Assistance With Pricing
Adriel Rowley
Adriel Rowley is offline
PostPosted: Thu Apr 10, 2008 1:53 pm    Post subject: Assistance With Pricing Reply with quote
On Sunday I went to the Bug-In, and purchased a box of fuel injection stuff for the large sum of $10. Now that I have gone through and cleaned, "rebuilt", and took inventory of everything, I would like help on pricing. Oh, and I have a question: when I started to remove the cold start injector, I noticed part of the plastic gasket was missing. After cleaning it, I think it is too far gone to prevent a vacuum leak. Can I make a new gasket from a Cheerios box?
Now, onto the inventory:
8 fuel injectors- four appear good except for the hoses, and the others have excessive heat scarring and will be turned in as cores
4 metal injector plates
3 plastic injector plates
7 original sleeves/bushings
4 runners- paint is shot, and there is light surface rust on two Should I sand blast them?
2 T.P.S.es- one 4 pin and one 5 pin
2 fuel pressure regulators
2 of an unknown, with a part number of 311 900 161C and 033 6003 008
1 mystery bracket (will get pictures later)
1 manual A.A.R.
1 manual transmission throttle body (the device between the runners)
1 automatic transmission throttle body (the device between the runners), with a strange bracket and do hicky bolted on it that has a rod on the throttle that it works with
1 AG distributor
1 H (automatic) distributor
I am sorry this is so long, but any assistance would be greatly appreciated. Very Happy Oh, and explanation of the auto. throttle body would be nice: it has got my curiosity.
Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation
VdubNewgye
VdubNewgye is offline
PostPosted: Thu Apr 10, 2008 3:09 pm    Post subject: Reply with quote
Ill tell ya what. Ill give you 10$ and pay shipping to get it to me. Smile
Russ Wolfe
Russ Wolfe is offline
PostPosted: Thu Apr 10, 2008 5:26 pm    Post subject: Reply with quote
Give him $20 you cheap skate!!
Wink Wink Wink
Gary: OK. Ima poop.
Adriel Rowley
PostPosted: Thu Apr 10, 2008 7:56 pm    Post subject: Reply with quote
No, I would not break even, because I payed $20 to get in! Wink Laughing
Russ, would the cardboard gasket work?
Russ Wolfe
PostPosted: Thu Apr 10, 2008 10:13 pm    Post subject: Reply with quote
It should. That is not a hot area, just a vacuum area.
Gary: OK. Ima poop.
Adriel Rowley
PostPosted: Fri Apr 11, 2008 7:30 am    Post subject: Reply with quote
Now I love Cheerios even more! Wink Laughing Thank you, Russ, it worked like a charm!
SquareTone
SquareTone is offline
PostPosted: Fri Apr 11, 2008 8:00 am    Post subject: Reply with quote
Are you talking about a black micro-switch attached to the left side of the unit? If so, then that's the kickdown switch for the automatic (also known as an utterly useless part stuck on so that you have something else to break and more wires strung around).
Tony
'70 Fastback AT/FI (daily driver (exept when the starter won't work, or it's out of gas, or I don't go anywhere, ...))
"...it is a well known fact, that those people who most want to rule people are, ipso facto, those least suited to it."
Help Improve TheSamba
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Apr 11, 2008 8:07 am    Post subject: Reply with quote
My kickdown switch works great! Definitely not "useless".
SquareTone
PostPosted: Fri Apr 11, 2008 9:19 am    Post subject: Reply with quote
Oh, they work fine. They're just not needed. In fact, I read somewhere that the tranny overrides the switch above something like 50mph. The spring loaded throttle lever on the automatics is a good feature though. Nice way to reduce cable breaks.
Tony
Adriel Rowley
PostPosted: Wed Apr 16, 2008 2:51 pm    Post subject: Reply with quote
Thank you for you alls assistance! Very Happy
It is in a bracket, but it has no wires. Today I found one in the adds:
http://www.thesamba.com/vw/classifieds/detail.php?id=556598. What does it do? How does it work? I ask because I want to make sure it is set up right, for now it seems like it is doing nothing.
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Wed Apr 16, 2008 4:11 pm    Post subject: Reply with quote
If they weren't needed, the engineers wouldn't have put them on the car.
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
Adriel Rowley
PostPosted: Wed Apr 16, 2008 4:29 pm    Post subject: Reply with quote
I am so glad to hear you say that! That has being my philosophy...and I though I was the only one! Laughing
Now, if I knew what they were intending with the modulator valve...
Tram
Samba Socialist
Tram is offline
PostPosted: Wed Apr 16, 2008 8:52 pm    Post subject: Reply with quote
The modulator valve uses engine vacuum to regulate shift points. For example, your car should shift thru the gears faster on the flat than going up an incline.
Russ Wolfe
PostPosted: Wed Apr 16, 2008 9:44 pm    Post subject: Reply with quote
If the trans is adjusted right it will kick out about 60 mph
Gary: OK. Ima poop.
Russ Wolfe
PostPosted: Wed Apr 16, 2008 9:47 pm    Post subject: Reply with quote
Get us a picture of yours. The modulator is not mounted in a bracket. It is screwed into the trans. I think what you are describing is an anti-backfire valve on the very late cars only.
I have a box full of those. NOS. They do kind look like a modulator valve.
Gary: OK. Ima poop.
Adriel Rowley
PostPosted: Sat Apr 19, 2008 7:34 pm    Post subject: Reply with quote
four fuel rails
4 runners- paint is shot, and there is light surface rust on two. Should I sand blast them?
1 mystery bracket
VdubNewgye
PostPosted: Sat Apr 19, 2008 9:47 pm    Post subject: Reply with quote
that mystery bracket is what the acceleration spring is connected to to get its stretch, the mystery metal piece goes right behind the T.P.S., not sure what it does... I was told at one time but forgot. has a certain name.
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Sun Apr 20, 2008 12:52 am    Post subject: Reply with quote
i second the mystery bracket, it bolts where the AAR sits and is the spot for the return spring to hook to.
those two mystery switches with the 1 prong are thermo switches for the cold start system.
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
Adriel Rowley
PostPosted: Sun Apr 20, 2008 8:45 am    Post subject: Reply with quote
Thank you for the replies! Very Happy Very Happy So, any one know if the part on the throttle body is an anti-back fire device?
Russ Wolfe
PostPosted: Sun Apr 20, 2008 8:49 am    Post subject: Reply with quote
architect_7 wrote:
Going to take up a lot of band width doing it this way, but.
Correct
correct
four fuel rails
correct. The 2 uppers are right side only. extra fitting goes to the cold start valve.
the one on the left is probably bad. not a good sign that the adjuster is screwed all the way in.
Thermo switches for the cold start valve. One is T-3 the other I thnk is 914 Porsche {/b]
1 mystery bracket
[b]Throttle return spring anchor as others have said.
That is not an automatic throttle body, just a late 72/73 with the deceleration dampner
Gary: OK. Ima poop.
