Fman Samba Member
Joined: November 21, 2018 Posts: 151 Location: Nor Cal
Posted: Wed Jan 16, 2019 12:38 pm Post subject: Re: Engine Stand |
Bruce Amacker wrote: |
Fman wrote: |
EDIT: my next question would be will the VW adaptor bracket more than likely work with this stand?
Quick note- make sure the diameter of the tube is the same on both, my VW engine adapter had a slightly smaller diameter which made me fabricate some sleeves so it fit properly in the engine stand "head". Also, most engine stands are very short, the manufacturers build them for people 5 foot tall. I'm 6'5" so several times I've had to cut and extend the vertical section of the stand. My back can't handle working bent over. |
That is the problem, I can't find ANY specs on the diameter of the hole for the adaptor with this engine stand. Still trying to get in contact with manufacturer to see if they can help me out. The VW stands IMO are all meh at best, especially the three wheel versions, would never think about using a three wheel stand. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3850 Location: San Jose, CA
Posted: Wed Jan 16, 2019 1:17 pm Post subject: Re: Engine Stand |
I've used a 3-wheeled engine stand for 35 years, rolled it around the garage and driveway WITH an engine on it, over bumps and gaps, and have never, ever had even a near-miss with a tipping incident. There's nothing at all wrong with 3-wheeled stands (unless you're hooking a tow-rope up to it and racing down the street).
On the other hand, what I don't like about 4-wheeled units is that I'd invariably end up standing on-or-around the leg, because it's just right there in the most inconvenient place...right where most of us stand, when we're working on engines. As far as a lift table between the legs, meh, I use a cherry-picker to install and remove engines from my stands, so it straddles them perfectly (which would never work with a 4-leg unit).
Just my ten cents
By the way, I believe the standard spec is 2-3/8" on the headstock diameter...it's considered the most common. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Wed Jan 16, 2019 3:04 pm Post subject: Re: Engine Stand |
Busstom wrote: |
On the other hand, what I don't like about 4-wheeled units is that I'd invariably end up standing on-or-around the leg, because it's just right there in the most inconvenient place...right where most of us stand, when we're working on engines. |
What he said.
Never a problem with a 3 wheel stand. _________________ Glenn
Member #1009
#BlueSquare |
Fman Samba Member
Posted: Thu Jan 17, 2019 10:10 am Post subject: Re: Engine Stand |
Glenn wrote: |
Busstom wrote: |
What he said.
Never a problem with a 3 wheel stand. |
I was also planning on using the stand for the new transmission coming to swap out the swing axles. What engine stand would you recommend? Is the EMPI stand Jbugs sells a good buy? |
Glenn Mr. 010
Posted: Thu Jan 17, 2019 10:36 am Post subject: Re: Engine Stand |
I had a empi yoke years ago.... It soft and will bend. I would not leave and engine on it without expecting it to be on the floor when i return.
A swingaxle tranny is much longer. I'd get a 4 leg stand with a 3 arm yoke. _________________ Glenn
Member #1009
#BlueSquare |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Posted: Thu Jan 17, 2019 11:27 am Post subject: Re: Engine Stand |
Don't buy this yoke unless you want to modify it to make it fit.
https://www.summitracing.com/search/part-type/engi...U&ar=1
The holes in the tabs are OK, but the shape of the tab is wrong. You have to grind it back to fit the raised area on the back of the engine that locates in the bellhousing. Doesn't anything work out of the box anymore??? Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jan 17, 2019 1:06 pm Post subject: Re: Engine Stand |
Tom_Kathleen wrote: |
The holes in the tabs are OK, but the shape of the tab is wrong. You have to grind it back to fit the raised area on the back of the engine that locates in the bellhousing. Doesn't anything work out of the box anymore??? Tom |
I era of cheap, disposable Chinese junk, you actually expect something to work!
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Thu Jan 17, 2019 1:13 pm Post subject: Re: Engine Stand |
I bought this yoke a few years back:
https://www.thesamba.com/vw/classifieds/detail.php?id=606310
I don't ever worry about it bending.
Hanging a 4k engine on a 40 dollar yoke make from recycled soda cans doesn't seem like a good idea. Pony up a few more bucks and get something that you will never worry about. |
Glenn Mr. 010
Posted: Thu Jan 17, 2019 2:21 pm Post subject: Re: Engine Stand |
Edit: my VWT yoke spindle measures 2.370, so you would seek an engine stand with a 2-3/8" headstock/tube.
Fman wrote: |
Maybe someone can answer this questions for me, I am getting ready to purchase a VW engine stand. I have located a really nice heavy duty 4 wheel stand with the "standard 4 prong V8 adaptor on it" that all the engine stands use. Can you attach a VW engine to this style mount or do you need the VW adaptor to make it work?
This stand looks pretty stout. Who makes it? As Glenn said, those four-pronged V8 type attachment yokes are a no-go for your VW. Can it be done? Yes. But the reasons to avoid it are many. Go with the Vintage World Tools yokes linked above.
