Dead 1 Samba Member
Joined: October 31, 2005 Posts: 1374 Location: Burning shores of Lake Michigan
Posted: Wed May 20, 2009 7:09 am Post subject: |
I have been having small leaks coming from the acorn nuts down by the sump. When changing the oil a few days ago I applied Hylomar to the gaskets that goes on the strainer and then also applied Hylomar to the studs where the acorn nuts screw on. No more leaks! _________________ "I reject your reality and replace it with my own"
"The American Dream - true enough because you gotta be asleep to believe it"
71, 1776 cc. |
RanX0R0X Samba Member
Posted: Wed May 20, 2009 8:14 pm Post subject: |
Desertbusman wrote: |
RanX0R0X wrote: |
With oil pressure hitting 150+ psi |
Shut that sucker down . You have a problem. No wonder you've had oil cooler seal problems. |
I don't even have it together yet so I'm not seeing any oil pressure at all
That figure is from the Aircooled VW Interchange Manual:
"Be aware that even the stock oil system is capable of 150psi on a pressure gauge when the oil is cold. If a high-volume pump is used, especially in conjunction with aftermarket relief valves, pressures as much as 300psi are not uncommon when the engine is first fired up, even when the stock by-pass (relief) valve is used!...." |
Desertbusman Samba Member
Posted: Wed May 20, 2009 10:02 pm Post subject: |
RanX0R0X wrote: |
No pressure at all- better shut it down
I just plain don't know what to think about that other stuff thou. ; Sure, if the relief is stuck closed. But I just plain can't imagine it if the valves are functioning. _________________ 71 Superbug
71 Westy |
Posted: Tue May 26, 2009 1:00 pm Post subject: |
I just plain don't know what to think about that other stuff thou. ; Sure, if the relief is stuck closed. But I just plain can't imagine it if the valves are functioning. |
Yeah, I was surprised too. I have read on Aircooled.net that they recommend synthetic due to better cooling properties. Since VWs use oil and air as primary coolers that seems logical.
Another site recommend 10W-40 dino oil for new engines because it flows well.
I'm going to run synthetic and change it 1k miles or less. While synth is more expensive, the VW engine doesn't use that much and oil is critical to the engine and engine life. An oil in 5w50 is going to flow very well when cold and cool better after the engine heats up. |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Tue May 26, 2009 1:18 pm Post subject: |
79SuperVert wrote: |
My 40hp 1200 "sweats". Doesn't drip, but there always seems to be a drop on one or two of the acorn nuts on the oil sump plate, and always a drop on the bottom of the bellhousing. Never actually drops off. Just hangs there. |
Me too. Last year it was "drip, drip, drip" from a few places but I found out the front crankshaft seal had gone and was letting oil out into the fan and spraying it EVERYWHERE! After I fixed that and cleaned the mess up she's been pretty constant with oil consumption and where she leaks (A drip here and there at the sump plate and occasionally the oil filter). But like 79SuperVert said, it mostly "sweats". _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
Hippie Samba Tinner
Joined: August 16, 2004 Posts: 1781 Location: Iowa: The Mud State
Posted: Tue May 26, 2009 5:02 pm Post subject: |
Mine only leaks to the point of dripping on the ground with full synthetic. |
Posted: Sat Jun 06, 2009 10:40 pm Post subject: |
I was just reading a tech note on Gene Bergs site and his comment was that the 150 psi readings and up were taken at the oil pump. By the time a standard oil gauge reads it it has passed through relief valves and other restrictions reducing it to a nominal 40 psi.
http://www.geneberg.com/article.php?ArticleID=243
But the problem is at the pump outlet itself. If the oil is too cold and slow flowing the pressure shoots up.
That's more my concern than the synthetics heat or engine wear protection. Those are wonderful characteristics but for our little flat fours it's the oil pressure and the squirrely little valve and routing systems that tell the real problem -- oil pressure.
Cold oil is thick and syrupy and hot oil is runny. The enigma faced by the original designers. We don't face that problem. A good synthetic flows the same no matter the temperature. |
spiderjames Samba Member
Posted: Sun Jun 07, 2009 11:42 am Post subject: |
I am no professional mechanic but have built maybe 1/2 dozen or so full rebuilds over the years, and too many partial rebuilds to count 'em. I have found that when motors are new and properly assembled they don't leak. At least initially. Leaks usually accur at the same places and indicate something needs to be looked at, replaced or retorqued. I generally use permatex on most gasket areas and it seams to decrease/postpone most leaks. here's what I have notice over the years regarding common leaks for what it is worth.
CASE HALVES:
In theory they shouldn't need any sealant at all since they are machined in pairs. In practise I have always used aviation permatex and blue locktite and don't have trouble if the torquing sequence is followed properly. In older motors that are seeping sometimes just a retorquing of all the case bolts is enough to stop it.
VALVE COVERS:
I use some fine sand paper on a block and smooth the sealing surfaces on the heads. Then put permatex (any good sealer would probably work here) between the seal and the cover. No sealant between the gasket and the head, just a film of oil. I use off the shelf gaskets whatever is available and reuse them a couple times when doing valve adjustments. My covers never leak.
