grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Fri Mar 07, 2008 6:48 pm Post subject: stock FI questions |
so i just picked up a late square... floors are totaled... but it have some usable parts for my fasty, like the front clip is in good shape, the fenders are great etc...
also it has all the factory FI on it,
also it appears to have stock AC.
i dont know crap about type 3s really im just learning, but i want to put the stock FI back into my fastback.
i know carbs pretty good, but im a dummy when it comes to FI.
the motor was "supposed to run" when it was parked a few years ago.
i could care less about that i just want the FI crap from it.. since i dont have a bently yet, i have a few questions..
where is the FI controller located, and what parts should i try to salvage fron that systems fi setup and what should i just replace with new?
edit: i just noticed TRAMS sticky, i guess ill start reading that and see if i find anything useful in it. _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri Mar 07, 2008 6:52 pm Post subject: Re: stock FI questions |
grimace007 wrote: |
where is the FI controller located |
the FI ECU is in the side panel on the driver's side, above the engine bay... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Fri Mar 07, 2008 7:04 pm Post subject: |
thanks =)
im ony page 6 of the sticky.. lol i think its gunna take me a few days _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
cr@M wrote: |
LesTroyer Samba Member
Joined: March 20, 2007 Posts: 536 Location: Sammamish, WA
Posted: Fri Mar 07, 2008 7:10 pm Post subject: |
To me the hardest part about understanding FI is that to go faster, you add more air, to increase idle speed you add more air.....
Just look at the throttle cable -- it hooks up to a butterfly that -- you guessed it -- controls the air to the engine. The computer will try and adjust the duration of the gas pulse to match the amount of air going to the engine, as it "sees" the throttle opening up it will add a little extra gas, but I think that is the exception...
This explains why vacuum leaks are so bad -- it fools the system on how much air is going to the engine....
LEs _________________ Thanks
Les
1972 Fasty -- more or less stock (1600, FI...)
1971 Square
1966 Fasty body on IRS pan -- |
Posted: Fri Mar 07, 2008 8:54 pm Post subject: |
cool that puts it in a way easy to understand _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
cr@M wrote: |
paulie walnuts Samba Member
Joined: February 07, 2004 Posts: 193 Location: Portland Oregon
Posted: Sat Mar 08, 2008 9:56 am Post subject: |
Quote: |
To me the hardest part about understanding FI is that to go faster, you add more air, to increase idle speed you add more air..... |
indeed funny for FI. however this is pretty much what all internal combustion engines are - just air pumps with a little sweet hit of flammable hooch at the right moment to make it burn with all that air. hence - liters displacement of an engine is bore diameter x stroke x # of cylinders is actually just saying how much volume of air those cylinders will hold. _________________ Paulie Walnuts
69 All Stock Squareback
2001 Audi Allroad 2.7T
+ Chevy work truck.
wish list: late 60's early 70's 911 E or T |
wuzmop Samba Member
Joined: July 24, 2002 Posts: 339 Location: Garland, TX
Posted: Mon Mar 10, 2008 6:08 am Post subject: |
Brian, I know a whole lot about T3 EFI. I can help you out with it. If you want to stop by one day I can give you a crash course on my 69. _________________ Robb
67 Bus
66 Bug o' Turd
71 Bus
91 Cabby
www.aircoolers.org |
Posted: Mon Mar 10, 2008 9:06 am Post subject: |
SWEET, hows this weekend sound bro?
sunday good for you? _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
cr@M wrote: |
wuzmop Samba Member
Posted: Mon Mar 10, 2008 9:35 am Post subject: |
That should work. _________________ Robb
67 Bus
66 Bug o' Turd
71 Bus
91 Cabby
Posted: Mon Mar 10, 2008 10:21 am Post subject: |
pm me yer # and adress man _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
cr@M wrote: |