Who makes that 4-leg stand you pictured? I can measure the diameter of my VWT yoke when I get home and post the dimensions (pretty sure 2-3/8 ). You just need to get the dims on the headstock of that pretty stand you're looking at. |
Fman Samba Member
Posted: Fri Jan 18, 2019 1:52 pm Post subject: Re: Engine Stand |
Busstom wrote: |
Fman wrote: |
The stand is made by Torin, I will only buy a 4 leg stand, I am still not sold on the 3 wheel stands. Just personal preference, not worth the risk to me of having a stand tip over to save $30.
Thanks for the reference on Vintage World yoke, definitely looks like a much better option than the EMPI. |
Bad bug Samba Member
Posted: Fri Jan 18, 2019 2:56 pm Post subject: Re: Engine Stand |
Busstom wrote: |
Fman wrote: |
Great that you guys are having this discussion. I bought the stand above couple months ago, it's the 1500 lbs v8 engine stand the 4 finger yoke spindle that came with it measures in at 2.340" also the area that the spindle goes into measures 2.390". My only question now is do you guys grease the spindle before use. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Fri Jan 18, 2019 3:54 pm Post subject: Re: Engine Stand |
I didn't. I like the resistance when rotating the engine during a build.
Others will chime in.
Good Luck _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri Jan 18, 2019 4:10 pm Post subject: Re: Engine Stand |
Bad bug wrote: |
Busstom wrote: |
Fman wrote: |
Excellent, sounds like the Torin tube will accommodate the VWT yokes.
Greasing I guess is personal preference...I always do, once I had a fit that was too close, the works galled up and I had to put it up on a press to get the whole dang thing apart |
Fman Samba Member
Posted: Fri Jan 18, 2019 6:49 pm Post subject: Re: Engine Stand |
Bad bug wrote: |
Busstom wrote: |
Fman wrote: |
Just to confirm the Torin stand will accomodate a 2 3/8" yoke? Wanted to make sure before I place the order. The only negative review I found on the Torin stand was it was too low? Have you noticed this being a problem? |
Posted: Fri Jan 18, 2019 9:55 pm Post subject: Re: Engine Stand |
Fman wrote: |
Bad bug wrote: |
Busstom wrote: |
Fman wrote: |
How tall are you? Do you like leaning forward for long periods of time? If not, you could always lengthen the post...but they made it short for the same reason you want four legs: stability.
By the way, that Tee-shaped 4-leg configuration doesn't present the foot-placement issue I spoke of earlier. |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Posted: Sat Jan 19, 2019 7:57 am Post subject: Re: Engine Stand |
ivwshane wrote: |
I have a type IV and this combo looks good. Any reason for the four arm yoke and not the three arm?
With the hydraulic cart, were you able to use that to remove/install your engine as well?
Dale M. wrote: |
Dark Earth wrote: |
Here's the setup I pieced together for my build.
I bought a 500 lb. capacity hydraulic table cart from Harbor Freight ...
... a 1250 lb. engine stand from Summit Racing ...
... and a four arm engine stand yoke from here on TheSamba.
They fit together nicely and allow the engine to be removed and mounted to the stand easily.
I drilled holes in the engine stand yoke 90º apart so I can rotate the engine on the stand and lock it into position with a pin.
Although there was a bit of expense involved, It’s all worth it to me. The engine came out smoothly and safely, the exchange to the engine stand went just as planned, and it's now stored safely out of the way.
Awesome combination of parts/assembly, don't know why
people struggle with cheapo stand that you can not get some sort of lift into to get engine up to working height...
Dale |
This is the best engine stand set up, I have seen so far. _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Fman Samba Member
Posted: Sat Jan 19, 2019 9:37 am Post subject: Re: Engine Stand |
Busstom wrote: |
Fman wrote: |
Bad bug wrote: |
Busstom wrote: |
Fman wrote: |
I am 6'0, I am sure it wont be a huge issue just something I read. I just ordered the VWT yoke. Going to place my order today for the Torin stand, it is on Amazon right now for $77 with free shipping. Great deal for a 4 leg 1500 lb stand that is also fold-able. |
Posted: Sat Jan 19, 2019 11:34 am Post subject: Re: Engine Stand |
I've been using a homemade three legged stand with an extended post for several decades now without issue..... |
Me too...I made my 3-leg stand in 10th grade, back in '81, and I was 6'3" back then! It's served me very well all these years. I recently finished a new 3-leg stand, and hell it looks oversquare in the pictures! But it's not, the center leg goes out 38" and the post comes up 36" to the yoke centerline. As soon as I get some paint on it, I'll post some pics of "old meets new."
Busstom wrote: |
I've used a 3-wheeled engine stand for 35 years... |
Sorry, I misspoke, that's 37 years now that I do the math |
