What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 424, 425, 426 ... 462, 463, 464  Next
telford dorr
telford dorr is offline
PostPosted: Sun Aug 05, 2018 2:31 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Everybody screws up sometimes.
For a couple of days, I noticed that the GEN (alternator, actually) light was glowing slightly - you could see it in the dark of the garage. Other than that, all seemed normal. Now this was bothering me because I recently went through the entire electrical system, inspecting, cleaning and tightening. So there was no reason there should be any voltage drop from the rear of the bus to the front. As the light was just barely glowing, I assumed the alternator was OK and it was a connection somewhere.
So today I decided to look into the issue. Figured it was good time to check the battery water and terminals for tightness. So I pop open the rear hatch, and with trouble light in hand, peeked inside. First off, I noticed the battery hold down clamp was loose. Not so loose that the battery could relocate itself, but certainly not tight. So I grab a 13mm socket and ratchet, and tightened it down. That's when I saw the big bare wire sticking out by the air cleaner. That certainly was NOT RIGHT. Turns out it was the wire from the alternator B+ lug to the positive battery cable clamp. It had apparently pulled out of the butt splice on the aftermarket battery cable! I had used a proper ratcheting crimp tool to crimp it, but upon inspection, the butt splice terminal was a cheapie which didn't have a welded seam. Thus, it slowly relaxed, releasing its grip and allowed the wire to pull out. The fix was to cut that sucker off, solder the wires together and insulate with shrink tubing (two layers).
Lessons learned:
1) Don't use cheap electrical terminals - especially in high current situations! I normally don't recommend soldering wires in a high vibration environment like a bus, but for heavy (#8 AWG) wires, it's definitely secure and viable.
2) The battery wasn't charging, but the alternator was driving the small red B+ wire, thus regulating properly and driving the dash indicator with 13.8 volts. Because of the disconnected wire, the battery wasn't being charged, and was down to maybe 11.8 volts. This difference (2.0 volts) was enough to cause the indicator to glow slightly. Had I kept driving, the battery would have slowly died, and the dash indicator would have gotten progressively brighter. Lesson: even though everything else was OK, don't ignore barely glowing GEN lights - investigate. It will save you being stranded on the road.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
kruno
kruno is offline
PostPosted: Mon Aug 06, 2018 1:15 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
'58 bug
'54 barndoor
'79 bay window
'05 renault modus Smile a little gallic gay car
toXic rust
Colonel Mosby
Colonel Mosby is offline
PostPosted: Tue Aug 07, 2018 3:40 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I have HEAT! Been working on fixing the heat system in a 1970 transporter off and on now for 4 years. Finally got it fixed! I had to restore the long heat tube, replace the heater cables, restore the accordion tubes, and then finally hook it all back up. One of the cables was frozen but a drill helped me spin the cable out and put a new one in. I still had all of those plastic bits and boots that make the cables work well. I restored the heater boxes. The biggest challenge was figuring out how to replace the asbestos on the metal collars on the accordion tubes. I used exhaust wrap instead of the asbestos on the collars. Seems to work well. Well I was out for cruise this morning. Cranked the heater levers down on the dash and low and behold there was heat. I mean good heat too. At the defroster and at the floor. Totally restored. The hardest part was tightening down the barrel nut on the cables. I have a busted arm that is partially frozen and I just could not get both arms up there to make it happen. Finally mastered after I removed the rear wheels to get both arms up in the right place for the tightening.
SamboSamba22
SamboSamba22 is offline
PostPosted: Tue Aug 07, 2018 9:25 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Heat is good, he says.
Well done, I know I sure appreciate my heat. With the later bay layout, the additional blower motor, along with my efforts a few years back cleaning out all the ductwork, sealing the connections, and replacing the accurator cables, my heat can cook my feet, and be too hot to leave my hands above the defrost.
I also added sticky insulation tape along the center heat tube, before wrapping the tube with the original vinyl material, I mean it cooks. I should pop a thermometer on it....
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
Zen Bus
Zen Bus is offline
PostPosted: Fri Aug 17, 2018 11:44 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Made a portable control box so I can start and test my engine on my stand.
'79 w/ Sunroof & zBed @ 10:11pm 22 of June 2009 I drove my grandpa's old bus! Thanks to The Samba and all!! 2.0; single weber carb; 78 heads & exhaust, electronic fuel pump.
