6:53 pm    Post subject: Reply with quote
Insightful
'69 Bug
'68 Baja Truck
'71 Bug
Ran when parked
Page 29 of 31
