morymob Samba Member
Posted: Fri Jun 12, 2015 5:00 am Post subject: |
Were u lifting with jack under engine.? Bad idea. Watch anyone putting a floor jack under there!! Getting tires put on, lifts full so flunky #1rolls jack under TRANS of my syncro. Had i not been watching some serious damage to trans mount and possibly eng mounts too. Just told them to put tires inside, I'll do it later, but i did go inside, told mgr what about happened, seemed like 'so what attitude ', mentioned i won't ever be back. |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 658 Location: Lancaster PA
Posted: Fri Jun 12, 2015 6:51 am Post subject: |
Don't lift it by the engine. _________________ wv2yb0252gg092706 |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Fri Jun 12, 2015 7:17 am Post subject: |
the engine is connected to the chassis by the motor mounts
the motor mounts are designed to support the weight of the engine resting on top of them.
if you try to lift the vehicle by jacking on the engine you are in effect trying to jack the engine upwards out of it's mounts and hang the chassis from the rubber of the mounts.
it will tear the mounts and is not good for many of the pieces involved..
can you use the engine support bar as it's solid steel?
maybe but shouldn't.
I lift my vans under the rear trailing arm below the spring perches.. one side at a time.. sometimes I do use 2 hydraulic jacks..
I also don't drive up onto ramps anymore. I jack the van up one side at a time and slide the ramps under neath it.. ramps can be too flaky and slide or such.. and if you drive over them you have to pull the jack out anyways to get it out from under the newly damaged body panel. _________________
Abscate wrote: |
cult-of-speed Samba Member
Joined: June 10, 2015 Posts: 16 Location: MID-ATLANTIC
Posted: Fri Jun 12, 2015 12:49 pm Post subject: |
Never doing that again!
Glad I checked. Used to be the way I would raise the front of my 95' M3 because of how low it sat and how little clearance I had.
The more you know. _________________ 88' Weekender |
japio Samba Member
Joined: June 14, 2013 Posts: 21 Location: the Netherlands
Posted: Wed Sep 05, 2018 5:36 am Post subject: |
danfromsyr wrote: |
I also don't drive up onto ramps anymore. I jack the van up one side at a time and slide the ramps under neath it.. ramps can be too flaky and slide or such.. and if you drive over them you have to pull the jack out anyways to get it out from under the newly damaged body panel. |
If you put a piece of material like transportbelt or something similar around the lower rung of the ramp, and you drive over that on the ramp, it stays put. _________________ Ex: 1985 Caravelle 2.5 V6TDi
1988 Camper (homebrew) MV now 1.8T (1996Audi A4)
working on: 1985 Doka 3.0H6 (EZ30R) |
vanagonjon Samba Member
Posted: Wed Sep 05, 2018 6:06 am Post subject: Re: Floor Jack and Jack Stand support points? |
I have lifted my GL with a jack using the Bostig engine cradle many times. It is a completely different arrangement than the stock engine support system. I always put a good sturdy wood 'spacer' between the jack or jack stand and the frame members. Jacking at the rear lower control arm right where it pivots at the chassis can lever the whole van off of any other supports you have under it. I have done it and it's scary to have the whole van shift position on you.
John |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 698 Location: long Island new york
Posted: Wed Sep 05, 2018 6:30 am Post subject: Re: Floor Jack and Jack Stand support points? |
I don't want to sound like a snob, but i invested in a mid height lift that resides under my van, i have it up in the air constantly. I use A,B,C and D. Its made my life so much easier. Im getting to old to be crawling under the van! _________________ Enjoy the ride....
72 bug
80 westfalia |
SnoopyPod91 Samba Member
Joined: August 03, 2018 Posts: 2 Location: Orange County CA
Posted: Fri Sep 28, 2018 2:28 pm Post subject: Re: Floor Jack and Jack Stand support points? |
Hey Calo you willing to show ua a picture of what that looks like? I am all for things that will make this easier as I get older!!!! |
cellerdoor Samba Member
Joined: July 10, 2012 Posts: 403 Location: Fairfax Virginia
Posted: Sat Sep 29, 2018 4:27 am Post subject: Re: Floor Jack and Jack Stand support points? |
Like Calo, I also invested in a new jack stand:
I spent years with the jack and ramps which served me well but I needed to create more parking area so I got the lift. It has a sliding hydraulic jack, so I still need to position it at the lift points and can only lift one end of the van at a time.
