Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Apr 04, 2017 7:27 am Post subject: Re: Engine Stand |
Personally I prefer a bus bell housing to a yoke for running and mounted very low on "stand" to prevents whole setup from being top heavy.
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6554 Location: Houston, Texas
Posted: Wed Apr 05, 2017 3:19 pm Post subject: Re: Engine Stand |
I was always using my Beetle for the power to the gambrel and pulley hoist so I got this instead. It should be a bit more stable than letting off the parking brake to lower the engine.
heimlich VWNOS.com
Posted: Thu Apr 27, 2017 8:52 pm Post subject: Re: Engine Stand |
1000 LB engine stand on sale at Harbor Freight for $49.99. |
Danpa Samba Member
Joined: August 21, 2007 Posts: 1240 Location: Valparaiso, in
Posted: Fri Apr 28, 2017 2:58 am Post subject: Re: Engine Stand |
kawfee wrote: |
I was always using my Beetle for the power to the gambrel and pulley hoist so I got this instead. It should be a bit more stable than letting off the parking brake to lower the engine. |
I'm curious about this method. Were you using a different car to lower the engine of the one you're working on or what?
Dan _________________ 67 Beetle (gone)
68 Bay Window Double Cab (gone) sob, sob!
64 Beetle (gone)
77 Scirocco (gone)
73 Squareback (scrapped)
70 Beetle (current, in pieces) |
heimlich VWNOS.com
Posted: Fri Apr 28, 2017 7:13 am Post subject: Re: Engine Stand |
Danpa wrote: |
Dan |
One time I was. Another time I wasn't. |
heimlich VWNOS.com
Posted: Sun May 07, 2017 6:02 pm Post subject: Re: Engine Stand |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76761 Location: Sneaking up behind you
Posted: Sun May 07, 2017 6:12 pm Post subject: Re: Engine Stand |
I would not start an engine on that stand setup. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun May 07, 2017 6:26 pm Post subject: Re: Engine Stand |
Glenn wrote: |
I would not start an engine on that stand setup. |
Totally agree with Glenn........ Great big NO...
heimlich VWNOS.com
Posted: Sun May 07, 2017 7:45 pm Post subject: Re: Engine Stand |
Glenn wrote: |
I was thinking of strapping and bolting the stand to the ground. I suppose I could just drop the whole thing to the ground as well. |
Glenn Mr. 010
Posted: Sun May 07, 2017 7:55 pm Post subject: Re: Engine Stand |
Or fire it up and gravity will get it on the ground.
Member #1009
#BlueSquare |
heimlich VWNOS.com
Posted: Sun May 07, 2017 8:01 pm Post subject: Re: Engine Stand |
Glenn wrote: |
Or hook it to my hoist, raise it, then let it dance. |
Posted: Mon May 08, 2017 6:27 am Post subject: Re: Engine Stand |
Or update stand...
https://www.thesamba.com/vw/forum/viewtopic.php?p=8399813#8399813
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Mon May 08, 2017 6:48 am Post subject: Re: Engine Stand |
kawfee wrote: |
Glenn wrote: |
Why not build a wood table (for lack of a better word) to sit under the engine while its on that stand when used as a run stand ? _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
heimlich VWNOS.com
Posted: Mon May 08, 2017 8:25 am Post subject: Re: Engine Stand |
That costs money and space both of which are precious. I do have some cedar blocks so I might just go for that. |
heimlich VWNOS.com
Posted: Sat May 20, 2017 12:10 pm Post subject: Re: Engine Stand |
The test stand adapter I previously bought didn't work. I won't go into the details on that but the manufacturer and I figure out the issue and the refunded my monies.
I bought part of a transmission and ground one out.
Remember when you are grinding away to dance a jig when you see flashes. I kept a water hose close by frequently spraying away excess dust. If it does catch on fire do not spray the fire with a water hose. |
Glenn Mr. 010
Posted: Sat May 20, 2017 12:53 pm Post subject: Re: Engine Stand |
Pretty sure the tranny case is aluminum and not magnesium. _________________ Glenn
Member #1009
#BlueSquare |
heimlich VWNOS.com
Posted: Sat May 20, 2017 12:56 pm Post subject: Re: Engine Stand |
Let me correct that for you unless you can think of another reason for the flash fires.
Glenn wrote: |
Pretty sure the tranny case is aluminum and magnesium. |
heimlich VWNOS.com
Posted: Sat May 20, 2017 12:58 pm Post subject: Re: Engine Stand |
Glenn,
Thanks for the original post with this part in it. I've always wanted it. I am very happy to finally have this. It fits perfectly. Hopefully the starter works as well. I've ordered an automatic starter since my bushing doesn't fit. |
Posted: Sat May 20, 2017 3:51 pm Post subject: Re: Engine Stand |
kawfee wrote: |
Is this the same adapter that you told me about and that I bought from your recommendation? _________________ ----------------------
heimlich VWNOS.com
Posted: Sat May 20, 2017 6:25 pm Post subject: Re: Engine Stand |
CiderGuy wrote: |
kawfee wrote: |
Is this the same adapter that you told me about and that I bought from your recommendation? |
CiderGuy, That is correct. I recommend trying it out and making sure it works. On the side note, if it does not work email them and let them know. Taking some pictures would help. They refunded my the purchase price plus my cost in shipping to send it back to them.
I tried the other way tonight with the adapter and the start spun right into the flywheel as expected. I was very pleased.
Let me know if I can help. |
