Useing alternative rear disc brakes
Page: Previous  1, 2, 3
manxmark
manxmark is offline
PostPosted: Tue Jan 12, 2010 6:15 pm    Post subject: Reply with quote
Much like pulling on the hand brake do you mean?
I have heard of a guy that has that setup (he's in Queensland on the other side of the country). I've often wondered how well it worked for him. Maybe not that good.
If I go for the discs it sounds like it would need to be 4 wheel discs with a Porsche master cylinder.
Gerrelt
Gerrelt is offline
PostPosted: Sat Jan 23, 2010 9:39 am    Post subject: Reply with quote
I've test-fitted a caliper:
But I discovered I have to change my (custom) exhaust. The caliper is hitting the (motorcycle) muffler..
More details here: link to new addition
homepage
dune limo
dune limo is offline
PostPosted: Sat Jan 23, 2010 5:54 pm    Post subject: Reply with quote
If your twin 19 mm master cylinder is working fine that is all you need for 4 wheel disc brakes--if it needs replaceing get the 20.6 MC you get a better peddle feel
manxmark
manxmark is offline
PostPosted: Sat Jan 23, 2010 6:24 pm    Post subject: Reply with quote
I would have thought that the standard disc / drum master cylinder would have been no good as the drum part of the master cylinder would have a built in residual pressure valve. If this was used with rear discs wouldn't the rear brakes drag all of the time?
Turtletime
Turtletime is offline
PostPosted: Sat Jan 23, 2010 6:59 pm    Post subject: Reply with quote
didget69
didget69 is offline
PostPosted: Sat Jan 23, 2010 10:40 pm    Post subject: Reply with quote
Russ Wolfe wrote:
Why not use 914-4 rear disc brakes. Probably cheaper and easier to source.
914-6 was not a common car.
914-4 rear calipers are getting harder to find; you can get the rebuild kits, but new and/or reman calipers are scarce...
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Gerrelt
Gerrelt is offline
PostPosted: Mon Feb 15, 2010 12:57 pm    Post subject: Reply with quote
Here is some info on the passat brackets.
The golf and passat bracket:
This is the reason the passat brackets have to be used:
The Golf bracket is angled, this brings the caliper outwards. The Passat bracket is straight, which is more convenient for the VW beetle rear axle and Porsche 914 disk combination.
Here you see the part number of the passat bracket:
It reads: 5780/2 Lucas.
I also have the left drum machined too:
Fits perfectly!
Now I need some brakelines custom made..
The black flexible hose has to be connected to the copper coloured hard line. I will have to get a new flexible hose and hardline made. The new hose has to have a connection fitted at one end where the hardline can be screwed into. I will probably have to create a support plate on the trailing arm where this connection can be attached. It should eventually look just like the flexible-hardline connection in the upper left corner of the picture.
homepage
Gerrelt
Gerrelt is offline
PostPosted: Sun May 09, 2010 11:46 am    Post subject: Reply with quote
It's finished!
This is the entire "Kit" :
All assembled:
With the wheel on:
I am using the original VW beetle handbrake cable.
It works great! See the whole story here: LINK
homepage
dune limo
PostPosted: Mon May 10, 2010 8:05 pm    Post subject: Reply with quote
Nice install Smile
kumatiger
kumatiger is offline
PostPosted: Mon May 10, 2010 9:07 pm    Post subject: Master cylinder Reply with quote
Nice work on the kit!
Given all the bad things I hear about Chinese sourced VW master cylinders, has anybody just gone to the junkyard and dropped in a master from a more recent four wheel disc vehicle? Something like a newer VW cylinder or a SAAB master cylinder (Volvo has a three circuit one I think if you really want overkill).
I'm going to start a disc conversion I'm just wondering if I should even bother with a Chinese $30 dual circuit master cylinder and if my money is better spent on a decent european master from a late model car. Also from what I hear about all the crappy brake switches, I think I'd rather just mount a switch on the pedal assembly and not worry about brand new switches failing after a month or two of use.
Which master cylinder are you going to use in yours?
Russ Wolfe
Russ Wolfe is offline
PostPosted: Tue May 11, 2010 9:07 am    Post subject: Reply with quote
Most later European cars, have power brakes.
The master cylinder size is designed for that.
Ever tried to stop a car with power brakes, and the engine is not running??
Gary: OK. Ima poop.
Gerrelt
Gerrelt is offline
PostPosted: Tue May 11, 2010 12:46 pm    Post subject: Re: Master cylinder Reply with quote
Thanks! Smile
I am using the standard master cylinder, that belongs to my 1303 S. The "S" in europe means it's got front disc brakes instead of drums.
But I've read that the master cylinder for a Porsche 924 or 944 will fit too. And these have different diameters than the beetle one (it could be dependent on model spec though..).
homepage
Russ Wolfe
PostPosted: Tue May 11, 2010 1:25 pm    Post subject: Reply with quote
What is the part number on that 1303S master cylinder?
Gary: OK. Ima poop.
Gerrelt
Gerrelt is offline
PostPosted: Wed May 12, 2010 1:27 pm    Post subject: Reply with quote
I don't know.. I don't think it's any different than the ones sold for the beetles today. The mexican beetles have discs up front too (I think?) , so it's probably the same as those ones.
homepage
pacorrison
pacorrison is offline
PostPosted: Sat Aug 07, 2010 2:31 am    Post subject: Reply with quote
hi folks!!!
I'm Mexican and I have this change in my mexican bug!!
now I have rear disc brakes with calipers of A4, but I use disc up front, because in Mexico is very dificult find rear disc brakes of porsche.
And I have dual circuit master cilinder stock in my car, but I have a problem because the pedal feel espogy, for that reason I will have tried use master cilynder of 20.6mm by empi.
Did you try to use the master cilynder of 20.6mm before?
do you have any tip for me?
sorry for my english, I hope you understand.
grettings from Mexico!!
E_bug
E_bug is offline
PostPosted: Sat Nov 20, 2010 1:57 am    Post subject: Reply with quote
Hello from Athens Greece.
I was inspired by Gerrelts awsome build page and I decided to have a go at it. I bought some 914 rear disks from Brombacher in Germany, they are Sebro brand and now I will have my rear drums cut. I have a question on the dimentions of the machining of the rear drum.
[img]
I will machine a locating ring but how deep should I do it?[/img]
What is that dimention with the arrows?
Question
aircooledpower.blogspot.com
Gerrelt
Gerrelt is offline
PostPosted: Wed Dec 08, 2010 11:58 am    Post subject: Reply with quote
Question
I had 2 mm machined off the surface of the drum. This was what Mike (from sharpbuilt) told me, and it was perfect!
homepage
Page 3 of 3
