What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 414, 415, 416 ... 422, 423, 424  Next
static
static is offline
PostPosted: Wed Aug 30, 2017 6:45 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
New galley pump!
I changed out the galley pump with a new one maybe 15 years ago.
I had replaced O-rings along the way, but the "remove-repair-reinstall" love affair was long over.
Thankfully, The Bus Depot (for now) still stocks manual pumps for the early Bay Westfalias.
I also needed to replace the water line from the tank (it was only 47 years old) with a new one.
Getting to it was a pain, but JLT helped.
And it works! I'm going camping!
Like VW campers? Join us!
https://www.facebook.com/groups/2362239654/
williamM
williamM is offline
PostPosted: Wed Aug 30, 2017 6:55 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
static wrote:
New galley pump!
[img]
[/img]
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
RBurn
RBurn is offline
PostPosted: Sat Sep 02, 2017 3:55 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Went with hankook vantra LT. 185r14.
Sandblast powder coat rims.
New front brakes, wheel cylinders
Did new shocks front and rear. Kyb gr2 front and rear gas selects.
Changed transaxle oil, adjusted the valves and changed motor oil
Removed, cleaned greased cv joints and new boots.
Next will be installing correct rear and middle seats and checking rear brakes.
I think shes ready to roll.
70 T2 Model 221
70 T2 Model 231
70 Karmann Ghia Vert
67 Beetle deluxe
Beagledog1
Beagledog1 is offline
PostPosted: Sun Sep 03, 2017 1:07 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Installed a new pop-up canvas from Bus Depot.
RBurn
RBurn is offline
PostPosted: Mon Sep 04, 2017 8:26 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Middle seat. Check. Now for some seat middle seat seat belts
70 T2 Model 221
70 T2 Model 231
67 Beetle deluxe
Tcash
Tcash is online now
PostPosted: Mon Sep 04, 2017 11:51 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Rear/mid seat belt lengths?
https://www.thesamba.com/vw/forum/viewtopic.php?t=578215&highlight=seat+belt+length%2A
Seat Belts & Mountings
http://www.justkampers.com/vw-bus-parts-1968-1979/...tings.html
richard123vmt
richard123vmt is offline
PostPosted: Sun Sep 17, 2017 1:58 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
My front door button (71 Bus) was increasingly difficult to operate, giving me soreness clear up to my shoulder. Yesterday, I tried some adjustment to the striker plate. There was a galling on it. Anyway, I did get it to work much better but today I discovered I could not get out! The inside lever would not work. Thinking something had gotten disconnected, I removed the panel but I found that it was the trim on the inside lock lever itself which was causing the trouble. I removed the trim and it works--but I like this not. I like to keep all the parts that come with the car.
Is there any good treatise on door locks? It would be nice to fix it so that it was a pleasure to open.
westysmb
westysmb is offline
PostPosted: Mon Sep 18, 2017 12:52 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I have the engine out right now, so I figured I'd quickly tackle this project.
Yesterday I replaced the old duct taped (yes, duct taped) filler hose with a new, proper piece. Much better now.
1970 Westfalia with a late Sportsmobile top
static
static is offline
PostPosted: Tue Sep 26, 2017 8:06 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Had my local VW repair boutique install Pertronix ignition.
I procrastinated and dicked around for about 25 years or so until I trusted that new fandangled system.
Wish that I had done it years ago. Immediate, noticeable improvement.
Spike0180
Spike0180 is offline
PostPosted: Mon Oct 02, 2017 8:16 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Changed oil
Replaced rear soft brake lines
bled brakes
fixed oil leak
greased front beam
replaced spring in drivers door handle
found that my brake light switches are both worthless...
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
66311
66311 is offline
PostPosted: Mon Oct 02, 2017 5:03 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Bought a bike rack that clamps on the swan neck ball.
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Sat Oct 07, 2017 4:06 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Globespotter wrote:
Decided to test set up my Westy tent for the first time in the basement. Didn't realize how huge it is! It is in mint shape, barely used and is going to be awesome this summer!
Where the heck is everyone getting these sweet tent finds??!?!?!
Robert in Memphis
1971 Riviera small pop-top
Engine rebuild thread
Fuelly MPG and maintenance stats
1641cc | CB cheater cam | H30/31 | 205T SVA | FF oil | everything else stock
FAA A&P
Charlie57
Charlie57 is offline
PostPosted: Sat Oct 07, 2017 5:20 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Today I did some prep work to my engine, have to stop and order some parts but did make a little progress. Here is my engine with the new thermostat, the fan shroud flaps and a few random pieces installed. I have to order some parts before I can keep going.
I do have a few questions under my thread:
"Restoring my 78 from the ground up"
Charlie
NOVA Bus
NOVA Bus is offline
PostPosted: Sat Oct 14, 2017 6:15 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Finally got around to finishing my front end restoration on 1977 Transporter.
Parts installed: Ball joints, drag link, tie rods, torsion arm bump stops, brake rotors, calipers, pads, wheel bearings, brake booster, brake master cyl, all the hoses and tanks, and set of nice new Koni shocks. Let's hope it lasts another forty years!
Many thanks to all you techies on this site for advice and information on how to do this the right way, invaluable resources here on Samba.
Before:
After:
1977 Transporter / Weekender
- GE engine, L-Jetronic w/ hyd. lifters
- Brown Beige plaid P27 Interior (ED)
http:/[url=http://www.vw-mplate.com/mplate-29638.png]Click to view image
Camper Interior donor:
[/URL]/www.vw-mplate.com/mcode.php?lang=EN&id=721 (M-Code for interior).
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sat Oct 14, 2017 12:53 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
New set of NGK spark plugs today. the last set had been in my '77 (2.0L FI) for 34K miles & about 7 years.
Also installed a hot/hard start relay. I gave finding the actual issue a try for a while, but I just don't drive the bus enough to really dig into it any more. The relay is mounted safely inside the engine compartment with the wires going through to the starter. Clean install.
Eric
77 Westy / 74 Super Beetle
My Photography Page. Photo Prints Now Available!
AirAssault2
AirAssault2 is offline
PostPosted: Sat Oct 14, 2017 2:00 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I rewarded her for being a good girl and took her on her longest journey yet. We did a 900 mile round trip to Morehead City, NC and camped near the beach. She did a phenomenal job. I couldn't have been more proud and more excited for more adventures. You should check it out!
camit34
camit34 is offline
PostPosted: Thu Oct 19, 2017 12:43 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Drove it down to ALBQ last weekend for the Balloon Fiesta
1971 Westy (Uncle was OG-PO)
1971 Deluxe (Soon to be FOR SALE)
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Thu Oct 19, 2017 1:01 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
camit34 wrote:
I've been trying to get to Busses and Balloons for over a decade. One of these years...
Eric
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Fri Oct 20, 2017 12:08 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Special reverse flood lights installed:
Spark plugs cleaned (EW!):
…and went to the beach!
Also bought more heads, drove 500 miles, and polished the fuse box tabs for the second time in six years…
Robbie
www.airschooled.com
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
williamM
williamM is offline
PostPosted: Fri Oct 20, 2017 1:32 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
got the new tires and rims mounted and the signature paint job has begun - still working on the electrical- tested the new out of the box starter switch and --Dange it- the old one is bad.- so back into the column again in 3 years- Evil or Very Mad
[img]
[/img]
Don't step in any!
Page 415 of 424
