67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9665 Location: Oregon
Posted: Thu Dec 17, 2020 7:00 pm Post subject: Re: Engine Stand |
Well yeah. That way the elactrickery won't drain out!
Zundfolge1432 wrote: |
Will it run with coil upside down? |
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2172 Location: HdG, MD & NJ
Posted: Fri Dec 18, 2020 7:12 am Post subject: Re: Engine Stand |
That coil was put there for a five mile drive from my old house to my new house. I was trying out a single drla when I closed on the new house. Before that it had Weber ICT’s with the sideways coil mount. It also has a half empi and half solex carb.
And here’s my seating for the low stand.
_________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Fri Dec 18, 2020 8:14 am Post subject: Re: Engine Stand |
Looks good. I have an engine stand and a seat on rollers. Less deep knee bends needed to move around. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2190 Location: UK (South)
Posted: Fri Dec 18, 2020 2:35 pm Post subject: Re: Engine Stand |
Dale M. wrote: |
Who.Me? wrote: |
A bay bell housing bolts up to a cheap ebay engine stand. I just had to cut a couple of spacers to stand the case off enough to clear the lip to mate the halves.
When complete, just bolt up a starter motor to test run the engine...
How do you split the case with using full bell housing...
Dale |
I made spacers out of a scrap of 5 or 6mm steel. The triangular 'ear' in this picture is one of them. They're wide enough to set the case half out far enough to clear the lip. I made them long enough to spread the load around the flange.
Once the case halves were maded, I unbolted the completed case, removed the spacers and bolted it back up to the bell housing with all four bolts to avoid putting too much strain on the two bolts on one case half.
Edit. Found a picture of the spacers...
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
pnw1302 Samba Member
Posted: Sat Jan 09, 2021 1:38 pm Post subject: Re: Engine Stand |
this thread gave me an idea, when i started the project i bought an empi bench mount stand. 5 years (and a different house) later bigger garage, less bench. i went to HF and bought the 1000 pound 4-wheel (bad things can happen with three wheel stands) stand and cut the head off of the HF stand and the EMPI mount. sizzle, sizzle, spark and this is what i got.
wardvwracer Samba Member
Joined: July 19, 2002 Posts: 489 Location: De Pere, WI
Posted: Wed Sep 29, 2021 6:44 pm Post subject: Re: Engine Stand |
Anyone have any pics of their test run engine stand set up?
I have been working on a test run stand using a Type 2 bolt on bell housing. My plan is to have battery mount, small fuel tank from a snow blower, some sort of dash that will house the ignition switch, a tach, oil pressure gauge and some sort of throttle control.
The idea is to have a test stand to break in my engines that allows for easy tuning and access during the initial run in of a new engine.
Roy at MOFOCO has a stand that is similar to what I'm doing.
I'm also interested in the simple wiring of one.
Post them up please. Thanks! _________________ David Ward
ACME Berrien Buggy Street/Strip racer build
1963 Single Cab
1969 Beetle Convertible
63 11-Window Kombi Bus
Cornpanzers |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Wed Sep 29, 2021 6:48 pm Post subject: Re: Engine Stand |
wardvwracer wrote: |
Post them up please. Thanks! |
We have a dedicated topic on run stands:
https://www.thesamba.com/vw/forum/viewtopic.php?t=380203 _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Sep 29, 2021 7:21 pm Post subject: Re: Engine Stand |
Thanks Glenn. I did several searches before posting that and didn't see it. I appreciate you sharing the link. _________________ David Ward
1963 Single Cab
Cornpanzers |
Visje Samba Member
Joined: March 29, 2022 Posts: 1 Location: Netherlands
Posted: Tue Mar 29, 2022 4:18 am Post subject: Re: Engine Stand |
earthquake wrote: |
With the adapter I used to sell you could hang a ACVW on any V8 type stand with adjustable fingers...
and after you get the short block assembled you can add one to the other side and take the strain off the one side of the case
these adapters and case are on a three wheeled stand that has had two 460 fords rebuilt on it and it was never tippy
Man I wish I still had access to the waterjet machine.
eQ |
Are you willing to share the design for the adapter?
