jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Mon May 23, 2011 12:10 am Post subject: |
fluxcap wrote: |
It would not cut off when I stalled the car. I could hear it clicking as if it were trying to cut off, but it would just keep on running.
This was my experience as well. I installed the relay just as instructed. It acted like there was some kind of residual current still feeding the elec. fuel pump after the engine stopped running.
It eventually did cut off, but sometimes after a full 15 or 20 seconds.
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue May 24, 2011 3:51 am Post subject: |
When I had an electric fuel pump for my supercharger setup I used a Bosch EFI fuel pump relay like the Rabbit/Golf one but from an Aussie made GM car.
It had a couple of extra terminals than the VW one but the good thing about it was it self primed.
When you first turned the ignition on it would run the pump for 1-2 seconds then stop it till it got a signal from the tach.
so if the car sat and the fuel bowls were dry turning the ignition on and off again a few times soon filled the bowls back up. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Tue May 24, 2011 4:28 am Post subject: |
Yep, that's how the one from revolution electronics works as well. Turn the key on and it pumps for a few seconds then stops until you crank the car.
Jzjames, if my first relay would have cut off after about 15 seconds, I'd probably lived with that, but I once tested it to see how long it would keep going and finally had to just turn the key off after 3 minutes!!! _________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
canvmnvw Samba Member
Posted: Wed May 25, 2011 8:09 pm Post subject: |
so are you guys saying that the German Rabit relay shown in this thread and wired as shown does not work properly or are you saying that the problems you had was with cheaper ebay versions out there. I've seen rabbit relays as low as 3.98 on the web. you're obviously gonna get what you pay for. I was going to go the rabbit relay (nice german one) with the pre-prime switch, but if there is a problem with this set-up, perhaps I'll look at the RE12003 set-up again, but at 70.00, it's a bit steep compared to the rabbit set-up. Anyone set one up as described in this thread with success? |
Posted: Thu May 26, 2011 1:49 am Post subject: |
The one I got was the one with the integrated fuse on top mentioned earlier in this thread. It was NOT made in Germany. I think it said it was made in Hungry. It was $25.
edit: I must have been hungry when typing this. I meant Hungary obviously _________________ Eric - 1966 camper bus
Posted: Thu May 26, 2011 7:37 am Post subject: |
huh that's a chuck of change for something that didn't work
I'm thinking of biteing the bullet for the RE 12003 kit. It appears that you guys have had good results with that one. and really if I add up a good german relay, socket, prime switch, wiring and connectors.... it's probably gonna come out close to the RE12003 kit (without it turning into a science project under my hood.)
Thanks for the info... |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Wed Jul 25, 2012 7:29 am Post subject: |
1961bluebug wrote: |
Glenn wrote: |
Use a Rabbit FI relay. It powers the pump when you're cranking the engine and shuts the pump off when the engine stops. No need for a push button.
just to let you all know..there is pretty neat relay of this partnumber for sale on E*bay, new, with integrated slot for a fuse.
Where do I add a manual override button to this relay circuit? I want to be able to prime my carbs before I start cranking the engine. Between 15 and 87 or between 30 and 87? |
With this kind of relay and an electrical pump, no manual override is necessary.
An electric pump can fill one or two carburetors in only a few seconds, so as you turn on ignition switch carburetor is already filled with fuel. |
Buck Naked Samba Member
Joined: March 11, 2009 Posts: 400 Location: El Dorado County,CA
Posted: Wed Jul 25, 2012 2:59 pm Post subject: |
I use the Rabbit FI relay referenced in this thread. Had friend who is a VW tech at the dealer order it from their supplier. Works flawlessly, no prime switch needed; car does not sit usually more than week if that offers any useable info.
Shane _________________ Be unique, like everyone else.
'63 Beetle Ragtop |
Nevada Notch Samba Member
Joined: May 02, 2005 Posts: 540 Location: Carson City Nevada
Posted: Wed Sep 19, 2012 9:31 pm Post subject: Re: Proper electric fuel pump wiring |
mailman wrote: |
Can someone please help me understand this wiring diagram that I found on the Samba? Thanks to whomever posted the diagram....
