airschooled Air-Schooled
Posted: Fri Mar 30, 2018 11:41 pm Post subject: Re: What did you do for your Bay recently? |
Ok I had to "do something for my bay" on page four hundred and twenty.
So I got some 69-cent poster board and made "panels" to cover the bulkheads where it was bare paint before.
Those should get me to Illinois at least this spring.
www.airschooled.com |
andrewtf Samba Member
Joined: August 10, 2011 Posts: 604 Location: Illinois
Posted: Sat Mar 31, 2018 7:15 am Post subject: Re: What did you do for your Bay recently? |
Awwww.... Robbie....
Missed it by........"that much"..! !
Everyone knows you need to start early on 420 to get anything done.
But I do agree - that poster board should get you to Illinois. _________________ '75 Riviera - 'BIG EMMA' (Pan American highway trip paused for a make over)
'77 Riviera - Murphy' (being reborn.... slowly)
'63 Austin Healey |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Sat Mar 31, 2018 12:49 pm Post subject: Re: What did you do for your Bay recently? |
cdennisg wrote: |
Hikelite wrote: |
I've had a little work done to my bus in the last month...
Rebuilt steering box installed... check
New rag join... check
New ball joints... check
New tie rods... check
New drag link... check
New steering damper... check
New front and rear seals and bearings... check
Disc brake system from donor 71... check
New rotors, pads, and calipers... check
New master cylinder... check
New rear pads and cylinders... check
New brake hoses... check
New CV Joints... check
New high output alternator... check
New heater boxes... check
New external oil cooler w/fan... check
New external oil filter... check
New Weber 40 IDF carbs... check
New battery... check
New clutch... check
New heater cable... check
New clutch cable... check
New accelerator cable... check
New fuel pump... check
New flasher relay... check
Drove her yesterday for the first time since 2001. |
Damn, that is quite the list! How does it feel to be back behind the wheel? |
With all new front end and brakes, it felt amazing!
It's been so long I can't truly appreciate all the difference, but I can tell it is much improved.
I doubt it ever felt this good back when it was my daily in 90's.
Thanks again for getting me in touch with Adam. He is great and took care of everything mechanical so I can actually get to the stuff that will make the Mrs happy
I also gotta give props to Adrian at Headflow Masters down in San Diego. The motor sounded and ran fantastic after all these years. Maybe it was just easier to build a quality engine back in 1997. _________________ ~Kevin
My 1968 Campmobile |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Tue Apr 03, 2018 9:18 am Post subject: Re: What did you do for your Bay recently? |
Front seats redone. Early TMI square covers modified to fit the later tapered frames.
I put over 225K miles on them with beat-up covers, broken springs and clips.
I started working on her 20 years ago, spent $8 grand the first year. She's been parked over 8 years.
Update: her first bath this decade, in between rain events!
_________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Thu Apr 05, 2018 6:21 pm Post subject: Re: What did you do for your Bay recently? |
Validating how much work and a pain in the ass it was going to be to remove a split-case transaxle with reduction boxes off my single cab, I put to use the ripped up moving blankets and excess 3” foam padding that was laying around in the shop to re-pad my front two seats in the Westy.
I took to the 3” padding an electric carving knife, buzzing the padding down to 1” thick pads, and did a combination of moving blanket (jute padding)/foam/jute to eradicate the springs from no longer sending pain up my back on the road. Pretty darn happy for no expense and about an hour or so of my time.
Here you can see I restuffed the front seats
_________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Sat Apr 07, 2018 2:32 pm Post subject: Re: What did you do for your Bay recently? |
With dragging ass on my post-700 mile trip service, I got around to running the valves and completing an oil change. Cylinders 3 & 4 were loose, right side was nice.
During my trip, I experienced a broken throttle cable, so I also took time today to replace that thing, which this time was a total pain in the ass. My make shift cable slide right in on the side of the interstate.
A question I have is that the brake servo up front, there is a port (barbed vent tube) on the rod portion of the brake booster with a hose going to a vented hard plastic tube, running along the perimeter of the driverside wheel well, today I replaced this MISSING tube. What a difference, the high idle at times, the wanting to stall at braking, the dieseling upon shutting off.
Who knew this thing was a vent for the vacuum system??? _________________ The Bus Barn Ltd. Co.
