sodbuster Samba Member
Joined: August 08, 2004 Posts: 1085 Location: wherever my baywindow takes me.
Posted: Mon Feb 05, 2018 9:02 am Post subject: Re: What did you do for your Bay recently? |
The horror. The horror.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Mon Feb 05, 2018 9:36 am Post subject: Re: What did you do for your Bay recently? |
Looks a lot like the #4 in my 63 Westy when the 40 horse gave up back in 1993. I still have the piston with the offending valve head glued to it as a reminder. _________________ nothing |
AircooledHome Samba Member
Joined: October 13, 2015 Posts: 273 Location: California
Posted: Mon Feb 05, 2018 6:31 pm Post subject: Re: What did you do for your Bay recently? |
Scary!!!
I just installed my new engine in my bay, but wanted to share a trick. I am working without a lift, and always struggled to get the engine into the engine bay with it balanced on a floor jack. So I went to harbor freight for $15 bought 4 swivel casters and welded a 3 sided square tube frame. Welded the casters on, and now have a omni-directional cart for engines. It made the install so much easier, I'm sure I could have done it with the dual carbs in place if I had tried. Also, since it's 3 sided you can simply slide a jack under and jack the engine off the dolly.
Weld one if you have the ability!
_________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
Plateau Samba Member
Joined: February 09, 2018 Posts: 1 Location: central North Dakota
Posted: Fri Feb 09, 2018 12:51 am Post subject: Re: What did you do for your Bay recently? |
in-laws came over to see the kids so I hung out with the bus in the bus and read Animal Farm can’t wait for spring! _________________ 1968 Riviera Tinpo Tintop |
mike77777 Samba Member
Joined: May 13, 2009 Posts: 119 Location: portland or
Posted: Fri Feb 09, 2018 3:49 am Post subject: Re: What did you do for your Bay recently? |
Metal Goodness. USA webcam and lifters. German Crank, 10/10 under. Honing cylinders, waiting on a case bolt anti harmonic damper(the funny looking white things in the gasket set). Fresh tube of Curil. Many parts sourced form Halsey Automotive in Portland, OR. great bunch down there. Picked up some new piston pin circlips, and some oil filters. They have Air Cooled Oil in stock(zinc) _________________ patience and putty |
Posted: Mon Feb 12, 2018 3:09 pm Post subject: Re: What did you do for your Bay recently? |
Zambia Samba Member
Joined: December 15, 2009 Posts: 56 Location: Southern Pines, NC
Posted: Tue Feb 13, 2018 5:53 pm Post subject: Re: What did you do for your Bay recently? |
I gave my bus a new camping trailer. It's a 1971 two wheel all state trailer I found on Craigslist that I brought back to life. It's got all our camping stuff packed and ready to go. Glamcamping at it's best lol.
Posted: Fri Feb 16, 2018 7:59 am Post subject: Re: What did you do for your Bay recently? |
Doing things on my "while I'm in there" list, as part of my engine rebuild.
I Followed Telford's excellent tutorial and fixed my fuel tank sending unit.
CV repack. A little before and after.
Posted: Mon Feb 26, 2018 9:42 am Post subject: Re: What did you do for your Bay recently? |
Engine progress.
svvsam Samba Member
Posted: Mon Mar 12, 2018 10:55 am Post subject: Re: What did you do for your Bay recently? |
Here my bay
fxshov Samba Member
Posted: Wed Mar 14, 2018 9:09 pm Post subject: Re: What did you do for your Bay recently? |
Well maybe not all today. But in the past month.....
1 Installed a 2054 type 4
2 Dropped spindles
3 Put the back up one click.
5 Rims and Tires
6 Tinted windows
_________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
I need a bigger garage. |
sioux888 Samba Member
Joined: November 12, 2015 Posts: 98 Location: La Feria Texas
Posted: Fri Mar 16, 2018 8:09 am Post subject: Re: What did you do for your Bay recently? |
After a while, working myself on my project I finally went through the painting stage; rewiring everything back is next, will be a pretty damn challenge.
