tburton100 Samba Member
Posted: Fri Oct 08, 2021 8:09 am Post subject: Re: What did you do for your Bay recently? |
Old motor was a 1300 and totally knackered so have had it replaced with a refurb 1641, so much better already.
Whilst it was at the garage, new dual heating gas/240v system plus updating the electrical system with split charge and hook-up.
First camping trip booked to give it all a try now.. |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Tue Oct 12, 2021 9:55 pm Post subject: Re: What did you do for your Bay recently? |
I ordered one of Jeremy's tow bars _________________ ~Kevin
My 1968 Campmobile |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33820 Location: Conejo Valley, CA
Posted: Sun Oct 17, 2021 2:53 pm Post subject: Re: What did you do for your Bay recently? |
Simple stuff, but satisfying.
On my new (to me) '69 Westy, I did a little engine work. Last weekend was valve adjustment and tuneup. This weekend I replaced the non-German 009 with a proper rebuilt SVDA unit, and it is already running better. When I figure out how to replace the missing/cut off mount, I'll put back in the original style air cleaner. The pleated paper cone-shaped unit on it is dirty.
Replaced the rusty and gutted pea shooters with nice SS units. Quieter and of course they look much nicer!
Got rid of the plastic fuel filler and replaced the fuel line from pump to carb.
One of these days I'll get to the tank to replace that line. Any tips on making that easier? |
Charlie57 Samba Member
Joined: July 29, 2012 Posts: 140 Location: Lebanon, TN
Posted: Wed Nov 03, 2021 10:13 am Post subject: Re: What did you do for your Bay recently? |
I started installing a new wiring kit. It's been a long time since I have worked on my 1978. Does anyone happen to have photos of a clean installation, I still have a long way to go and it already looks like a rat's nest!
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 905 Location: SouthEast
Posted: Sun Nov 28, 2021 5:34 pm Post subject: Re: What did you do for your Bay recently? |
Random orbital Menzerna 400 > Menzerna 2500 > Jesco Powerlock
Angus II Samba Member
Joined: June 01, 2016 Posts: 706 Location: Mammoth Lakes Ca. 93546
Posted: Sun Nov 28, 2021 6:46 pm Post subject: Re: What did you do for your Bay recently? |
Hello,
Ralph, Passat 15" wheels?. or others?... That looks good. |
Posted: Mon Nov 29, 2021 5:45 am Post subject: Re: What did you do for your Bay recently? |
Angus II wrote: |
Hello,
No those are stock wheels. |
scubasteve321 Samba Member
Posted: Sun Jan 02, 2022 2:46 pm Post subject: Re: What did you do for your Bay recently? |
KTPhil wrote: |
Drain tank first to make your life easier; remember, it's a 14 gallon tank, so run till 1/4 or less then drain into 5 gallon bucket to be sure _________________ 1971 Campmobile Tin-Top
1971 Campmobile Pop-Top
1974 VW Bus |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Tue Jan 04, 2022 12:48 pm Post subject: Re: What did you do for your Bay recently? |
Received my pair of the discontinued Cibie 7" H4 headlamps which were still in the supply chain. Apparently Valeo didn't keep up the tooling and it slid below QA standards, and was discontinued. (Also got a pair of German Flösser brand H4 bulbs.)
Get them while they still have them. It is a screaming good price, and after this, there's no more. I found them by accident at classicgarage.com.
Note: These are E2 European lenses which take replaceable H4 lamps and are legal in Europe and Canada, but *technically* not legal in the USA because they are not DOT approved. If someone is squinting at your headlights looking for the compliance mark, you're pretty much already screwed.
_________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .81 4th
Click to view image |
Posted: Tue Jan 04, 2022 4:51 pm Post subject: Re: What did you do for your Bay recently? |
Hello,
I just received a new pair of Cibie #082440s. For, $75 shipped for the pair from a private seller. All, I need is the correct high/low beam bulbs. I should have bought the Toyota kit for less and are plug & play. But, I don't like the ideal of Jap/china parts on my survivor 71 pop top... How much were yours from classicgarage.com with shipping. If, you don't mind me asking.
