What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 421, 422, 423 ... 425, 426, 427  Next
Hikelite
Hikelite is offline
PostPosted: Sun Apr 29, 2018 9:45 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I put this in.
~Kevin
My 1968 Campmobile She is drivable again!
cdennisg
cdennisg is offline
PostPosted: Sun Apr 29, 2018 10:06 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
^^^ Did you replace the bushing? A tricky job with the engine in place, but it can be done, with patience.
A podium level performance in the Waste of Time Olympics.
-Cold War Motors
Hikelite
Hikelite is offline
PostPosted: Sun Apr 29, 2018 10:24 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
No. I struggled for a bit, then came in and looked it up. Then I talked to Adam. I decided I'll swap it out next time the motor comes out, probably next month to replace rusty parcel tray.
~Kevin
cdennisg
cdennisg is offline
PostPosted: Sun Apr 29, 2018 11:02 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
If you have pending engine R&R plans, that is definitely the better time to do this job. It will take about two minutes, and that includes opening a beer.
-Cold War Motors
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Apr 29, 2018 11:27 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Did ya put any grease on the shaft that slides on the bushing? Always a good idea.
Bill
My 1970 bus refresh thread- http://www.thesamba.com/vw/forum/viewtopic.php?t=598191
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
orangebug60guy
Twin #1
orangebug60guy is offline
PostPosted: Sun Apr 29, 2018 5:16 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Replaced front pads and rotors. New rubber and metal lines.
Then put the engine seal in.
Adjusted the timing Best could but still need to sync the carbs.
View user's profile Send private message Send e-mail AIM Address MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
KentPS Premium Member
KentPS is offline
PostPosted: Sun Apr 29, 2018 5:24 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
orangebug60guy wrote:
Shocked. . . . Shocked . . . . Shocked. . . . Shocked . . . . Shocked . . . . Shocked
You are a brave man for posting that pic.
-Kent-
1976 Riviera, my 1.8l FI chrome yellow VAN - "Chloe"
WildIdea wrote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!"
tootype2crazy
tootype2crazy is offline
PostPosted: Sun Apr 29, 2018 6:35 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Replaced the rear crankshaft seal (fan end). Lubed and adjusted the shifter, the old grease was officially soap. And I finally got around to installing and tuning my idle valve (my bus is powered by fuel and spark megasquirt). No more starting with low rpm and then having high rpm when it's hot, now it's the opposite.
air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
xyzzy
xyzzy is offline
PostPosted: Sun Apr 29, 2018 6:41 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Finally got a replacement NOS Escutcheon plastic spacer for the sliding door handle since the original one was cracked and constantly annoying me! Getting that handle out was a son-of-a...
1973 VW Westfalia 2L hydraulic, dual Solex PDSIT
1987 VW Vanagon Westfalia
cdennisg
cdennisg is offline
PostPosted: Sun Apr 29, 2018 7:26 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
That's called FREESTYLE!
-Cold War Motors
KentPS is offline
PostPosted: Mon Apr 30, 2018 7:02 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I can't tell from the pic...
... Is that drivetrain blown? Think Shocked Laughing Razz
-Kent-
mike77777
mike77777 is offline
PostPosted: Wed May 02, 2018 6:44 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
patience and putty
BackwardsInHeels
BackwardsInHeels is offline
PostPosted: Thu May 03, 2018 9:39 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Replaced the sliding door seal yesterday (the 4th of the 4 doors) and got the passenger seat put back together and prepped for reupholstry today.
I'm looking forward to the NW Bug Run and hoping I get all of the projects done in time.
Life is a journey, not a guided tour.
1974 Sportsmobile camper conversion
Fozzy
Fozzy is offline
PostPosted: Sat May 05, 2018 7:53 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Today was the day I really got some work done.. Yesterday I bought some new OLD bus front seats and stripped them to the frames.. I took the driver's seat back to the salvage yard today and asked to exchange it for another. After pulling the upholstery off I found that it had rot in the tubes and at least two broken springs. Wandered around the place, found a few driver's seats in buses but they just would not budge/slide forward .. Then I found one with all of the front windows still intact and its seat came out great. I stripped it today and it was really nice and dry. I got to pull the horrid aftermarket/other car seats out and toss them in the driveway. The front of the bus has some rust issues.. but not horrible. I will replace the floor, but the rust in the seat pillars is just going to have to stay for now. Cleaned the pedestals out and off, sprayed all the rusty areas with some rust converter, it took most of the day. My buddy was under the bus removing the stupid plastic air horns and we ran the new vacuum line to the booster to the engine. It seemed to give me a lot of pedal, but I was driving it around the block with a 2 X 6 as a driver's seat. Looking forward to next weekend when I get to cuss like a sailor trying to reupholster the seats. TMI covers and seat foam is on the way.
65 Sedan..
Adopted 07/15/17
this is the bug I've been looking for..
71 Tin Top Westy
Adopted Dec or so 2017
xyzzy
xyzzy is offline
PostPosted: Mon May 14, 2018 5:00 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Replaced my Antenna. Which, instead of a 10 minute job, was a huge pain in the ass having to remove the under-dash AC unit. Used the wolfsburg west one, seems like good quality. Radio works anyhow.
SamboSamba22
SamboSamba22 is offline
PostPosted: Tue May 15, 2018 5:56 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Painted my rusty wiper arms.
Looking out is so much nicer now, I guess it truly is the little things.
Invention is the tool of the adventurer - Jacques Cousteau
Sinning led me to become a saint, which I then learned I wasn't qualified. -Samuel Heath Belcher
2017 Golf GTI
1974 Brilliant Orange Westfalia Deluxe
1965 Ruby Red Standard Beetle - SOLD
1959 Dove Blue Single Cab
ISO Rebuild kit APG Fuel Pump (Type 4/72-74
Bus)
camit34
camit34 is offline
PostPosted: Wed May 16, 2018 6:51 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Rolled the ODO over for the 2nd time...
I purchased the Bus from my aunt and uncle who bought it new and all indications are it has 162k on it when I bought it as my uncle had the engine rebuilt (I have the paperwork) in 1984 @ 126k miles and parked it 2 years later. So from the info I have this should be it's 2nd rollover.
1971 Westy (Uncle was OG-PO)
1971 Deluxe (Soon to be FOR SALE)
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
SamboSamba22
PostPosted: Wed May 16, 2018 7:21 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Awesome sauce!
2017 Golf GTI
Bus)
Tcash
Tcash is offline
PostPosted: Wed May 16, 2018 8:33 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Time sell that rare 00000 mile bus.
Laughing
jtauxe
jtauxe is offline
PostPosted: Thu May 17, 2018 1:40 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Yesterday, I removed three windshields. They all need replacing, and I figured, why not get the glass guys to install 3 at once! It's a job I have done many times before, but I will be glad to have someone else do these 3.
These are for the 1972 Sportsmobile, 1973 9-seat Wild Westerner (both of which are already sold, so I am being a nice guy), and the 1975 single cab.
Last evening, I cleaned them up and treated them all with Ospho. Aside from two pin holes in the single cab, everything looked pretty good! I was definitely nervous about having them all out at the same time, but was pleasantly surprised.
This morning, I painted the window sills (3 different colors, of course).
Tomorrow, Speedy Glass comes to install new glass!
EDIT:
All windshields in, and they look great. The installer even put in the plastic silver deluxe trim on the Wild Westerner. Yay!
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
http://vw.tauxe.net
1979 Champagne Sunroof
, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner
1974 Westfalia parts bus, 1975 Mexican single cab, 1978 Irish 4-door double cab RHD
Page 422 of 427
