What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 410, 411, 412 ... 419, 420, 421  Next
TomWesty
TomWesty is offline
PostPosted: Wed May 24, 2017 8:35 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I replaced the brake servo with a new air tec model and replaced the master cylinder with a Brazilian one. New lower reservoir and new vacuum hoses to and from the servo. Getting ready to bleed....
inhabor
inhabor is offline
PostPosted: Thu May 25, 2017 7:03 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I installed two new gauges in my bus cylinder head temp and air fuel ratio.
inhabor
inhabor is offline
PostPosted: Thu May 25, 2017 7:18 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
On board air sistem
cv66seabear
cv66seabear is offline
PostPosted: Sat May 27, 2017 8:05 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Installed Vintage LEDs - 4000 Lumens - correctly, this time!
Replaced rear Seat belts with new green ones from car seat belts.
Replaced front turn signal lenses.
OH, also replaced the left front visor holder - you have to remove the visor then put in the holder, then slide in the visor and re-fasten! Clever Germans!
Would like to put the base on my new Berlin table, but can't find anything showing where it goes!
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
2015 Passat 1.8T "Rudy"
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sat May 27, 2017 8:36 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Installed a Pertronix unit.
Eric
77 Westy / 74 Super Beetle
My Photography Page. Photo Prints Now Available!
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Sun May 28, 2017 1:43 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
New brake light lenses. Five years on the old ones (left side) showed some weird heat-fading around the bulb area. Lenses looked light pink at night.
Wrapped up a quick 300-mile trip with this road to celebrate five years together. Razz
Robbie
www.airschooled.com
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
cv66seabear
PostPosted: Sun May 28, 2017 6:29 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
what road is that - that looks awesome!
wihr
wihr is offline
PostPosted: Sun May 28, 2017 6:57 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
For a '70, that is a second gear climb.
WW
WIHR
1970 Campmobile "Van Ordinaire"
1972 Mercedes Benz 280 SEL 4.5 "Buttercup"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc
RBurn
RBurn is offline
PostPosted: Thu Jun 01, 2017 8:29 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Well i finally figured why i was running on 3 cylinders. Bought the van a month ago and i knew it wasn't running quite right but the drive home was 5 miles level and some down hil. Wasnt firing on #4, checked valve clearance, tried different plugs, checked plug wires, changed coil and cap. I then checked compression and #4 was 110. Thinking what the heck. Finally the last item i could check was to change distributor and bam shes running on all 4. It came with a 009 and 30pict-2, i had enough smarts to get a rebuilt 30pict-3 from volkzbitz and the rebuilt 205T from Bill Fowler. Tuned her up and she runs beautifully. Next is alot of delayed maintenance on the bus. This site has been awesome!
Enjoy
Rob
70 T2 Model 221
70 T2 Model 231
70 Karmann Ghia Vert
67 Beetle deluxe
TomWesty
TomWesty is offline
PostPosted: Mon Jun 05, 2017 6:02 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I drilled out the rivets on the bars on my westy luggage carrier, removed the bars and submerged them in Evaporust overnight and then after rinsing them, blasted them with Rustoleum cold galvanizing spray.
webwalker
webwalker is offline
PostPosted: Wed Jun 07, 2017 8:35 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Cleaned out the accelerator cable tube, cleaned cable, installed new front boot with a load of grease in it and coated the cable and the inside of the tube with spray teflon.
Removed TDI starter preparatory to dropping engine / transmission package to have the transmission rebuilt for a better gear ratio to match the Subaru 2.2.
Also removed the transmission carrier bolts at the top of the transmission (091) bellhousing preparatory to dropping the package.
Replaced split brake fluid reservoir cap with new one way venting unit.
Replaced Emergency flasher switch, the old one having literally disintegrated in its enclosure.
Intend to have the transmission on its way to the shop in a week.
Still kicking, here in NJ.
Webwalker
North American Member of the Static Motion Club
1977 CE1 Transporter Deluxe
Click to view image
AircooledHome
AircooledHome is offline
PostPosted: Fri Jun 09, 2017 8:59 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I've been doing a ton to my bus. I'm moving in as soon as it's done and traveling, so check out the thread in my signature if youre interested?
'71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight=
Van Damage
Van Damage is offline
PostPosted: Thu Jun 15, 2017 10:42 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Ordered a new alternator, then daydreamed about the day when the body work is complete.
SamboSamba22
SamboSamba22 is offline
PostPosted: Fri Jun 16, 2017 6:06 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Yesterday consisted of me tearing into the steering coupler to find out I ordered the wrong part, followed up by finally getting my wiring correct down there to have a working horn!
Honk, Honk baby, yeah Iím going 60mph, and YOUíRE driving like an a-hole! HONK! Ohhh, the joy to be had.
Invention is the tool of the adventurer - Jacques Cousteau
Sinning led me to become a saint, which I then learned I wasn't qualified. -Samuel Heath Belcher
2017 Golf GTI
1974 Brilliant Orange Westfalia Deluxe
1965 Ruby Red Standard Beetle - SOLD
1959 Dove Blue Single Cab
ISO Rebuild kit APG Fuel Pump (Type 4/72-74
Bus)
lostsailr
lostsailr is offline
PostPosted: Sat Jun 17, 2017 7:42 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I finally got back to my emergency clutch cable replacement. Last fall, when my knee was blown out, the cable snapped, fortunately in my mother's driveway. After remembering there was an old spare under the bench seat, I found enough tools to replace it, but didn't grease it. Then I drove it back home for the winter.
so I got a new complete set and redid the whole thing with grease, seals and an improved bowden tube with metal tip instead of plastic. Found the old wing nut was only a single wing, lol. Glad I got the whole kit.
Pedal is smooth as butter now! Next is the gas pedal hinge, spring and through floor seal.
Noticed a gas line replacement may be in order. Probably the best thing I did... finding that. Not critical, but I'd rather that it not get that bad.
The Bus came by and I got on, that's where it all began!
KentPS Premium Member
KentPS is offline
PostPosted: Sun Jun 18, 2017 8:38 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
You might consider buying a new pedal linkage from Butty's Bits. It is a thing of beauty and works great. Simple to install too.
-Kent-
1976 Riviera, my 1.7l FI chrome yellow VAN - "Chloe"
--> Whatever you do, have fun doing it! Smile
WildIdea wrote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!"
senseless1707
senseless1707 is offline
PostPosted: Sun Jun 18, 2017 9:26 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Continued to tear out more interior.
2014 VW GTI
1976 Westfalia Camper
SamboSamba22
PostPosted: Mon Jun 19, 2017 6:00 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Cabinetry looks good, other than the doggy door on the bed/bench corner lol
2017 Golf GTI
Bus)
kooper271
kooper271 is offline
PostPosted: Mon Jun 19, 2017 6:08 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
figured out my distributor drive pinion was installed (by me) 180 deg off. Installed a pertronix kit in my distributor.
new cap and rotor.
new clutch and pressure plate
removed the transaxle and degreased it. scraped off a good 3/8" of crud. Needs new nosecone and bellhousing gaskets
richardandtory
richardandtory is offline
PostPosted: Fri Jun 23, 2017 10:19 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
My lovely wife was asking for a grab handle for when we swing around corners and something to hold onto in the heat to get a bit of fresh air under the arms... So I put up this grab handle matching the door pull... Seems to work ok!
Page 411 of 421
