BarryL Samba Member
Joined: November 01, 2004 Posts: 14259 Location: Casa de Oro, California
Posted: Tue Aug 22, 2017 10:02 am Post subject: Re: VW Bus air cleaners |
nebkv wrote: |
I have this unusual front tin with hole for pre heating on right(passenger)side
I'm almost sure it's from the 40HP engine
With original hole for pre heating
The bug 40HP had no hole for preheating to the right
Bus had, but as far as I know, it was only during 66-67 on 1500 engines
Also, as far as I know in 1966-1967 there was no bus with 40HP engine
For which air cleaner-pre heating sistem it can be? |
If it's a factory hole then it's the ultra rare '67 only front tin. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24737 Location: Olympia Wash Rinse & Repeat
Posted: Tue Aug 22, 2017 10:20 am Post subject: Re: VW Bus air cleaners |
By the pressing it does not look 40 HP.
70 CM both 40 HP and 1500/1600 have same dimension width there.
Where they would be different is from just inside the forward exhaust pipes. _________________ In Stereo, Where Available! |
nebkv Samba Member
Posted: Tue Aug 22, 2017 11:13 am Post subject: Re: VW Bus air cleaners |
Eric&Barb wrote: |
Where they would be different is from just inside the forward exhaust pipes. |
You're right
I did not pay attention to that part
I thought the range between fixing holes was different,like that on rear tin
So this is definitely for 1500 66-67 |
BarryL Samba Member
Posted: Tue Aug 22, 2017 6:44 pm Post subject: Re: VW Bus air cleaners |
nebkv wrote: |
'66 is one year only and hole is on rear tin right side. |
D-train Samba Member
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
aerosilver Samba Member
Posted: Mon Apr 02, 2018 12:08 pm Post subject: Re: VW Bus air cleaners |
Found this one recently..
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2207 Location: UK (South)
Posted: Thu Apr 12, 2018 5:50 am Post subject: Re: VW Bus air cleaners |
I noticed yesterday that the flap on my single cab's oil bath is always open. Like this...
(Same oil bath, but mine has the breather pipe on the other side of the bowl).
The flap handle isn't tied open. The bob weight is in such a position that it holds the flap open at rest, rather than closed. The hooked arm and bob weight point in the same direction toward the body of the cleaner.
Before I go bending stuff, was there ever a legitimate reason for that, or has it just been messed with by a previous owner? _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Thu Apr 12, 2018 7:42 am Post subject: Re: VW Bus air cleaners |
Yes, no bendy required, just flex it off that point. _________________ In Stereo, Where Available! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Thu Apr 12, 2018 8:31 am Post subject: Re: VW Bus air cleaners |
Who.Me? wrote: |
Normally the flap is closed and opens if you hit the throttle hard. Having warm air enter the carb is important for several reasons- it increases the vaporization of the fuel which results in a better running engine without stumble/hesitation, and helps prevent icing of the carb in cool damp climates like yours. You should notice a difference in how it drives once you fix this. There's also a heat riser tube under the carb (which is commonly clogged) to add heat but I think the warm air inlet to the air cleaner is equally or more important that the tube under the carb.
It looks like someone has mangled yours in a previous life. Unmangle it so the balance weight just barely keeps the flap closed, and it should open when you gun it.
Good Luck! _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Posted: Thu Apr 12, 2018 9:53 am Post subject: Re: VW Bus air cleaners |
Thanks, I should have been clearer. That photo wasn't my air cleaner, it was a picture from the gallery.
Mine is below. The bob weight is parallel with the hook arm, rather than opposing it, so the flap stays open all the time. From the answers though, I'm sure this is screwed up...
Posted: Thu Apr 12, 2018 10:24 am Post subject: Re: VW Bus air cleaners |
Who.Me? wrote: |
Thanks, I should have been clearer. That photo wasn't my air cleaner, it was a picture from the gallery. |
Bend the weight toward the end of the snout so it just closes up the flap. Then contact the owner of that first image you posted and see if you can do a trade of air cleaners!! _________________ In Stereo, Where Available!
Posted: Thu Apr 12, 2018 10:31 am Post subject: Re: VW Bus air cleaners |
Eric&Barb wrote: |
Then contact the owner of that first image you posted and see if you can do a trade of air cleaners!! |
Clara Samba Member
Posted: Thu Apr 12, 2018 11:36 am Post subject: Re: VW Bus air cleaners |
Who.Me? wrote: |
NOS flaps:
Posted: Thu Apr 19, 2018 3:33 am Post subject: Re: VW Bus air cleaners |
Ok so for this one here, some documents have been found. thanks to John In2vws.. note the differences with the clips, the breather tube in the bottom, and also the rocking horse shit rare metal caps for the heater hose holes!
_________________ shiny paint doesnt make it worth any more |
gonzalo Samba Member
Posted: Tue Nov 26, 2019 9:01 am Post subject: |
hazetguy wrote: |
dusty conditions/cyclone filter
i'm sure RickC has more pics/info of this set up. |
I have this same setup in a 63 double cab delivered to Chile (dusty conditions )
anyone know where I can find the rubbers? specially the one from the cyclone to the engine tin.
thanks! _________________ 1976 VW Safari | 1963 VW Kleinbus Crew Cab | 1973 VW Super Beetle 1303 /German Look/
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Wed Nov 27, 2019 8:49 am Post subject: |
gonzalo wrote: |
hazetguy wrote: |
thanks! |
The upper one looks like a stock rubber connector:
And the lower one, possibly this style, cut to fit?
_________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