I understand the need for the relay; to cut power to the pump in the event the engine dies.
I understand the need (desireability) of the push button over-ride switch; to be able to fill the carb bowl(s) without starting the engine.
What is confusing me is the use of the gen/alt light to trip the relay. I would have thought you would use the oil pressure light. I'm presuming that the pump should be fed power through the relay when the gen/alt light is off (engine running). But, looking at the wiring diagram, it looks like the other way around....that the pump relay would get power when the light is on. What am I not getting, here?
Also, one more thing. What happens if the push button switch is pressed (feeding 12 volts directly to the pump) when the pump is already getting 12 volts supplied through the relay (while engine is running)? Not the normal situation, but it could happen by accident, right?
I'm notoriously bad at posting pictures....but here goes....
Just an update here, I just installed a fuel pump with bone dry carbs using the schematic and relay pictured here.
Priming the carbs is very easy. You do not need to put a button in, all you need to do is run a quick temporary jumper wire (alligator clip) to terminal 87 then touch the other lead to a hot point on the fuse block. Let her run for about 15 seconds and you're good to go! _________________ 1966 Euro
1600DP
Dual 34mm ICT's
99% Resto-Custom Daily Driver |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Wed Sep 19, 2012 9:50 pm Post subject: VW/Audi Relay |
I picked up this VW/Audi relay to run with my Carter 3.5 PSI fuel pump. It has the fuse slot and cost $35 (apologies for my poor camera work). 3.300.100 is the KAE part#:
_________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Bigg Tim Samba Member
Joined: February 26, 2008 Posts: 47 Location: Phoenix, AZ
Posted: Tue Oct 15, 2019 9:20 pm Post subject: Re: Proper electric fuel pump wiring |
Does anyone have the picture Glenn posted that is no longer available? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76908 Location: Sneaking up behind you
Posted: Wed Oct 16, 2019 5:23 am Post subject: Re: Proper electric fuel pump wiring |
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Oct 16, 2019 2:17 pm Post subject: Re: Proper electric fuel pump wiring |
Fantastic! Thank you very much.
I found this other pic and it has pin 87 and 30 swapped. Does this actually matter? Also, the relay I have has a 15amp fuse on the top. Does this eliminate the need for an online fuse on the battery + wire?
j10nbom Samba Member
Joined: February 14, 2007 Posts: 262 Location: Philly
Posted: Thu Jul 21, 2022 9:06 am Post subject: Re: Proper electric fuel pump wiring |
Bigg Tim wrote: |
Bumping an old thread...
Can terminal 15 go to the positive side of the coil for "switched +12V"?
What about using B+ on an alternator for terminal 30 as the "constant +12V"? |
60 vert Samba Member
Joined: October 21, 2002 Posts: 10 Location: Salt Lake City, UT
Posted: Sun Jan 29, 2023 5:54 pm Post subject: Re: Proper electric fuel pump wiring |
I too am bumping this old thread. I did this install this week using a 12v, 4-pin, Bosch style, 30-amp fused relay. Everything worked except now, my Alt light stays on with the car running.
I am now trying to resolve this issue.
If it was working properly, I think it should be causing a condition where the voltage is equal on both sides of the lamp, so it goes out (equal voltage on both sides of lamp equals a no current flow situation through lamp filament).
For some reason I have a voltage difference across the Alt filament, and it stays lit up with the bug running.
The only thing I could think of was it might have something to do with different size wire gauges, but even this doesn't entirely make sense to me. Using a multimeter, I measured ~14.2 v on the ignition side and only 8.2 v on the opposite side of the Alt filament.
Any ideas? |
Glenn Mr. 010
Posted: Sun Jan 29, 2023 6:05 pm Post subject: Re: Proper electric fuel pump wiring |
j10nbom wrote: |
Remember that the positive side of the terminal goes through the ignition switch. The more power you draw through it the switch the more chance it will eventually fail.
The switch and wire are only rated for a specified amperage.
BTW.. electric fuel pumps are pushers and should be mounted under the tank. Easy access to the fuse panel. If you have a tach then you can use that wire for 31b. _________________ Glenn
Member #1009
#BlueSquare |