OIL COOLER:
No tricks here. Just need to use the correct seals. I don't use sealant here. My experience has shown me that trying to use a SP oil cooler with a late model case just doesn't work well even with those fancy adaptar seals. They just never hold up for me. I get best results using a single relief case for SP applications. For DP applications either case is fine as the above mentioned seals work fine for adapting earlier cases to doghouse type applications.
PUSHROD TUBES:
I have found that leaks here usually indicate that the heads need to be retorqued. Some sealant on these will help to delay the leaks a bit.
FRONT MAIN SEAL:
If this is leaking you just gotta pull the engine a replace it. While you are at it check the endplay and retorque everything.
OIL SCREEN:
I put a tiny bit of permatex just around the outside edges of the paper seals. They still seem to seep a bit.
GENERATOR STAND:
I dont usually have an issue here if torqued properly. Old engines usually just need the nuts tightened and the leaking will go away
FUEL PUMP:
I usually don't have trouble here either. again just some seepage usually.
Did I miss anything?
Remember this is just my two cents worth based on my experience, but if a motor is new and I assembled it properly it usually doesn't leak. As the motor ages if I pull it occassionally, like for valve jobs and the like, and retorque eveything properly even an old motor wont leak much. Maybe just some seepage which is easily taken care of with routine cleaning s(purple power). |
enjoispammy8 Samba Member
Joined: December 26, 2007 Posts: 1984 Location: Long Beach, CA
Posted: Sun Jun 07, 2009 12:50 pm Post subject: |
mines got a leak, im not sure exactly where from yet. but im betting its the seal behind the flywheel. _________________ 1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Is there a message here? Enjoy Spammy Ate |
EZ Gruv wrote: |
Way to fuck up some little kids riding in the car next to you. |
hazetguy wrote: |
you need to be doing better drugs. |
reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1927 Location: Bloomington, IN
Posted: Thu Nov 12, 2009 7:11 pm Post subject: |
My engine seems to have developed a leak and it appears to be the front main seal (says rear here).
Quote: |
There is also a seal between the crankshaft and the flywheel called the rear main seal. Many busses leak there because the seal was installed incorrectly or they used a cheap seal. This seal is a nuisance because it means dropping the engine and removing the flywheel. |
Are the reinz seals from Bus depot OK or is the Elring Klinger seal better. I have already had it replaced once before and will do it myself this time so I know what is used for it. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
Rusty O'Toole Samba Member
Posted: Thu Nov 12, 2009 7:29 pm Post subject: |
An old time aircraft mechanic taught me to put Harley crankcases together with Permatex #2 and a silk thread laid on the middle of the joint O ring style. I think he learned this in the 1930s.
The dental floss sounds like the same idea. If this is the case, the thing to use would be small round waxed floss, any flavor. |
TheRustySuper Samba Member
Joined: June 24, 2009 Posts: 2076 Location: New Albany, IN
Posted: Thu Nov 12, 2009 8:27 pm Post subject: |
My stock 1600 leaks...not badly, and not all from one particular spot. Just slow, steady leaks from all around the engine. I don't think the case has ever been split, 104,xxx miles. No puddles or anything, just a few drops. _________________ My '72 Super |
vw donvieira Samba Member
Joined: May 11, 2004 Posts: 617 Location: stockton, California
Posted: Sun Nov 22, 2009 11:23 am Post subject: |
Yes the silk thread and waxed floss are tricks that John Hayes taught me to keep the cases sealed. They work really well. vwdon |
TrickyThom Samba Anarchist
Posted: Sun Nov 22, 2009 4:38 pm Post subject: |
TheRustySuper wrote: |
My stock 1600 leaks...not badly, and not all from one particular spot. Just slow, steady leaks from all around the engine. I don't think the case has ever been split, 104,xxx miles. No puddles or anything, just a few drops. |
I also have almost 90K on original engine. Maybe 2 drops after driving hard for 3+ hours in hot conditions.
Other than that, nothing. Neither did my last buses after I rebuilt the engines. _________________ 1977 Riviera |
Posted: Sun Nov 22, 2009 7:08 pm Post subject: |
I just bought a SABO seal for mine. Hopefully this will do it. That and I will double check the flywheel to make sure it isn't grooved. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
hamid Samba Member
Posted: Sun Dec 26, 2010 7:13 pm Post subject: oil leak |
HI
I recently got a 78 bus. it was just leaking few drops right under the engine while the engine was runing. then the engine was dropped by bunch of not so honest mechanics for puting on a new trany. then, I took the bus home. now when the engine is on. I can see the oil driipping on the passenger side right under the head cover. can you help diagnose this. when the engine is not running there is NO leaking. help thanks. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Sun Dec 26, 2010 7:55 pm Post subject: Re: oil leak |
hamid wrote: |
HI
Eithor the valve cover or the push rod tubes. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
hamid Samba Member
Posted: Sun Dec 26, 2010 10:47 pm Post subject: oil leak |
thanks
I will check those and reply later. thanks a lot |
Randy in Maine Samba Member
Posted: Mon Dec 27, 2010 7:49 am Post subject: |
Also make sure the VW logo on the valve covers is upside down. |
hamid Samba Member
Posted: Mon Dec 27, 2010 9:08 am Post subject: oil leak |
thanks
I have to get under the bus and check things out. if it is the push rod tubes what is to do? I hope I do not need to do a valve job now! thanks |
