indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Wed Sep 21, 2011 5:54 pm Post subject: |
I own an '87 without and a '91 with. I can tell no discernible difference between the two as it relates to wind noise. Given my experience, if I found a set of these at the junkyard I probably wouldn't go to the time and trouble to get them off the donor van and then onto mine. _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com |
stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Wed Sep 21, 2011 6:27 pm Post subject: |
When I did the window out repaint of my Westy, I added these rubber strips. I simply bend the taps of the metal frame to fit the door mounting frame that do not have the bumps. I think the bumps are there to make putting in the screws easier. At the same time, I put " Peel-N-Seal " every where. Now my Westy is much quieter than my tin top but I don't know what percentage the rubber strips at the doors lower the noise. IMHO, the VW engineer did not put in these rubber seal just for kicks. They have their reasons. _________________ Steve
87 Westfalia full camper 4 speed |
shizzon Samba Member
Joined: July 25, 2006 Posts: 596 Location: Boulder, CO
Posted: Tue Nov 27, 2012 2:37 pm Post subject: |
Does anyone have any pics of this project to share? specifically, of the cheap ebay solution? but also of the stock solution. For many of us, it's hard to find vans in junkyards, and an aftermarket solution would be great, if it works! _________________ 1989 Bostig Syncro Westy |
Luckyphil Samba Member
Joined: March 07, 2011 Posts: 156 Location: Australia
Posted: Wed Nov 28, 2012 11:29 am Post subject: |
I already did that, and I still have pretty bad wind noise coming from my drivers side. _________________ 1989 Bostig Syncro Westy |
charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2238 Location: Olympia, Washington
Posted: Sat Sep 02, 2023 5:35 pm Post subject: Re: Wind noise reduction on late model Vanagon |
I don't go fast enough to create wind noise, beyond my own. . . . 😎 _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Sep 02, 2023 8:58 pm Post subject: Re: Wind noise reduction on late model Vanagon |
I fitted the lower door seals to my 86 about 3 years ago. In the interest of being thorough, I documented
db readings before and after. (Cheap/free phone app, nothing anywhere near real serious…)
IIRC, it showed 2db reduction in road noise. Certainly measurable, but in retrospect not what I’d consider
really effective for the money & effort put into the project. YMMV… <shrug>
Yes, I took the doors off, supported on a shop stool allowed me room to work & keep speaker wiring in place.
Pics? FWIW…I took only one after the fact:
Related thread (some good pics in there): https://www.thesamba.com/vw/forum/viewtopic.php?p=9334745&highlight=#9334745
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32629 Location: Reading Pennsylvania
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Sun Sep 03, 2023 11:14 am Post subject: Re: Wind noise reduction on late model Vanagon |
djkeev wrote: |
Well, funny this thread resurfaced, these wind block seals are presenting a bit of a delemnia for my repaint of my 90.
I see no easy way to remove them, they are nearly impossible to mask.
They are going to involve removing the doors, remove the seals, install the doors, spray the Van, remove the doors, install the seals and reinstall the doors!
Heavy Sigh........ |
You could shoot the doors while off the van. Depends on how far into a full respray you're willing to go . _________________ Currently:
Posted: Sun Sep 03, 2023 1:02 pm Post subject: Re: Wind noise reduction on late model Vanagon |
MsTaboo wrote: |
djkeev wrote: |
You could shoot the doors while off the van. Depends on how far into a full respray you're willing to go . |
Funny you ask...... I'm not doing a full respray....... just a face lift is all for a tired old girl.
I've already begun taking the doors and weatherstrip off.
I'm now waiting for my son-in-law to arrive for dinner ...... little does he know..... heh heh heh....
The upper weatherstrip is simply glued to the door window frame ......
The lower ones need fasteners removed, I've got everything loose and ready to pull upon his arrival.......
Ghia
Vanagon
Beetle
