stevespeirs Samba Member
Joined: June 10, 2008 Posts: 310 Location: Virginia Beach, VA
Posted: Wed Sep 12, 2018 10:08 am Post subject: Re: What did you do for your Bay recently? |
Peeled off all the crappy window tint film from the PO. Still a few sticky patches to clean off, but overall, looking much better! _________________ 1979 Microbus |
ScottWally Samba Member
Posted: Wed Sep 12, 2018 11:43 am Post subject: Re: What did you do for your Bay recently? |
Filled holes after removing green emergency light from cab top.
Used plastic automotive plugs with rubber washers sealed with Gorilla Glue silicon adhesive.
Before:
After
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Sep 19, 2018 7:16 pm Post subject: Re: What did you do for your Bay recently? |
Replacing both intake manifold gaskets (HP gaskets from Aircooled.net)
Also remedied (2) hex bar sleeve bushings with the addition of a single Viton o-ring (each side) on the inboard side of the bushing and wrapped the bushing with several turns of PTFE tape. This effectively eliminated the slight bushing slop I had and should hold up very well given both items used are somewhat resistant to heat.
Now just waiting for parts to arrive for reinstall. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Sven F Samba Member
Joined: July 24, 2009 Posts: 92 Location: Croatia / Denmark
Posted: Thu Sep 20, 2018 1:30 am Post subject: Re: What did you do for your Bay recently? |
Got tired of losing plastic bolt caps on the bumper. Bought some stainless M8 bolts and washers, grinded the markings off and shaped the heads to a slight dome shape, then wetsanded and polished to a high shine.
Stainless is much cheaper than chrome and also won't chip and rust when you use tools, they just don't come shiny out of the box.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Thu Sep 20, 2018 6:48 am Post subject: Re: What did you do for your Bay recently? |
Looks like you got tired of the later bumper too that the bolt caps and bolts go to? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Sven F Samba Member
Posted: Thu Sep 20, 2018 9:42 am Post subject: Re: What did you do for your Bay recently? |
I didn't drill holes in a early bay bumper if that's what it looks like. That's a late, late bumper from a Brasilian bay window. They also use bolts and caps, although not horizontally like that. |
Gashog Samba Member
Posted: Fri Oct 05, 2018 4:46 pm Post subject: Re: What did you do for your Bay recently? |
Servicing the CV jernts on my sweet 72 deluxe. They're the originals, dated 71 and looking pretty good with 180K on them. Have yet to decide on them or a new set… Thank you Mr Tcash for all the informative links. Wouldn't be doing this without them… or my Bentley. |
kevinj73us Samba Member
Joined: September 25, 2011 Posts: 228 Location: Laurel, MD
Posted: Sat Oct 13, 2018 10:20 am Post subject: Re: What did you do for your Bay recently? |
Installed a new (reman) transmission from Mr. Gas.
So much quieter driving now instead of the 45 year old howler that I replaced. Looking forward to actually talking to people when they ride with me.
kj _________________ 1973 Station Wagon
m-plate |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Mon Oct 15, 2018 9:43 am Post subject: Re: What did you do to your Bay recently? |
Sometimes I get my words mixed up, but here is my latest post for the "What did you do to your Bay recently?" thread.
My ignition switch had stopped springing the key back from the start position, so it's time to replace it. I'm ready to start the job.
I found the set screw!
The old switch came out easy enough, but I struggled a bit getting the new one back in. As I tried to move the turn signal wire bundle around, I realized my wiring was not offering much slack.
My fuse block had one of the mounting points broken off when I bought it in the 90's. Since that seems like an important part to have in working order, I got right on it and ordered a new one this week.
Knowing a new fuse block was coming, and following the age old wisdom, "If something aint broken, fix it anyway," I decided to go ahead and disconnect everything.
This is how I left things last night. Every wire identified and labeled.
New fuse box arrives on Wednesday. _________________ ~Kevin
My 1968 Campmobile |
Posted: Mon Oct 15, 2018 10:10 am Post subject: Re: What did you do for your Bay recently? |
Dahm, it took you longer to label then to disconnect
I just took a pic - several of them for when I put mine back. _________________
t3kg wrote: |
1964 1500 S
Posted: Mon Oct 15, 2018 11:53 am Post subject: Re: What did you do for your Bay recently? |
notchboy wrote: |
I just took a pic - several of them for when I put mine back. |
I took several photos to reference as well.
I couldn't get the dash cluster out without disconnecting wires from the back first. I used the photos to identify which ones went where after I removed the dash cluster. It did take a little time to label all the wires, but I feel it was worthwhile. After I clean up all the connectors, everything will go back together easily.
I had other motivation as well. I am putting in an electric washer pump, so I needed to pull that switch as well.
While it's all apart I can also clean everything up. The switches looked a lot worse when I first pulled them out. I'll clean and lube everything before reinstalling.
Of course while I am sitting there working on this, I keep eye balling that wiper assembly. It looks like it could use a little TLC as well. I have Colin's thread bookmarked already. Maybe while I'm under here I can also get a spray can of Pearl White and touch up some spots. _________________ ~Kevin
Posted: Sat Oct 20, 2018 10:03 am Post subject: Re: What did you do for your Bay recently? |
Waiting on some bits and pieces to be delivered. Might as well install the VDO Quartz clock I snagged on the classifieds.
HoboBus Samba Member
Joined: December 29, 2016 Posts: 347 Location: Massachusetts
Posted: Sat Oct 20, 2018 6:38 pm Post subject: Re: What did you do for your Bay recently? |
Passed yearly inspection today, got my new inspection sticker, and took my girl out for BBQ tonight in the Bus!!
Was a good day.
Hobobus.
_________________ Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus. |
Angus II Samba Member
Joined: June 01, 2016 Posts: 707 Location: Mammoth Lakes Ca. 93546
Posted: Sun Oct 21, 2018 10:35 am Post subject: Re: What did you do for your Bay recently? |
Hello,
I put the luggage rack and pop top back on the bus. By myself, where's all the help when you need it?.
Now, Gus the bus looks like a real campmobile not a tin top...
I may have to go for a fall colors drive today. It's so nice up here this time of year, with all the colors changing. Also, the lack of tourist...
Too bad, Gus has to get put away for the winter soon. |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Wed Oct 24, 2018 8:47 pm Post subject: Re: What did you do for your Bay recently? |
Truck Army working. Helping me paint the house.
_________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Fri Oct 26, 2018 7:20 am Post subject: Re: What did you do for your Bay recently? |
Hit a new max speed of 84MPH, didn't take picture proof... because that's dangerous. I had pedal left, I think ima go for 90. That'd be faster than my 97 ranger lol _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Zambia Samba Member
Joined: December 15, 2009 Posts: 56 Location: Southern Pines, NC
Posted: Sun Oct 28, 2018 5:37 pm Post subject: Re: What did you do for your Bay recently? |
Did a generator to alternator conversion on my 69 deluxe bus. Overall easy. Had some issues with alternator not sitting all the way back on the alternator stand. Pulled out my grinder and fixed that problem. Didn't know that you had to run your motor to over 1000rpm to get the generator light to go off. I checked my wiring twice until a buddy let me in on that little secret!
Posted: Mon Nov 12, 2018 5:28 pm Post subject: Re: What did you do for your Bay recently? |
As part of the sliding door hinge refresh, replaced the crusty old beading from behind the sliding door rail cover. Turned out pretty good.
Part # 281 843 799 from BusDepot.com
http://www.busdepot.com/281843799
Posted: Mon Nov 12, 2018 5:39 pm Post subject: Re: What did you do for your Bay recently? |
Door is sliding along nicely too!