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Apr 09, 2018 7:49 am Post subject: Re: What did you do for your Bay recently? |
Fairly short list this time, but this is over the past week.
1) Retorque heads
2) Adjust valves
3) Drain oil, change filter, check oil strainer and replace seals
4) Fix dash wiring after I messed it up failing to install my new tach
5) Replace drag link (get stuck removing drag link from drop arm, cuss a lot and waste a bunch of time to fail in the end)
6) Buy new drop arm
7) repair steering box threads and threads on the nut for the steering box
Install new drop arm
9) Stop and catch my breath after that workout
10) Install new drag link (took 3 months to get the right boot on it after the first one was shipped with a ripped boot)
11) Go for a drive! (was it worth it? Yes! it steers much more direct now) _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
mborr2 Samba Member
Joined: April 11, 2018 Posts: 9 Location: Rochester,NY
Posted: Wed Apr 11, 2018 9:36 am Post subject: Re: What did you do for your Bay recently? |
I made some brass bushings for the throttle body on my leaky 34 PDSIT carbs.
The fear of setting your bus on fire is a great motivator! |
gfw2 Samba Member
Joined: March 07, 2009 Posts: 5 Location: United States
Posted: Wed Apr 11, 2018 3:52 pm Post subject: Re: What did you do for your Bay recently? |
Set the timing. The engine is out of a 1978 FI Bay window. Engine Code comes up 1977 2000cc. Its been runing well, but just wanted to check it. Woody has a Electronic distributor and showed 15* and 28*at 3500 + To be safe, i set it back to 7.5* and its only getting up to 20*....any thoughts?
Other recent work:
Installed tach
Installed LED signal lights
Installed Heater fan
Installed generic turn signal control to replace broken 1977 1/2 broken unit
Extensive interior work
_________________ 1974 Bay Window w/sunroof
Weber carburetor 1977 2,000 cc / hydralic lifters
Electronic distibutor
Putting my heart where my treasure is / matt6.19.21 |
wcfvw69 Samba Purist
Posted: Wed Apr 11, 2018 7:03 pm Post subject: Re: What did you do for your Bay recently? |
gfw2 wrote: |
Set the timing. The engine is out of a 1978 FI Bay window. Engine Code comes up 1977 2000cc. Its been running well, but just wanted to check it. Woody has a Electronic distributor and showed 15* and 28*at 3500 + To be safe, i set it back to 7.5* and its only getting up to 20*....any thoughts?
It's only advancing 20*? So, what you mean is it's advancing to 27.5* with the engine rev'd up to say 4000 RPM?
What kind of distributor is this? Picture of it or model number? _________________ Contact me at [email protected]
The Samba member since 2004.
melville Samba Member
Joined: August 09, 2006 Posts: 1246 Location: Just Outside the Redwood Curtain
Posted: Wed Apr 11, 2018 9:37 pm Post subject: Re: What did you do for your Bay recently? |
gfw2 wrote: |
No, that's dangerous. The 20 degrees under load will cook your exhaust valves.
Put it back to 28ish degrees at 3500 and let the idle fall where it may. Timing under load is much more important than timing at idle.
Your advance mechanism is probably sticky. Most VW distributors will advance 24ish degrees. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
gfw2 Samba Member
Posted: Fri Apr 13, 2018 2:43 pm Post subject: Re: What did you do for your Bay recently? |
Thanks for the comments on the timing! I didn't get very far setting the timing back, loss of power. So just letting it stay at 27.5* at 3,500 + rpm and not worry about the idle reading. To answer your question Bill, this Electronic distibutor was on the vehicle when I bought it and don't see any markings. BUT no vacuum advance or external coil either. Any one know the manufacturer? _________________ 1974 Bay Window w/sunroof
Posted: Fri Apr 13, 2018 3:39 pm Post subject: Re: What did you do for your Bay recently? |
gfw2 wrote: |
Thanks for the comments on the timing! I didn't get very far setting the timing back, loss of power. So just letting it stay at 27.5* at 3,500 + rpm and not worry about the idle reading. To answer your question Bill, this Electronic distibutor was on the vehicle when I bought it and don't see any markings. BUT no vacuum advance or external coil either. Any one know the manufacturer? |
Sounds like a fantastic Chinese distributor.. Post a picture of it. _________________ Contact me at [email protected]
78BusGA Samba Member
Joined: February 01, 2017 Posts: 315 Location: Buford, Georgia
Posted: Sun Apr 15, 2018 12:54 am Post subject: Re: What did you do for your Bay recently? |
After about 16 years... He got a deserved bath! He must have been eager for it because he decided to run, with coaxing, to get in and out for the event.
