Nor_AL_67 Samba Member
Joined: December 18, 2007 Posts: 663 Location: Huntsville,Alabama
Posted: Mon Mar 24, 2008 6:02 pm Post subject: 1st Drive Observation and Question |
Hey all, after three months of installing new beam/suspension/steering, tires/wheels, shift rod bushing, new brakes and more I finally took Suzee for her first drive with me as the owner. The weather was beautiful 70 deg no clouds and perfect. She drives great, handles like a go-cart and no rubbing anywhere anytime. Got numerous thumbs-up, smiles, double-takes and the such.
Now the question, it starts great after one flick of the switch, and runs great until you are at speed (~50 mph) and depress the clutch, then it dies. Then starts right back up no prob. I'm thinking maybe too rich on the carb, or leak at carb/intake manifold?
Thanks all for the help for this newb the last couple of months.
_________________ 63 Sedan
61 Rag
67 Type 1 Sedan
63 Type 2 Standard Walk-thru
69 Ghia
68 912
Amateur Versus Rusty Bus! |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
henrym Samba Member
Joined: August 19, 2006 Posts: 1002 Location: Marina Del Rey, California
Posted: Mon Mar 24, 2008 6:34 pm Post subject: |
Beautiful! Great job. I remember when I did my front beam and suspension---it was fun finally driving it. Don't know why your engine is dying but who cares? Just sit in your car and pretend!! _________________ 1967 Bug (Second owner) |
spook Samba Member
Posted: Mon Mar 24, 2008 7:32 pm Post subject: |
Hey spook notice I got your 'Airkooled Kustoms' sticker on the side? _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
Euro 67 Samba's 67 part whord
Joined: February 24, 2007 Posts: 1370 Location: Between Florida and Cali
raise the idle a little _________________ 68 Bug totaled one day will live again
69 Bug donor car
Many parts had, always need em!
millerje78 wrote: |
I'm no expert but I'm guessing the spike during cold running has everything to do with the roofing tar(20-50) in the crankcase. |
bill may wrote: |
...i could be wrong as i have only been driving air cooled beetles since august 1965. |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Mon Mar 24, 2008 8:12 pm Post subject: |
Running too lean, stock carb ? Adjust the mixture, look for vacuum leaks and make sure the timing is not too far retarded. _________________ Midwest Autosavers, Inc. Woodstock, IL |
Posted: Mon Mar 24, 2008 8:21 pm Post subject: |
DrDarby wrote: |
Running too lean, stock carb ? Adjust the mixture, look for vacuum leaks and make sure the timing is not too far retarded. |
Ok thanks Doc, carb is a solex H30/31 pict (stock?). It seems as though the idle is too high already, will check. _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
67 Shane Samba Member
Joined: September 05, 2007 Posts: 1080 Location: Losing my mind in Charlotte, N.C.
Posted: Tue Mar 25, 2008 4:10 am Post subject: |
Nice ride! Looks very nice and has a great stance. _________________ -OstKüste-
67 Euro Type 1.
67 SO-42 Westfalia |
Posted: Tue Mar 25, 2008 5:34 am Post subject: |
Nor_AL_67 wrote: |
DrDarby wrote: |
Ok thanks Doc, carb is a solex H30/31 pict (stock?). It seems as though the idle is too high already, will check. |
Get all the tune up specs in order especially timing and adjust the carb per the book. You have a slight lean condition and / or timing retarded. _________________ Midwest Autosavers, Inc. Woodstock, IL |
Seb67 Samba Member
Joined: December 02, 2003 Posts: 1006 Location: New England
Posted: Tue Mar 25, 2008 6:03 am Post subject: |
sounds like there is something in your fuel line / tank. _________________ 1964 Type 1 |
HERC Samba Member
Posted: Tue Mar 25, 2008 3:31 pm Post subject: |
Also......Make sure the valves aren't too tight...
Tight valves will also kill a motor while depressing the clutch, unless it's really warmed up.. _________________ Herc |
spook Samba Member
Posted: Tue Mar 25, 2008 5:37 pm Post subject: |
Nor_AL_67 wrote: |
Hey spook notice I got your 'Airkooled Kustoms' sticker on the side? |
yep,thanks for the window space,
happy with your beam? _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
Posted: Tue Mar 25, 2008 9:40 pm Post subject: |
spook wrote: |
happy with your beam? |
Great job building the beam, exactly what I wanted. I installed the tie rods using the inner hole on the spindle for quicker steering (most driving is between 10 and 2 o'clock).
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
