MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Mon Apr 07, 2008 3:36 pm Post subject: Exhaust sealing issues |
I've been working the entire day to get my new (Dansk) heater boxes (72-74) to fit my heads (2.0l heads, AMC casting)
I have read Ratwell's write up on this subject which was very helpfull and pretty much every related forum post. I'm still having problems to get a good seal.
I have two questions;
1. When the exhaust is seated do to the 2 flanges have to be seated aswell? Or is is ok to have a little space between the head and the flanges?
2. I put the exhaust studs into the heads with the indicated torque value. However, the lower threads aren't completely in the head. Since the lower thread is a bit wider, this could pose a problem if the holes in the heater box flanges are too small, here's a picture:
_________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Mon Apr 07, 2008 3:42 pm Post subject: |
If there is any space, you will have an exhaust leak. That stud should be flush with the surface of the head. I would think the heater box isn't seating because it's hitting the shoulder of that stud before it hits the head. I would try to get it flush with the head, or maybe just open up the holes in the heater boxes just at the end so it will sit flush. |
Ritter Samba Member
Joined: March 10, 2005 Posts: 383 Location: Sonoma County, CA
Posted: Mon Apr 07, 2008 3:42 pm Post subject: Re: Exhaust sealing issues |
MadMax78 wrote: |
1. When the exhaust is seated do to the 2 flanges have to be seated aswell? Or is is ok to have a little space between the head and the flanges? |
The two flanges (where the bolts go through) should not seat. In fact, if they do, you'll need to file some off of the mating side. There needs to be clearance to ensure the gasket gets squished and fills up any little voids. This won't happen if the flanges are making contact with the head first. Make sense?
As for your second question, I would await a more qualified responder. It doesn't look right though. _________________ -------
1978 westy 2L FI (needs a little bit less work) |
busdaddy Samba Member
Posted: Mon Apr 07, 2008 4:20 pm Post subject: |
The outer bosses on the heat exchanger flanges don't meet up tight with the head but could be hanging up on the stud. Have you ran it and heard a leak or are you still assembling?
You may need to grind a bit off the head end of that stud to get it down flush if you think it's hanging up.
Anneal the gaskets with a propane torch (blue heat, air cool) before installing as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Apr 07, 2008 4:21 pm Post subject: Re: Exhaust sealing issues |
[quote="Ritter"]
MadMax78 wrote: |
I understand that this has to happen, on the other hand, what would happen if force is exerted on the heater boxes (i.e. when lifting the engine), this would cause a force to push on one side of the gasket. This would squash the gasket on one side and cause a leak. If the flanges would have been seated the heater box can't tilt so this won't happen...
Does anyone know if it's normal on new AMC heads that the threads aren't flush with the head?
Thanks for the replies so far _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Ritter Samba Member
Posted: Mon Apr 07, 2008 4:35 pm Post subject: Re: Exhaust sealing issues |
MadMax78 wrote: |
what would happen if force is exerted on the heater boxes (i.e. when lifting the engine), this would cause a force to push on one side of the gasket. This would squash the gasket on one side and cause a leak. If the flanges would have been seated the heater box can't tilt so this won't happen... |
Got me there! I don't know as I had the experience of doing mine laying on my back under the bus. It was super fun! _________________ -------
Posted: Mon Apr 07, 2008 4:47 pm Post subject: |
busdaddy wrote: |
Anneal the gaskets with a propane torch (blue heat, air cool) before installing as well. |
I'm still assembling (testing for leaks with compressed air), I just want to make sure that the exhaust pipes sit flush on the head before I anneal the gaskets and crush them. Taking of the head end of the studs is an option, maybe my only one...
At the moment I can get a seal which looks ok by eye and no blowby can be felt by hand. However, some leak detector revealed a lot of bubbles. Maybe the studs are just about 2mm out of the head and this is about the thickness of the gasket, causing a small leak. I guess taking down the studs should fix this.
I'm glad my engine is in a stand and not under my bus _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
CarlSpackler Samba Member
Joined: December 12, 2005 Posts: 665 Location: Mason, Ohio
Posted: Tue Apr 08, 2008 8:18 am Post subject: |
Drill your flanges larger on the side where the interference is occuring so they'll clear the threads. You can run it all the way through too, if you wish, but at the very least, drill them out to 9mm for a cm or so into the flange. _________________ '67 Micro Bus
'73 Thing
'91 Westy |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Tue Apr 08, 2008 9:12 am Post subject: |
Busdaddy is right about the gaskets needing annealed, but you must heat it beyond blue, copper requires being heated to a dull red, then either air cooled or dropped it in water if you are in a hurry, it makes no difference how you cool it. |
Randy in Maine Samba Member
Bursch Samba Member
Joined: October 28, 2006 Posts: 448 Location: Netherlands
Posted: Tue Apr 08, 2008 5:16 pm Post subject: |
Spent another day on the HE's...