After installing a new inside sliding door handle (First new part on him!!), I actually got him to fire up with a bit of coaxing from WD40 used in the engine bay to work into screws that haven't been turned since God knows when.
https://youtu.be/wZXTQAbEfoc
I was quite pleased with the lack of dust and grime on the outside (roof looks wonderful), though the spots of rust made clearer by the pressure washer getting the loose paint off shows the honesty of the minor sanding the body needs, much in thanks (grrr) to the PO installing that side trim with rivets.
The engine is running on new gas that was put into the un-removed tank, when the PO had a shop replace the fuel pump to make it roadworthy. The engine is all original, the only two inconsistencies from normal are no air filter, and cracked vapor return lines (probably what kept it from idling).
I had created a thread a while back on him, though had it removed to make a new one later, when the project really gets underway, and as ideas have changed. Purists, you'll be happy with some of my revisions I am sure. _________________ Few will understand the passion and majesty, among the nuts and grease.
Tom H.
My '74 Super 1303 thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=764902&start=60
My '78 Kombi Bus thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=769385&highlight=
'72 Superbeetle (retired), '78 Bus Kombi 2.0FI, '74 1303 Superbeetle |
Posted: Sun Apr 15, 2018 2:40 am Post subject: Re: What did you do for your Bay recently? |
Type 4 1.8L rebuild using a '72 CB case, German standard bearings, RAT 9550 Cam w/ dual thrust, and HAM 0825 heads w/ 2.0L chambers. Len cut the steps out after 15,000 mi., as I am using dished Cima pistons, when resurfacing them 8 years ago.
I have torqued the case while hand-turning everything. First mock-up to check geometry.
OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2168 Location: Portland, OR
Posted: Sun Apr 15, 2018 11:33 am Post subject: Re: What did you do for your Bay recently? |
Adjusted rear brakes and e-brake (I love the feeling when your e-brake handle engages in just a couple clicks...)
Got the heat working a little better, but it still sucks. It's barely a defroster. I'm guessing that my non return flaps are either stuck or have fallen off. I'm going to remove the exhaust next weekend to fix my leaking oil cooler, so I'll fix it then. Made the decision to finally install the BA6 this summer.
Made a spreadsheet with my list of repairs for the westy. Since I'm getting close to being finished with my 67, I want to see what I'm getting into on the Westy. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
BackwardsInHeels Samba Member
Joined: April 23, 2017 Posts: 3 Location: Portland, Oregon
Posted: Sun Apr 15, 2018 11:00 pm Post subject: Re: What did you do for your Bay recently? |
Took the tattered canvas off a packed it up for shipment to the company the is making the new one. Also cleaned 1/4" layer of playa (alkaline Nevada desert dust) out of the pop up. There's a long way to go get, but it was big steps in the right direction. |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Wed Apr 25, 2018 7:37 am Post subject: Re: What did you do for your Bay recently? |
Not for my bus, but for a friend. 091 box for his '71 single cab. Got it done last night.
What have you done for a friends bus recently? |
Djpaz0975 Samba Member
Posted: Sat Apr 28, 2018 7:00 pm Post subject: Re: What did you do for your Bay recently? |
Adjusted the valves on my 71 bus 1600cc for the first time ever. Sounding great! |
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Sat Apr 28, 2018 8:27 pm Post subject: Re: What did you do for your Bay recently? |
Pulled out my craptacular Chinese fuel sending unit (second one ) and turfed it,rebuilt my old German one per Telford dorr's excellent tutorial and it works perfect..Thanks for that!
Replaced my bottom roller wheel on my sliding door,welded in a track plate where my body guy had left a weird lip,greased and now it it pops open and rolls back on it's own almost to the catch on the rear..(I know,so close)..a little push with one finger finishes the action..
Ohh yeah,bought a really nice cover for the Bus,as he will have to live outside this summer to make room for the '56 Oval turd I will need the space in the lab for that's set to arrive via shipper any day now and will take all my time and the wealth of riches I don't have to get that little devil back on the road _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