EricT
EricT is offline
PostPosted: Sat Aug 18, 2018 7:38 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
pulled her engine and ordered a flywheel and seal
JimVeeW
JimVeeW is offline
PostPosted: Sat Aug 18, 2018 2:48 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Bought him some new gauges
bvolks
bvolks is offline
PostPosted: Sun Aug 19, 2018 1:55 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
After owning it for 24 years, I finally made the first cut into it. The inner and middle rockers like they're going to work ok. I have never seen so many patches on top of patches.
1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1971 Doublecab project
1995 Golf CL
1974 Beetle
1978 Westfalia
Spike0180
Spike0180 is offline
PostPosted: Sun Aug 19, 2018 2:41 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
And it worked great for those 24years.
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
notchboy
notchboy is offline
PostPosted: Sun Aug 19, 2018 2:54 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Davydomes
Davydomes is offline
PostPosted: Mon Aug 20, 2018 4:48 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Wow - they look good!
I only went to look at it!
"Mum, Dad ………. I'm Bay"
Patience is bitter, but its fruit is sweet. Jean-Jaques Rousseau
bvolks
bvolks is offline
PostPosted: Wed Aug 22, 2018 6:13 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
It hasn't been on the road since 1982. I don't understand how they beat it up so badly in the 11 years it was on the road.
756,000 km)
1995 Golf CL
1974 Beetle
1978 Westfalia
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Aug 30, 2018 9:45 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Lowered” the Plump Truck yet again! Razz
That’s 1800 pounds of stainless steel to make two standing ovens! Cool
Volswagon
Volswagon is offline
PostPosted: Wed Sep 05, 2018 10:22 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I had enough fabric left over from the front seats to cover the driver's side kick panel.
Turned out pretty well, using 3M spray trim adhesive I bought years ago.
Had to modify the new Tbird header I bought 9 years ago to fit this 1.8L motor. It must have been for a longer stroke 2L.
Pertronix stopped carrying them 5 years ago. I haven't searched for another source. This motor has been a 5 month project.
I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight=
Spike0180
PostPosted: Wed Sep 05, 2018 1:59 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Tuned my engine after having out for maintenance. I had to fix some air intake leaks. I think I may still have a little on the drivers side, but its running and my commute is short.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Sep 05, 2018 2:24 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Had a double header…
My bus? Ball joint boots and kumbucha.
Xevin's bus? Just ball joint boots.
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
andrewtf
andrewtf is offline
PostPosted: Wed Sep 05, 2018 6:30 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I see you had the perfect crescent wrench for the job.
If only you had some gloves as well. Don't want to get those cuticles dirty... do we?
'75 Riviera - 'BIG EMMA' (Pan American highway trip paused for a make over)
'77 Riviera - Murphy' (being reborn.... slowly)
'63 Austin Healey
Abscate
Abscate is offline
PostPosted: Sun Sep 09, 2018 12:09 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Lets keep riding him on those gloves - if someone knows his Mom's Ill amazon her a box of nitriles so she can rag on him too.
Love you Robbie...
.ssS!
mike77777
mike77777 is offline
PostPosted: Tue Sep 11, 2018 2:08 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
The 77 "Fun Van" was taken on a 400 mile maiden voyage ,engine wise, she is hardly a virgin at 94,000 miles. 100 miles north on I5 from Portland. No problem holding 60mph. east on US12 , starting to climb some mountains, Refueled from the can of 110/92 goodness, let the gal cool a bit. Cleaned the windows. had a smoke, took a pic. Monique, my gps voice(British English) is a hoot to keep me company, turns me off US road onto a county road, Bypassing Yakima at an angle. about 40 mile of "Forest Service" unpaved, but maintained in the spring, some really smooth, some paved, then get to a Wa.Route 141, paved, then around30 miles later, slide down Broadway for some pump fuel and a cooldown/undercarriage looky looky. Closed Union 76, pumps would work with plastic. 10 bux got me back in the comfort one. Electric pumps work better with a more full than empty fuel tank. IMO Campsite about 15 miles east on all blacktop, 1/4 mile gravel off that to Camp. 1:30 AM Saturday last. Return south on US 97 10 miles to Biggs Oregon, Pilot Truckstop. Self serve Island, FYI. 95 or so more on I84, north on i205, then Wa.14 to my neighborhood.
patience and putty
TheRealOld59
TheRealOld59 is offline
PostPosted: Wed Sep 12, 2018 9:16 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I took him to gather some apple today
And i finally found an original westfalia middle seat mustard skai
Page 425 of 464