I'm currently restoring my VW Buggy and I would really like to have this made so I don't accidentally damage the casings. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Apr 06, 2022 11:27 am Post subject: Re: Engine Stand |
Visje wrote: |
earthquake wrote: |
eQ |
It not hard to make a drawing or take a case to some body make one or a pair, I would use 3/8" plate minimum but I like over kill, mine are 1/2"
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1501 Location: Buford GA
Posted: Wed Apr 06, 2022 4:34 pm Post subject: Re: Engine Stand |
Thanks for posting this !! I already have that hyd lift and soon I will have that engine stand from Summit and the 3 arm head from the classifieds !! |
dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Fri Apr 08, 2022 3:48 pm Post subject: Re: Engine Stand |
Wish I came across this thread before I bought my stand. Jegs 1000 lb with 4 casters. The buy a VW adaptor. Cut the old stand, weld on a new receiver, level to the ground.
I'm 71 and work alone. Sometimes I'll put a sign in the alley: Help Wanted. $25 to load or unload the engine out of my truck. Putting the engine on the stand today was fun. Got into some back alley engineering.
Out of the truck and onto the box.
Had to re drill the holes to get the cradle to mount.
Have to get the engine off the box and on to the lift, line it up and push. This was fun. I didn't want to "drop" my engine. Very careful.
Taadaa, ready to go to work.
As soon as it cools down a bit.
dgsaz |
pharos Samba Member
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1163 Location: San Angelo, Texas
Posted: Sun Jul 17, 2022 11:17 am Post subject: Re: Engine Stand |
dgsaz wrote: |
Your vertical support is on there backward. Looks pretty tippy to me.
dgsaz |
_________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
RCP Phx Samba Member
Joined: November 20, 2021 Posts: 496 Location: Phoenix,AZ
Posted: Sun Jul 17, 2022 12:03 pm Post subject: Re: Engine Stand |
rugblaster wrote: |
dgsaz wrote: |
dgsaz |
It sure is!!! |
Don Jones Samba Member
Joined: April 09, 2020 Posts: 198 Location: Makaha, Hawaii
Posted: Sun Jul 17, 2022 10:13 pm Post subject: Re: Engine Stand |
Here's my engine stand creation. Modified a Amazon Engine Stand.
Added a throttle lever to the right for breaking in camshaft. |
Posted: Fri Mar 17, 2023 11:42 am Post subject: Re: Engine Stand |
This isn't really an engine stand, but this thread seemed the right place to share it.
Space is a premium in my garage, so I use the bed of my Single Cab as a workbench. Manhandling a built engine to access either side is a pain, so I thought I'd try and find a turntable.
I looked at motorbike turntables, but they were more than I wanted to spend. Then I came across 'patient transfer turntables' on Amazon.
They're designed for careworkers to help people with limited mobility in and out of chairs and beds. This one is rated for 19 stone and only cost £15.
My wife and I tried it together (#worldscrappestmerrygoround) and it took our combined weight easily, so I added a couple of bits of plywood to protect the ABS and gave it a whirl . It works a treat...
Busstom Samba Member
Joined: November 23, 2014 Posts: 3790 Location: San Jose, CA
Posted: Wed Mar 22, 2023 5:51 pm Post subject: Re: Engine Stand |
^ ^ ^ Thanks for sharing. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
link7 Samba Member
Joined: November 18, 2023 Posts: 2 Location: Southern California
Posted: Wed Nov 22, 2023 11:14 am Post subject: Re: Engine Stand |
Does anybody know if Vintage World Tools or VW Alley is still selling the adapters?
I don't see any active classifieds or anything on ebay and the contact info I've tried has been unsuccessful. Looking for a 2 arm adapter for a super beetle engine to put on a Torin Big Red stand.
Thanks |
Millionmph Samba Member
Posted: Wed Nov 22, 2023 11:18 am Post subject: Re: Engine Stand |
what the hell is all this? whats wrong with a couple 4x4s and the kitchen floor? lol |