72" clear under the ramps. _________________ 1986 Westy |
Posted: Sat Sep 29, 2018 5:24 am Post subject: Re: Floor Jack and Jack Stand support points? |
Here's pictures of the jack points:
A and C
B and D
2
3 - Due to whats connected to this bar I would not jack here:
inorganic Samba Member
Joined: September 26, 2016 Posts: 60 Location: Portland, OR
Posted: Sat Dec 01, 2018 10:11 pm Post subject: Re: Floor Jack and Jack Stand support points? |
cellerdoor wrote: |
72" clear under the ramps. |
Can you please tell me more about the rack set up you have?!? this is AMAZING WOW! _________________ '86 SYNCRO Weekender |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32570 Location: Reading Pennsylvania
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7753 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Mar 08, 2021 5:14 pm Post subject: Re: Floor Jack and Jack Stand support points? |
FWIW: OP graphic from first post currently missing...reproduced here for posterity:
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
jimf909 Samba Member
Posted: Mon Mar 08, 2021 8:38 pm Post subject: Re: Floor Jack and Jack Stand support points? |
djkeev wrote: |
A "For What It's Worth" comment.....
The stock VW jacks are far from good.
I ended up carrying a Toyota Pickup jack in my spare tire rim.
It is a much safer way to lift your vehicle while on the road, no matter where you decide to place it.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=80
Dave |
After seeing the thread above I wondered about the Toyota jack for years and finally plunked down $7K to get one.
It came with a free pick-up truck.
The stock jack from a 2003 Toyota Tundra is 8" tall...
...and goes to nearly 20" tall...
_________________ - Jim
Abscate wrote: |
aidanp Samba Member
Posted: Tue Mar 09, 2021 10:29 am Post subject: Re: Floor Jack and Jack Stand support points? |
cellerdoor wrote: |
That is a nice setup, I'm probably going to do the same myself. _________________ 1989 Vanagon Westfalia, with 2.5l Subaru by SmallCar, manual 'box, 16" wheels. |
aidanp Samba Member
Posted: Tue Mar 09, 2021 10:31 am Post subject: Re: Floor Jack and Jack Stand support points? |
cellerdoor wrote: |
Posted: Tue Mar 09, 2021 11:11 am Post subject: Re: Floor Jack and Jack Stand support points? |
jimf909 wrote: |
After seeing the thread above I wondered about the Toyota jack for years and finally plunked down $7K to get one. |
I use screw jacks all the time. Have several on hand, from Toyotas, Nissans, and Dodge Trucks. Great if you are just taking one wheel off and don't intend to actually get under the vehicle. Also good for just raising one wheel enough to add a 2x6 or 4x6 under the tire. The Dodge one has a really large base so is quite stable.
One thing I like about screw jacks over hydraulic jacks is you have precise control when lowering the vehicle, say if you are trying to get the holes lined up to put a lug bolt in. |
coqcitywesty Samba Member
Joined: February 20, 2018 Posts: 401 Location: Coquitlam, BC
Posted: Tue Mar 09, 2021 12:22 pm Post subject: Re: Floor Jack and Jack Stand support points? |
I have 'ordered' one from a local wrecker for pick up this weekend - never used and includes the storage bag for $50, so I am set. Thanks for the insights on this issue. _________________ 1991 Westfalia EJ251, 1972 Volvo 1800 ES |
eskachig Samba Member
Joined: October 11, 2011 Posts: 57 Location: United States
Posted: Mon Nov 20, 2023 11:09 pm Post subject: Re: Floor Jack and Jack Stand support points? |
Somehow after reading through this thread I still feel clueless about how to lift the van. I have some 3-ton jackstands with flat tops that I got for the bmw, and a harbor freight jack. The stands are these:
https://www.amazon.com/gp/product/B0019JVIPM/
I am not even lifting the whole van, I'm trying to do a wheel swap. Are 3-ton stands safe enough with three other wheels on the ground? Can I put the flat part of the stand under the springs and jack from the frame behind the official jack points? should I just use the emergency jack that fits into them instead of my Harbor Freight one? |
Posted: Tue Nov 21, 2023 12:33 am Post subject: Re: Floor Jack and Jack Stand support points? |
If you are just doing a wheel swap and don't intend to be under the van while the wheel is off, then just use a jack, no stand necessary. |
