ValleyHappy Samba Member
Joined: April 04, 2007 Posts: 251 Location: Walla Walla, WA
Posted: Thu Mar 13, 2008 8:36 am Post subject: "air boot and breather hose-junk" |
When I bought my van, I had a mechanic make a list of deficiencies he spotted. Over time I have worked through a number of these and now I am looking at this one. The subject line is a quote from his assessment. I think this sits right on top of the engine as a firm black plastic, elbowed hose. Am I looking at the right thing and what does this do, and when it is bad what are the symptoms? _________________ 09 Suzuki SX-4 Crossover |
need2boat Samba Member
Joined: November 13, 2007 Posts: 123 Location: North Jersey
Posted: Thu Mar 13, 2008 8:40 am Post subject: Re: "air boot and breather hose-junk" |
ValleyHappy wrote: |
Am I looking at the right thing and what does this do, and when it is bad what are the symptoms? |
a picture is worth a thousand words.
JFF _________________ 1987 Syncro Adventurewagen: Vincent Van-Go
1998 SAAB 900 SE Coupe: Black Swan |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3342 Location: Talos IV, Piedmont Arizona
Posted: Thu Mar 13, 2008 8:42 am Post subject: |
Your correct as to the part discription. Bad boot and hose = vaccume leaks. Hunting idle,poor fuel mileage from excessively lean mixture. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
Vanagon Nut Samba Member
I believe what you're referring to is the "intake air hose" in Bentley.
On the air cooled engines, this part is NLA
On WBX I think it is still available.
If it's cracked, you can repair with "Red Hi Temp" sealant (sorry can't recall brand. common though)
Just degrease surfaces and inside cracks if poss, clean it off and apply the schtuff.
Cheers,
1988 West DIY 50º ABA
VE7TBN |
Posted: Thu Mar 13, 2008 8:51 am Post subject: |
This the part?
look I have an extra___ _________________ LEARN TO SELF RESCUE
Posted: Thu Mar 13, 2008 9:30 am Post subject: |
yep, that's what i'm looking at. i'll take a closer look this afternoon and may send you a PM...thanks Bill! _________________ 09 Suzuki SX-4 Crossover |
Posted: Thu Mar 13, 2008 10:05 am Post subject: |
man that thing is crazy looking! I've never poked around the air cooled engine or even the 1.9.
Posted: Thu Mar 13, 2008 10:08 am Post subject: |
It's for a 2.1L wbx...same as your syncro I suspect _________________ 09 Suzuki SX-4 Crossover |
Posted: Thu Mar 13, 2008 10:20 am Post subject: |
The breather hose is the hose that connects the S boot to the crankcase breather. They go to crap pretty fast. Typically the underneath side rots out so you don't see the failure as early as would be good. The thin crappy OEM hose also got sucked flat by the vacuum. Use silicone heater hose as fix, or at least Goodyear Hi-Miler hose. Even regular heater hose will last as long as the original VW hose, but that wasn't very long. |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Thu Mar 13, 2008 10:32 am Post subject: |
Wildthings wrote: |
I've never had a S-hose fail in 18 years. (the air- cooleds were a different story lots more heat under there!) The breather hose went soft on me after changing to synthetic oil many years ago. I found some US car water pump bypass hose to fill the void. I think it is still on there.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Mon Mar 17, 2008 10:53 am Post subject: |
Well, I checked out my air boot this weekend and saw that its connection to the AFM was crooked and full of silicone sealer...no doubt leaky. I went to clean it up and reattach it and I can't seem to get it to attach as firmly as I would like. The boot appears to be made of a firmer rubber than what Bill W shows in this photo and every time I attached the boot to the AFM and tightened the clamp, the clamp would squeeze the boot off of the AFM outlet. I had to back way off on tightening and added my own sealant as a temporary fix, but I don't like it as I should be able to mount it without the sealant and just a good firm clamp......any tips? The condition of the boot looks good and I shove it allllll the way on until tightening the clamp but it still just slides off.
Also noticed the breather hose to the crankcase was like playdough soft and squishy and no ability to maintain shape.... I guess this is 'junk'. I will take Wildthings suggestion and replace. What does a this crankcase vent do other than connect to the intake boot? Why does the crankcase need to be vented in this 'circular' fashion?
Thanks a lot! _________________ 09 Suzuki SX-4 Crossover |
Posted: Mon Mar 17, 2008 12:25 pm Post subject: |
You may have a 1.9 boot on there. _________________ LEARN TO SELF RESCUE
