flat4freak1978 Samba Member
Joined: June 02, 2003 Posts: 793 Location: stone mountain georgia
Posted: Tue Jun 03, 2003 7:03 pm Post subject: bus tranny. |
how do you drop the tranny out of a 78 bus? its a 4SPD, dont know anything as to what model tranny it is. also how do you disconnect the drive shafts from the vw trans? im also dropping a bug tranny. from a 67 bug. same trans in both??
thanks
justin |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Tue Jun 03, 2003 11:12 pm Post subject: bus tranny. |
The bus tranny will be IRS for sure. Checklist:
- undo clutch cable
- remove brake list switch wiring
- uncouple the shift rod from the nose cone
- unbolt transmission ground strap
- disconnect the axles by undoing the cvjoint at the flange on each side
Unbolt away! |
Posted: Wed Jun 04, 2003 9:52 am Post subject: bus tranny. |
Ratwell pretty much included everything. Just be VERY careful when removing the bolts from the CV joints. They are going to be allen or star, and they strip easily. The safest way to get them off is to get a socket mounted allen or star wrench. Clean all of the guck out thoroughly and apply steady, even pressure to loosen the bolts with your socket wrench. With these babies, slow is fast. Have fun...
Richard |
Posted: Wed Jun 04, 2003 9:59 am Post subject: bus tranny. |
I meant to say:
- remove backup light switch wiring |
