High pitched noise
[email protected]
cfisher13@aol.com is offline
PostPosted: Wed Apr 02, 2003 10:42 am    Post subject: High pitched noise Reply with quote
As I drive my 69 sundial i hear a loud high pitched noise coming from the front of my bus. This happens usually when i am using the gas pedal but also sometimes when i use the breaks or clutch. What could this be I need to fix it asap since this bus just turned into my daily drive since i crashed my other car.
OB Bus
OB Bus is offline
PostPosted: Wed Apr 02, 2003 10:50 am    Post subject: High pitched noise Reply with quote
Could be many things. Wheel bearings are a freqeusnt souce of mysterious high pitched sounds. Is the sound reletive to speed? Does it only come on when you touch the brakes? Might be a brake shoe sraping or worm out. Do you have stock tires? Wider ones might be rubbing in certain driving situations.
[email protected]
PostPosted: Wed Apr 02, 2003 1:09 pm    Post subject: High pitched noise Reply with quote
It only happens when i used the pedals.
chabanais
chabanais is offline
PostPosted: Wed Apr 02, 2003 2:13 pm    Post subject: High pitched noise Reply with quote
Spray some Lithium Grease on the pedal springs and let me know what happens.
