TopBud Samba Member
Joined: February 28, 2004 Posts: 1111 Location: Flagstaff AZ
Posted: Tue Apr 01, 2008 9:25 am Post subject: rear bumper mounts? |
Howdy. OK I am trying to take off my drivers side rear bumper bracket. There are 2 bolts holding it on. 1 bolt came off no problem. The other bolt is just spinniing. It seems as if the "nut" on the inside is broken. I am not sure because I can not see what is in there. On the rear of the bus there is a little hole. I can not see in there, it is too small, but it seems as if that is where the nut is. I am not sure how to get the bolt off. I need to remove the bumper bracket so that I can do some rust repair. Any suggestions.
Should I cut a hole in the engine compartment to access the nut or what. Any help would be appreciated.
Thanks _________________ 86 bostig SYNCRO
66 convertible Karmann Ghia |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4522 Location: Oklahoma City, OK
Posted: Tue Apr 01, 2008 9:58 am Post subject: |
Got a torch or access to one? Cutting a hole through the engine compartment will not help, that channel is boxed. Have the head of the bolt cut off. |
TopBud Samba Member
Posted: Tue Apr 01, 2008 10:00 am Post subject: |
Then how would I attach the new bolt? wouldn't I have to attach a nut? _________________ 86 bostig SYNCRO
NOVA Bus Samba Member
Joined: April 18, 2005 Posts: 517 Location: Herndon, VA
Posted: Tue Apr 01, 2008 10:12 am Post subject: |
I would wedge the bracket to keep the bolt from spinning, then use an angle grinder to take the head off. For the replacement bolt, you could tap larger threads in the "box section" of the frame strut.
It would also be possible to have someone tack-weld a threaded stud in the same hole location, then use a nut to secure the bracket, though the other bolts would provide the bulk of the holding power. _________________ ********************************
1977 Transporter / Weekender
- GE engine, L-Jetronic w/ hyd. lifters
- Brown Beige plaid P27 Interior (ED)
http:/[url=http://www.vw-mplate.com/mplate-29638.png]Click to view image
Camper Interior donor:
[/URL]/www.vw-mplate.com/mcode.php?lang=EN&id=721 (M-Code for interior). |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Apr 01, 2008 12:21 pm Post subject: |
Your only option is to grind or burn it off, cut a horizontal slot in the side of the framerail at the bottom just big enough to slip in a piece of 1"x 1/4" bar with a tapped hole in it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Rocknrod Samba Member
Joined: November 02, 2004 Posts: 2157 Location: North Carolina
Posted: Tue Apr 01, 2008 12:40 pm Post subject: |
Drill a hole right beside the nut on the side of the frame rail. Slip a piece of square steel into the hole and wedge the nut so it won't move while you loosen it up, then fish the nut out of a hole in the frame with a magnet.
If you have a welder, or access to one cut out a hole, weld the nut back in place and weld the hole over. If not, enlarge the hole so a thin box wrench can slip in to hold the nut. The frame won't be as strong, but for impact it'll be stronger than having only one bolt holding that side of the bumper. _________________ 1971 Westfalia with a high top.
http://71vwbus.blogspot.com/ - Pictures and words... Oh My! |
TopBud Samba Member
Posted: Tue Apr 01, 2008 1:06 pm Post subject: |
Thanks guys. I will attack this project this weekend and let you all know how it comes out _________________ 86 bostig SYNCRO
boat_builder Samba Member
Joined: July 19, 2007 Posts: 610 Location: Republic of Ireland
Posted: Tue May 20, 2008 2:22 pm Post subject: |
I'm struggling with the exact same problem tonight
One bolt is just spinning.
I've tried drilling a hole down through the frame from the top, and I could wedge a screwdriver on the nut, but the nut is also seized on the bolt.
You can't get in there with an angle grinder because its too close to the engine mounting bracket. Can't even get near it with a hacksaw.
I'm going to try to drill through the head of the bolt, but its gonna be tough to stop it from turning round, maybe a spot of weld on it first.
Then when I get the damn thing off, I'll just put a long bolt down through from inside the engine compartment.
A classic example of how a simple job can turn into a nightmare. |
youslayme Samba Member
Posted: Tue May 20, 2008 10:02 pm Post subject: |
me too... i currently have the bumper off, one bracket off... and one bolt off the other bracket... and then one thats spinnin.. oh well.. ill get it soon.. lol _________________ Dave |
dweller Samba Member
Joined: May 31, 2007 Posts: 819 Location: Chapel Hill, NC
Posted: Tue May 20, 2008 10:28 pm Post subject: |
how'd they get a nut on it to begin w/ if it's not a threaded hole?
i lost one also so one side has only one bolt. Some kid rearended me at a stoplight a few months ago, that side took the worse impact but damaged only the bumper.
dp _________________ 77 Westie 2.0L FI ... slowly restoring bit by bit... |
Posted: Tue May 20, 2008 11:31 pm Post subject: |
boat Builder:
Drill your hole from the side of the frame, and wedge against the side of the nut on an angle against the other side of the frame. Gives more leverage. Pick your side so that when you are loosening the bolt pins up against your lever.
Failing that...
Grab a die grinder/dremel and some little cut off wheels and chew it out.
Don't try to wedge in and try to cut the bolt in half, or the disk will break. (Bad news) take pie shaped chunks out of you can. Or go in at a 90 degree and chew out slots.
You can also use a green (silicone carbide) wheel on one eat it out that way. Probably a wash on time. 15 minutes and the head of the bolt is gone.
If theres a decent air gap between the frame and bumper bracket, you might be able to grab the bolt head with a vice grip and use a metal cutting blade on a jig saw to get at it.
I prefer those methods over drilling (less hot chips falling around the goggles to the eyes... But if you really need to... grab hold with a huge C-clamp on the outside of the bolt head and wedge it in the slot at an angle. Center punch, and spot drill first and shoot some oil up there! You can also take the bumper bracket and wedge a pipe diagonally through it to the ground, and have someone put enough load on it to keep the bolt from spinning. Can also try a wooden wedge driven under it...
Creepers are a dang nice thing compared to sitting in the bilge beating in new frames... What kind of boats do you build? _________________ 1971 Westfalia with a high top.