Posted: Mon Mar 19, 2018 2:05 pm Post subject: Re: What did you do for your Bay recently? |
Well other than the 500 mile break in period I deem the camper done. I will always be doing something to it of course but the blown up engine disaster is behind it. I took care of a few things while I had "Ol Blew" apart. some you can see, many more you cant. Beyond the rebuilt engine and what it required I also did the following;
Replaced all external oil lines and relocate spin on oil filter mount and oil cooler fan thermo switch.
Repair fuel vapor recovery system.
Repack CV joints and replace axle boots.
Reseal transaxle replace "hockey stick" and fill with fresh gear oil.
Remove gas tank. Remove and repair fuel gauge sending unit.
Install serpentine belt system on motor.
Modify new header exhaust system to fit the flanges on my heater boxes.
Strip and repaint the new exhaust system with high heat paint.
install new side mirrors.
install new side step. (I ordered this a few days before the engine went south.)
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Mon Mar 26, 2018 6:40 pm Post subject: |
EZ Gruv wrote: |
I surveyed the damage from the lady that hit me. |
I hope you hit the b1¥[# back!
How bad was the damage? _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Tue Mar 27, 2018 7:57 pm Post subject: Re: What did you do for your Bay recently? |
sodbuster wrote: |
May as well order one for the other side. I ran through a mudhole and the step threw us sideways.
Here I had just dropped the motor for a new top end build, when my parents came by and she snapped a pic. I was breaking it in, while opening and running a store behind me, when it happened.
Oh, and Happy pg. 420! _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
Posted: Fri Mar 30, 2018 7:55 am Post subject: Re: What did you do for your Bay recently? |
Volswagon wrote: |
sodbuster wrote: |
Oh, and Happy pg. 420! |
On my 71 camper I have the classic 71 westy cross over pipe for the sink drain and a I also have a set of Addco sway bars on it too. Just like the EMPI sway bars the rear bar hangs pretty low. Have not hit anything yet in 15 years. I'm more worried about bashing the side step into a curb than it being the cause of the bus getting kicked up out of a mud hole. But thanks for the heads up anyway. I'll watch it. |
kevinj73us Samba Member
Joined: September 25, 2011 Posts: 228 Location: Laurel, MD
Posted: Fri Mar 30, 2018 9:19 am Post subject: Re: What did you do for your Bay recently? |
Changed the inline fuse for the PO's after market radio that blew as I tried to jump the battery.
Then changed a 16A fuse that blew when the end of the wire for the inline fuse touched the ebrake brace.
Drove to work.
kj _________________ 1973 Station Wagon
m-plate |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Fri Mar 30, 2018 10:04 am Post subject: Re: What did you do for your Bay recently? |
I've had a little work done to my bus in the last month...
Rebuilt steering box installed... check
New rag join... check
New ball joints... check
New tie rods... check
New drag link... check
New steering damper... check
New front and rear seals and bearings... check
Disc brake system from donor 71... check
New rotors, pads, and calipers... check
New master cylinder... check
New rear pads and cylinders... check
New brake hoses... check
New CV Joints... check
New high output alternator... check
New heater boxes... check
New external oil cooler w/fan... check
New external oil filter... check
New Weber 40 IDF carbs... check
New battery... check
New clutch... check
New heater cable... check
New clutch cable... check
New accelerator cable... check
New fuel pump... check
New flasher relay... check
Drove her yesterday for the first time since 2001. _________________ ~Kevin
My 1968 Campmobile |
Posted: Fri Mar 30, 2018 4:35 pm Post subject: Re: What did you do for your Bay recently? |
Hikelite wrote: |
New clutch... check
Drove her yesterday for the first time since 2001. |
Damn, that is quite the list! How does it feel to be back behind the wheel? _________________ nothing |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Fri Mar 30, 2018 9:33 pm Post subject: Re: What did you do for your Bay recently? |
Hikelite wrote: |
And that's the best thing you can do for your bay. Congrats!!!!
www.airschooled.com |
