What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 451, 452, 453 ... 462, 463, 464  Next
cartoonmonkey
cartoonmonkey is offline
PostPosted: Mon Oct 19, 2020 1:53 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Ernie that is crazy man. I can't wait to see what you do with er!
Shout out from the Pacific Northwest.
Fozzy
Fozzy is offline
PostPosted: Tue Oct 20, 2020 5:10 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Bumper ectomy.. Removed, banged out most of the dents, filled, sanded and painted them white.. probably too white, but they look OK for not having any idea what I was doing. They are on, but not tight, the front is crooked and I haven't worked on them much to get them perfect..
65 Sedan..
Adopted 07/15/17
this is the bug I've been looking for..
71 Tin Top Westy
Adopted Dec or so 2017
Chorro
Chorro is offline
PostPosted: Wed Nov 04, 2020 6:56 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Been cruising lots, we put on about 1500 miles this month. fixed up the original westfalia rack and scored a realyy cool light bar with neat old fog lights. Me and kids went and picked up some straw bales, used the old rack. Loving our little 68
kruno
kruno is offline
PostPosted: Sat Nov 07, 2020 5:10 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
'58 bug
'54 barndoor
'79 bay window
'05 renault modus Smile a little gallic gay car
toXic rust
mike77777
mike77777 is offline
PostPosted: Sat Nov 14, 2020 1:39 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
been parked 2 months, started her up and drove around a little. Very Happy
patience and putty
Cuccuzze
Cuccuzze is offline
PostPosted: Sat Nov 14, 2020 6:16 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Just about dont getting the walls in. . All the walls are lined with soundproofing adhesive panels, insulated, sealed and covered with soundproofing foam. Then made the holes to secure the clips. I put the spare in today, and the cover I sewed 2 years ago!
When I laid the floor, i followed dimensions I found online, sadly, it is slightly short. Not horrible... once the captain chair and table are in, I can trim the gap between the floor and wall.
1971 VW westy
My generation made girls take home ec and sewing. I really wished they let us learned cars!
Cuccuzze
Cuccuzze is offline
PostPosted: Sat Nov 14, 2020 6:18 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
The bumper and steps look great. What did you do to make the black rubber step really black and shiny? Did you replace them? How do they adhere?
1971 VW westy
Fozzy
Fozzy is offline
PostPosted: Mon Nov 16, 2020 7:57 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
They are new. they are secured using the steps themselves, they have tabs and pins that pop into the original holes in the metal (pics hopefully show them
65 Sedan..
Adopted 07/15/17
71 Tin Top Westy
Cuccuzze
Cuccuzze is offline
PostPosted: Mon Nov 16, 2020 9:22 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Got it.. so you probably has to pry the old one off, sand, paint, and snap the new ones on. I'll try this! They look really nice!
1971 VW westy
Fozzy
Fozzy is offline
PostPosted: Mon Nov 16, 2020 8:26 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Mine were the originals and not really pliable anymore.. so they did kind of "pop" off.. the new ones were nice and pliable and with some duckbill pliers pulled into place nicely. The other thing you have to get that I had a lot of problem fitting were the "seals" that go between the bumper and the bumper ends... I will end up redoing them because I don't like the ones I got. I did find the ones I want to get though
I ordered new hardware kits for front and back, and splash pan seals for the rear.. I put a new corner on my passenger side, and the hole for the splash pan bolt is a bit off..
65 Sedan..
Adopted 07/15/17
71 Tin Top Westy
Cuccuzze
Cuccuzze is offline
PostPosted: Mon Nov 16, 2020 9:24 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
So where do I get those bumper ends? The numnuts that painted my bus never took them off and sprayed them over... so I guess I will have to grind them out.
What is a splash pan? I have two small holes over the rear wheel hump, is that the hole youre talkin about?
[/quote][/quote]Mine were the originals and not really pliable anymore.. so they did kind of "pop" off.. the new ones were nice and pliable and with some duckbill pliers pulled into place nicely. The other thing you have to get that I had a lot of problem fitting were the "seals" that go between the bumper and the bumper ends... I will end up redoing them because I don't like the ones I got. I did find the ones I want to get though
I ordered new hardware kits for front and back, and splash pan seals for the rear.. I put a new corner on my passenger side, and the hole for the splash pan bolt is a bit off..[/quote]
1971 VW westy
HoboBus
HoboBus is offline
PostPosted: Tue Nov 17, 2020 9:56 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Finally cleaned up the garage enough to get HoboBus inside for the winter.
We have a garage-under, so the roof rack had to come off. Rolling Eyes Even with that, it just barely slides in under the garage door trim.
But at least the Bus is out of the weather for the winter.
Cool Razz Very Happy
Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus.
danfromsyr
danfromsyr is offline
PostPosted: Tue Nov 17, 2020 11:11 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
your garage door can be adjusted to go up a few more inches.
I'd recommend that it's usually a fairly easy task of turning the adjust screw a couple turns.
it will not effect the door going all the way down.
HoboBus
HoboBus is offline
PostPosted: Tue Nov 17, 2020 1:31 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Thanks Dan! Sadly it's not the door that limits it - it's actually the trim on the framing of the opening. Rolling Eyes Hard to see but this pic might show it better if you zoom in.
The trim is only 6'4" from the floor. (It's only a 9ft x 6.5 ft door.) The Bus just skims by. At least I don't have to deflate the tires. Confused Laughing
scubasteve321
scubasteve321 is offline
PostPosted: Mon Nov 30, 2020 10:36 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Among many other projects prepping bus for an extended journey South;
Cedar kick and door panels
1971 Campmobile Tin-Top
1971 Campmobile Pop-Top
1974 VW Bus
Jb916
Jb916 is offline
PostPosted: Thu Jan 07, 2021 4:07 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Just scored this 79 bus this past summer for my wife's essential oil business. I got her the grille for her birthday in November, then got it powder coated for christmas. I finally got around to installing the grille and running some LED lights behind it so you can read the words in the grille!
Powder coated
Installed
58 ragtop bug / 68 bay window photo booth bus / 70 bay window tin top westy / 71 bay window photo booth bus / 79 bay window California bus
NorCalWeekender
NorCalWeekender is offline
PostPosted: Thu Jan 07, 2021 8:01 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I've been doing lots of little pandemic projects to just escape from being at home and working all day, but last week I finally got my slider cover off (screws were pretty stuck and rounded out) because I'd planned to replace the nylon block.
While it also gave me a good opportunity to clean up the area under there, something definitely didn't look right with my roller unit.
Yeahhhhh, that really broke at some point in its past. Thankfully, a friend in Idaho has one that he's sending down for free. So I should be able to get it swapped out this weekend.
9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995
Fozzy
Fozzy is offline
PostPosted: Sat Jan 16, 2021 8:54 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Cleaned the (already removed) front doors, new rubber (not the best) and new door cards from TMI.. New hardware and rubber "seats" and new clips.. had to drill the holes a bit bigger but it made the job easier. I used a heavy weight shower curtain for the vapor barrier (cheap) Overall, pretty happy with the results
65 Sedan..
Adopted 07/15/17
71 Tin Top Westy
Charlie57
Charlie57 is offline
PostPosted: Fri Jan 22, 2021 4:20 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I have been working on my dash. I repaired some holes and painted it with vinyl spray paint. I think it turned out pretty good. I am far from ready to put it back in. My goal is to check all the gauges and lights before it does go back in. Someone at one point added the battery gauge which I plan to leave.
Charlie
NorCalWeekender
PostPosted: Fri Jan 22, 2021 8:44 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Charlie
Wow. That looks good!
Page 452 of 464