The Dansk repro is a bitch. The bend in the exhaustpipe of the 1/2 HE was way off, creating a mismatch on my header and engine tin and hitting the mustache. Spent a few hours carefully filing the sealing area 2mm down on one side to compensate.
Anyway, gone through the whole process of filing/marking/filing/marking/filing/etc. I'm still in the fase of test fitting with the un-annealed seals. When torqued to spec it's still leaking noticeably. Is it even possible to obtain a proper seal without annealing and using locktite 518? _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply, Busted Bus & Aircooled Technology
2014: New York - Rio de Janeiro - FIFA World Cup -- 28.000km
Posted: Tue Apr 08, 2008 5:27 pm Post subject: |
You do realize having more than one account is against the Forum Rules don't you??
The Rules wrote: |
"DON'T create more than one account for any reason. If you have multiple accounts:
You may request to have older accounts consolidated
We will eliminate your duplicate account
Violating this rule may lead to deletion of ALL your accounts and Classified Ads" |
Posted: Tue Apr 08, 2008 5:28 pm Post subject: |
Why don't you pull your offending studs and measure the depth of the bore verses the length of the threads on the studs. You should be able to determine is it would be better to run bottom tap into the hole or the grind off the end of the stud a little.
Sorry you are having so much trouble with the aftermarket exchangers. I wish Bus Depot or someone would find a company to manufacture new shells for the old exchangers, a SS or at least a more corrosion resistant shell would be nice. |
nebe Samba Member
Joined: October 08, 2007 Posts: 450 Location: Rhode Island
Posted: Tue Apr 08, 2008 7:31 pm Post subject: |
busman78 wrote: |
It does make a difference how you cool it. If you quench it in water, your going to harden the metal. |
Posted: Tue Apr 08, 2008 8:22 pm Post subject: |
Don't feel bad, I had to go at a set of OG "F" tubes today with a pipe wrench, vice and portapower, didn't take much tweeking but once the twist was gone and they were spread out a bit they fit soooo much nicer.
Do yours slide down the studs nicely or are they a battle from the first thread?
You're right Busman, dull red is the right heat but I've always been taught to allow to air cool unless you want to harden it, at least for non ferrous metals. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Apr 08, 2008 8:56 pm Post subject: |
Copper does not react the same as ferrous metals, a water quench does not harden the copper after annealing. |
Posted: Tue Apr 08, 2008 9:57 pm Post subject: |
busman78 wrote: |
I can verify that....I quenched mine in water last summer when I redid the exhaust on my '74. They were still very soft and the exhaust sealed up with no leaks. |
Bursch Samba Member
Posted: Wed Apr 09, 2008 4:25 am Post subject: |
Drilled a large hole in the bottom of the flange, making room for the studs. They slide on pretty nice, only need a gentle tap when almost seated. Gonna work on that a little more, so they'll just slide into place with the gasket being the fist thing they hit. Grinded down the flanges so that there is over 1mm of play before the flange hits the head. This should give enough room for the gasket to crush.
Need to do some more clearance work where the HE's meet up with the fan shroud. Did all the fitting with the fan shroud removed.
VDubTech wrote: |
You do realize having more than one account is against the Forum Rules don't you?? |
Dont worry, Madmax is my brother. Together we're prepping our bay for beijing! _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
82-T/A Samba Member
Joined: March 23, 2004 Posts: 183 Location: Fort Lauderdale, Florida
Posted: Wed Apr 09, 2008 5:50 am Post subject: |
Just a thought, but have you checked to make sure that the flanges are flush with eachother? If they're slightly off, it would cause a leak. This is usually corrected by taking it to a machine shop where they put it on a belt sander, or a sanding disk and make the mating surface of both flanges completely flush. _________________ Todd,
(Fun cars)
2002 Ford Crown Victoria LX-P74
1987 Pontiac Fiero SE / V6
1973 Volkswagen Type-2 Transporter |
Bursch Samba Member
Posted: Wed Apr 09, 2008 6:49 am Post subject: |
82-T/A wrote: |
Just a thought, but have you checked to make sure that the flanges are flush with eachother? If they're slightly off, it would cause a leak. This is usually corrected by taking it to a machine shop where they put it on a belt sander, or a sanding disk and make the mating surface of both flanges completely flush. |
You mean the sealing area? Did the large bastard file thing, ratwell style. So yes, they are as flush with each other as i can get them. Even rotated the file every few strokes to make up for any imperfections on the file (no noticeable imperfections, but you never know) _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
