Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Mar 06, 2008 9:31 pm Post subject: Need some info - thex portion of the gland nut |
What is the thickness of the hex portion of the gland nut for a T-3 automatic??? I have some T-1's, but they are thinner. They are 6mm.
I need the dimension, so I can make some more. I sold my last one and have lost my notes that had the dimensions. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
timsvw Samba Member
Posted: Thu Mar 06, 2008 10:01 pm Post subject: Re: Need some info |
Russ Wolfe wrote: |
What is the thickness of the hex portion of the gland nut for a T-3 automatic??? I have some T-1's, but they are thinner. They are 6mm. |
If you can't get the info somewhere else, the ISPWest website says they have them in stock. They might give you the dimension if you called. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Mar 07, 2008 7:59 am Post subject: |
8mm plus? |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Fri Mar 07, 2008 9:16 am Post subject: |
Is this the measurement you're looking for?
From this nut:
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
timsvw Samba Member
Posted: Fri Mar 07, 2008 10:35 am Post subject: |
notchback wrote: |
THAT"S what I call service |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Fri Mar 07, 2008 10:51 am Post subject: |
I still kick myself. I had a motor from an automatic that I pulled the torque converter, flex plate, flex plate bolts, and special gland nut – and threw it all away! Oh, to be young and dumb...
Energy is truly wasted on the youth. _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Fri Mar 07, 2008 4:26 pm Post subject: |
Yes, that is it Neil. Thanks. I got a couple made. and the dimension is written on the wall.
In case I loose my notes again. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
