TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Wed Mar 05, 2008 3:39 pm Post subject: average price a shop would charge to install drop spindles.. |
got a 54, cant really find time to install some link pin drum drop spindles... what should i expect to pay for labor on these?
Thanks guys. |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Wed Mar 05, 2008 4:26 pm Post subject: |
Its about a 3 hr job,so whatever the shop rate is x 3hrs. _________________ die schwarzen Schafe #666 |
my03yellowv Samba Member
Posted: Wed Mar 05, 2008 4:50 pm Post subject: |
Don't most shops charge about $90 an hour rate? |
Alan Willis Banned
Posted: Wed Mar 05, 2008 4:52 pm Post subject: |
Yep _________________ die schwarzen Schafe #666 |
Posted: Wed Mar 05, 2008 5:27 pm Post subject: |
im sure they will do a flat rate, whos going to pay 300 bux to install drop spindles.... |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Mar 05, 2008 8:13 pm Post subject: |
Yes, you are probably right, they will do flat rate. 3 hours at $90 a flat rate hour. Does that sound like a better deal?
If thats too expensive for you, then maybe you need to rearrange your schedual to fit in the 3 hours to do it your self.
By the time you drop off the parts or the car and have someone else drag you home and then go pick it up, you probably lost 4 hours dealing with it.
It's your car, get to know it better and get in there and bleed a little!
Of course if you are just using the time thing as an excuse to not have to admit you have no tools, money or skills...... _________________ Mother Nature is a Mean Evil Bitch! |
Migit Banned
Joined: July 09, 2004 Posts: 831 Location: Central Illinois
Posted: Thu Mar 06, 2008 6:06 am Post subject: |
That is $90 an hour PLUS the Front end alignment PLUS balancing your tires so for a 3 hour job you can do yourself $500 will probably be closer to the truth. _________________ Looking for a 58 euro hardtop! |
markm Samba Member
Joined: July 21, 2003 Posts: 986 Location: Seattle, Via Beautiful El Sereno CA.
Posted: Thu Mar 06, 2008 10:22 am Post subject: |
Migit wrote: |
That is $90 an hour PLUS the Front end alignment PLUS balancing your tires so for a 3 hour job you can do yourself $500 will probably be closer to the truth. |
Why would you need to balance the tires to put in dropped spindles? |
Kombi Samba Member
Joined: August 02, 2002 Posts: 562 Location: Edmonton, AB, Canada
Posted: Thu Mar 06, 2008 10:29 am Post subject: |
markm wrote: |
Migit wrote: |
I think an assumption was made that he wouldn't be running the same tires with drop spindles... Otherwise no wheel balancing would not be required.
Local market will dictate shop rate Mechanical shops around here are $115/hr
Some independants might give you a break but... $500 for a proper install sounds about right. _________________ Air and Water are needed to survive,
you just can't live as long without air!
Air Riders, VW Club |
KILLERWATT Samba Member
Joined: November 18, 2003 Posts: 3298 Location: Vero Beach
Posted: Thu Mar 06, 2008 11:05 am Post subject: |
Are the spindles already built? Or do they need to be honed, bushed, with the king and links installed with a press. Just to build the spindles in my neck of the woods is around $200.
Also consider that you might need new tie rod ends, bearings and you have to shim for proper front wheel camber. Depending how low you go you might want to do the flip kit for bump steer. |
FRK Samba Member
Joined: December 09, 2002 Posts: 2652 Location: Orange county, CA
rockettdoggie Samba Member
Posted: Sat Mar 08, 2008 10:38 pm Post subject: Do it yourself |
Just dig in and do it yourself. By the time you read this thread for 2 hours you could be almost done and doing the ghetto alignment.
Who balances tires that go 60 mph? _________________ 57 Oval |
Mr. Bungle Samba Member
Joined: December 11, 2003 Posts: 1705 Location: Vancouver BC, Canada
Posted: Sun Mar 09, 2008 12:08 am Post subject: Re: Do it yourself |
rockettdoggie wrote: |
Who balances tires that go 60 mph? |
anyone with half a brain.
for safety, proper tracking, steering, handling, elongated tire life and comfort. _________________ Silas
Zundfolge Car Club
Stock Motor Challenge website |