I bought these after reading The H4 upgrade thread...SGKent gave them a good review in his opinion. And, they're from Europe for an European made bus. A plus too me. |
Posted: Tue Jan 04, 2022 7:08 pm Post subject: Re: What did you do for your Bay recently? |
Angus II wrote: |
Hello,
I just received a new pair of Cibie #082440s. How much were yours from classicgarage.com with shipping. If, you don't mind me asking.
$141 total, which was lenses, two 55w/60w H4 German Flosser bulbs, tax, and shipping.
I bought the Cibies for the classic curved shape, but the Japanese Koito lenses are demonstrably better at the job. I just don't care for the flat lenses.
Don't let perfect be the enemy of "better": Any H4 bulb from a reputable manufacturer will give you good service, and much better than you will get from a sealed beam.
I also plan to add dual relays so the light switch only has to power the relays instead of both bulbs straight through the switch. There are plenty of good relay kits that only require you to add 12ft of 14AWG stranded copper to the positive terminal on the starter and the kit, and you're rolling with a dedicated power tap just for your H4 bulbs. Lotsa more light.
webwalker _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
Posted: Tue Jan 04, 2022 7:46 pm Post subject: Re: What did you do for your Bay recently? |
Hello, WebWalker
Thanks for the info. Mostly, the relays upgrade trick for more juice to/for the headlights via the relays saving the switch some wear and tear. |
static Samba Member
Joined: March 22, 2002 Posts: 1830 Location: The High Desert
Posted: Fri Jan 14, 2022 4:13 pm Post subject: Re: What did you do for your Bay recently? |
Got rid of my ugly, rusting, oxidizing, 52-year-old Westfalia shelf support and replaced it with a snazzy stainless steel one from NLAVW.
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Fri Jan 14, 2022 5:33 pm Post subject: Re: What did you do for your Bay recently? |
Shiny! _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
bummerbus Samba Member
Joined: April 12, 2009 Posts: 64 Location: Portland, OR
Posted: Tue Jan 18, 2022 4:12 pm Post subject: Re: What did you do for your Bay recently? |
After buying a house and moving my bus has been feeling generally neglected lately. But I did just have these stainless steel shore power electrical faceplates made up to modernize the interior and add some usb charging to the back.
Disregard my greasy finger prints!
_________________ ‘75 FI-1800cc. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22403 Location: Escondido CA
Posted: Tue Jan 18, 2022 7:55 pm Post subject: Re: What did you do for your Bay recently? |
Thanks Notchboy! I find it’s the little projects that keep me motivated on this thing these days. _________________ ‘75 FI-1800cc. |
wildDogPizza Samba Member
Joined: March 15, 2017 Posts: 81 Location: Southern Orange County, CA
Posted: Tue Feb 08, 2022 6:23 pm Post subject: Re: What did you do for your Bay recently? |
I installed a bluetooth receiver and an amp. I created a bracket out of sheet metal to mount everything without drilling any holes. It mounts to the 2 bolts that hold the bracket for the parking brake to the ventilation tube at the bottom and the bolt that holds the heater controls at the top.
I had to clearance the bottom a bit more to clear the parking brake hitting it after this.
_________________ "Sliced Bread" 68–73 Bus Part Finder |
Posted: Tue Feb 08, 2022 6:54 pm Post subject: Re: What did you do for your Bay recently? |
Looks good! _________________ 9th Owner of a 1971 Tintop Westy
j10nbom Samba Member
Joined: February 14, 2007 Posts: 262 Location: Philly
Posted: Fri Mar 04, 2022 8:51 am Post subject: Re: What did you do for your Bay recently? |
Threw on some MB hubcaps.
