Posted: Wed May 28, 2003 11:52 am Post subject: 1970 Westy fuse box, is it different from others? |
hi, i am having problems finding a replacement fuse box for my bus. the one that is in there is yellow, bigger than others that i have looked at, has relays plugged into the bottom of it, and has the part# 411-937-505A. do i have to use the same model or can i adapt to another? please let me know which one. email me at [email protected] thanks, elizabeth |
nodtobob Samba Member
Joined: May 27, 2003 Posts: 208 Location: Santa Barbara, CA
Posted: Wed May 28, 2003 3:42 pm Post subject: 1970 Westy fuse box, is it different from others? |
Elizabeth,
I checked the numbers on my bus which is a 70 as well and the numbers are the same as yours.(411-937-505A) I would stick with the same year fuse block and yes they do have the relays attached to the bottom of them. Hope this helps. Anthony |
Posted: Wed May 28, 2003 4:33 pm Post subject: 1970 Westy fuse box, is it different from others? |
it doesnt help, because i am having problems finding the same type. where do you suggest besides auto wreckers? |
Posted: Wed May 28, 2003 6:40 pm Post subject: 1970 Westy fuse box, is it different from others? |
I would find a bus somewhere that is parting out. Where are you located at, I actually had to get one for my other bus awhile back and this guy has them in boxes at this vw salvage yard, maybe I could check it out for you. Anthony |
Posted: Wed May 28, 2003 6:53 pm Post subject: 1970 Westy fuse box, is it different from others? |
i'm in stockton, calif near sacramento and SF. would you please check for me about it? thanks, elizabeth |
Posted: Wed May 28, 2003 10:16 pm Post subject: 1970 Westy fuse box, is it different from others? |
Yeah I will check for you and get back with you tomorrow sometime. I am in Santa Barbara. It shouldn't be hard to find. Will let you know. anthony |
Posted: Thu May 29, 2003 2:50 pm Post subject: 1970 Westy fuse box, is it different from others? |
Elizabeth, I talked to the guy and he recommends upgrading to a 71 bus box since all the 1970 model stuff is only a one year deal. Like the headlight relay and the flasher are only for that year. If you upgrade to a 71 fusebox then those headlight relays can be interchanged with any type and are readily available and the 71 fuseblock comes with the 3 pin flasher and the the fuse block is made of better plastic that won't break as easily. He has the block for $15 and the relay and flasher are around $8-10 a piece. So i guess your earlier answer to your question is yes you can upgrade!! Let me know I am going there tomorrow to pick up a few things, it is small enough to ship up there. You can email me and let me know. |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Thu May 29, 2003 7:55 pm Post subject: 1970 Westy fuse box, is it different from others? |
The early 70 A fuse box was yellow and spilt down the middle. VW got smart and made the later ones out of better material, same as 71 and up. Look for the white one. I have one, complete, if you want it. Pmail me at aufever@prodigy,net |
Karl Samba Member
Posted: Thu May 29, 2003 7:57 pm Post subject: 1970 Westy fuse box, is it different from others? |
Forgot to mention, yes the A is 70 only, But 71 is B and 72 is C. Each one is one year only. [and D is 73 411 and E is 74 412....] |
BenPonKombi Samba Member
Posted: Mon Jul 20, 2015 6:45 pm Post subject: Looking for Fuse Box 411-937-505A, PLEASE HEEEELP! |
Hello All,
I see people went over this topic 12 yrs. ago, and let me tell you, things haven't changed. I am too having problems finding a fuse box for 1970 bus part# 411-937-505A. Does any one know where I can find one? PLEASE HELP! i've been looking everywhere... |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Tcash Samba Member
Posted: Tue Jul 21, 2015 7:58 am Post subject: Re: Looking for Fuse Box 411-937-505A, PLEASE HEEEELP! |
BenPonKombi wrote: |
Hello All,
1970 Fuse Box Conversions
Good Luck
Tcash
Search fuse box |
BerneseMtnDog Samba Member
Posted: Tue Jul 21, 2015 8:31 am Post subject: |
Try Busted Bus: http://bustedbus.com/ They've been very good at finding odd parts for me.
Steve |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Tue Jul 21, 2015 9:31 am Post subject: Re: Looking for Fuse Box 411-937-505A, PLEASE HEEEELP! |
Hello All,
I had luck running a wanted ad a few months back. Also, when guys part out a 1970 ask them if they have it. Be sure to get the newer type plastic. The part number is the same. Being a Type IV part number you may have luck in that ad section too.
karmann1st Samba Member
Joined: September 12, 2010 Posts: 93 Location: Florida
Posted: Sat Sep 17, 2016 10:10 pm Post subject: Re: 1970 Westy fuse box, is it different from others? |
I have a 1970 early with the Yellow fuse box.
My fuse box has NO relays at all just wires....
can someone please tell me the relays that I need to be connected there or any other place?
I know is supposed to be the Frond lights and turn signals...
any parts numbers to check to buy?
Thank you!!! _________________ Questions? Email me, I always answer all emails, same day or next. |
Tcash Samba Member
Posted: Sun Sep 18, 2016 12:13 pm Post subject: Re: 1970 Westy fuse box, is it different from others? |
Headlight Relay
411941583A
TURN SIGNAL FLASHER RELAY
211953215C
Door Buzzer Relay
111 951 307B
Good luck
Tcash
Posted: Sun Sep 18, 2016 3:02 pm Post subject: Re: 1970 Westy fuse box, is it different from others? |
thank you so much!!
is a number for the door buzzer? _________________ Questions? Email me, I always answer all emails, same day or next. |
Tcash Samba Member
Posted: Sun Sep 18, 2016 5:35 pm Post subject: Re: 1970 Westy fuse box, is it different from others? |
karmann1st wrote: |
thank you so much!!
is a number for the door buzzer? |
Added number to post above ^^^^^^^ |
gettysburg Samba Member
Joined: February 18, 2015 Posts: 3 Location: Gettysburg
Posted: Mon Dec 17, 2018 2:43 pm Post subject: Re: 1970 Westy fuse box, is it different from others? |
I changed out my 70 fusebox for a 71 years back and everything seems to work fine. Meanwhile I came across a 70 fusebox (the newer white one). Just asking opinions here should I hang onto it? Or should I sell it and for how much. Just kind of seeking advice. |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Mon Dec 17, 2018 8:22 pm Post subject: Re: 1970 Westy fuse box, is it different from others? |
the last clean 70 fuse box I sold I got 200 for about 2 years ago.
my rule of thumb:
if I have a 1 year only car and I have spare 1 year only parts, I keep all the parts until I sell the car _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
