Posted: Thu Jun 05, 2003 11:47 am Post subject: name of engine seal? |
Ive got a 77 westy. What's the name of the engine seal that goes around the bottom part of the engine. You know, its foam and it keep exhaust from running directly into your bus. I've concluded that is the cause of my exhaust smell in the cab problem.
Bret |
Posted: Thu Jun 05, 2003 11:56 am Post subject: name of engine seal? |
Its called the engine compartment seal. Check the seal on the rear hatch, deck lid and the hatch located under the bed. If any are bad they should be replaced. good luck. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Fri Jun 06, 2003 9:48 am Post subject: name of engine seal? |
If any parts of the seal is missing, replace it for $20. If you touch it and it disintegrates, replace it. It's required to keep the engine cool (same function seals out exhaust) and to keep dirt out of the intake clogging up the air filter.
There is a void behind the bus as you drive and seals on the real that allow air in (cracked, missing, deformed,etc) will allow exhaust to come in. I have a bad seal on the rear hatch and it doesn't allow the door to close properly so it's slightly ajar on one side.
The access hatch lid on 73-79 models has a seal also but since it's partly inside the bus I've never seen a bad one even at the junkyard. I just noticed this seal in a recent search of body seals:
http://www.oeveedub.com/Merchant2/merchant.phpc?Sc...ct_Count=0
http://tinyurl.com/dne4 |
Posted: Fri Jun 06, 2003 11:19 am Post subject: name of engine seal? |
I think I explained that wrong. It's a piece of foam that surrounds the actual engine. It's not made of rubber, its foam. Um, if you open up the engine compartment, it's the foam piece that keeps you from seeing through the compartment to the ground. There, I think that was better. So, what is that one called? |
Posted: Fri Jun 06, 2003 6:31 pm Post subject: name of engine seal? |
That's the one. No confusion here.
There is always some debate on the right way to install it. According to the parts diagrams the ends join in front of the cooling fan. The lighter colored porous side of the foam goes up and the darker more solid side goes down. The diagrams in bentley and the workshop manual bear this out. |
Posted: Mon Jun 09, 2003 8:01 am Post subject: name of engine seal? |
ah, that is it, sorry I didn't believe you guys before. Those pictures of the hatch seals threw me off. Thanks for the help |
