canabus Samba Member
Joined: April 15, 2003 Posts: 259 Location: Kelowna.B.C
Posted: Fri May 16, 2003 8:05 pm Post subject: exhaust for 2000 fi |
We would like to know if any aftermarket exhaust could be put on our rebuilt 2000 motor in our 74 bus, from the block to the tip to eliminate our heater boxes.We never drive the bus in bad weather and would like to eliminate the weight and the boxes.They are in like new cond but we want a perfomance header/exhaust? any ideas. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri May 16, 2003 8:18 pm Post subject: exhaust for 2000 fi |
I think that would have to be pretty much custom made, there is not alot of demand for what you are asking for.
some aftermarket custom exhaust for the type 4/2 engine do exist but for buggies and off road etc.
I do not think there is a "simple bolt on" you can buy for what your asking, but I'm also not saying it is not impossible to have done/do.
good luck... |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Fri May 16, 2003 9:03 pm Post subject: exhaust for 2000 fi |
These guys:
http://www.tangerineracing.com/Super_Header.htm
Although the exchange rate is getting better (wow 72 cents!) this is an expensive addition to a stock motor. I thought you'd be interested in the pictures at least. |
Posted: Fri May 16, 2003 9:31 pm Post subject: exhaust for 2000 fi |
wow very expensive,One of my tickets is a pressure welder ,I'll try to fab something up, see what I can do.We just thought that we could buy a aftermarket exhaust that was not as expensive as our paint LOL I'll will post the exhaust I fab after we move next month thanx.... |
Posted: Fri May 16, 2003 10:06 pm Post subject: exhaust for 2000 fi |
you might try gutting a pair of heat exchangers and just using the inner metal pipes for 'manifolds' and then get a bolt up header... |
Posted: Sat May 17, 2003 4:28 pm Post subject: exhaust for 2000 fi |
John at aircooled.net sells a header set up which bolts to the exhaust ports allowing you to fashion a suitable exhaust. |
