Posted: Sat Apr 05, 2003 5:15 pm Post subject: Air Cleaner |
I recently purchased a 71 bus. It is time to change the air filter, but I am having a problem changing it. The air cleaner will not open up. It appears to be stuck. I am not sure how to get it open any sugestions?
Thanks all,
Daniel |
chabanais Samba Member
Posted: Sat Apr 05, 2003 7:04 pm Post subject: Air Cleaner |
If you mean the Oil Bath Cleaner there are a series of sprin clips. |
Posted: Sat Apr 05, 2003 9:55 pm Post subject: Air Cleaner |
I have released the clamps. The two halfs are stuck. Any clue how to get them apart? |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Sat Apr 05, 2003 9:59 pm Post subject: Air Cleaner |
Try pulling and twist alittle at the same time first, then try a small screw driver and gently pry between the two. It will come loose. |
Posted: Sun Apr 06, 2003 4:09 pm Post subject: Air Cleaner |
I would also try gently banging them with a rubber mallet to break the crud between the two pieces. |
TimGud Samba Member
Posted: Sun Apr 06, 2003 8:01 pm Post subject: Air Cleaner |
Ya, thats alot better idea than prying. |
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Sun Apr 06, 2003 8:51 pm Post subject: Air Cleaner |
(...without going outside to look at my bus)
isn't there a *third* clip that is in front of the air cleaner (that you can't see)?
I doubt that there is enough grunge to keep it from opening. Never had that with any of *my* busses, but one never knows... |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Mon Apr 07, 2003 7:55 am Post subject: Air Cleaner |
Yeah, that clip behind the filter housing, (towards the front of the bus) had me scratching my head once. If you don't have it, invest in the Bentley manual - it's worth every penny. |
