kbwakesk8 Samba Member
Joined: December 08, 2005 Posts: 1499 Location: Hacienda Heights CA
Posted: Thu Apr 10, 2008 3:46 pm Post subject: Questions about 3.5L v6 honda. |
who out there is running a 3.5L v6 honda Im putting together my fuel system What fuel pump are you running What kind of presure do i need. What regulator type are you useing. pic would be sweet. |
npetric Samba Member
Posted: Mon Apr 14, 2008 7:48 pm Post subject: |
Use the napa p5000 pump. The factory fuel rail has a reg. on it |
Posted: Mon Apr 14, 2008 9:46 pm Post subject: |
npetric wrote: |
Thats part of the problem my motor doesn't have a stock Fuel rail. it require an external regulater. |
Posted: Tue Apr 15, 2008 6:57 am Post subject: |
Which 3.5 do you have? What kind of fuel rail is on it? As far as I know there arent many aftermarket fuel rails for the j-series honda motors. |
Posted: Tue Apr 15, 2008 7:03 am Post subject: |
I might have an extra fuel rail laying around |
Posted: Tue Apr 15, 2008 8:59 am Post subject: |
npetric wrote: |
That would be sweet |
Posted: Tue Apr 15, 2008 10:48 am Post subject: |
just let me know which 3.5 you got.....i will check the piles |
Posted: Tue Apr 15, 2008 10:50 am Post subject: |
pic of my motor i bought befor we pulled it out of the sand car
i think they said 2000 or 2001 piolet |
Posted: Tue Apr 15, 2008 10:56 am Post subject: |
Are you running it with the intake reversed like that?(it makes a difference on what fuel rails to use) |
Posted: Tue Apr 15, 2008 11:01 am Post subject: |
Yes Im running it just like that. |
Posted: Tue Apr 15, 2008 11:04 am Post subject: |
I will see what I have. When you get a chance take a pic of the ends of the fuel rails for me. I might even have a aftermarket fp reg. laying around we could get to work for ya |
Posted: Tue Apr 15, 2008 11:18 am Post subject: |
ok sweet |
Posted: Thu Apr 17, 2008 1:30 pm Post subject: |
npetric wrote: |
My girlfriend has my camer the end of the fuel rail is eather a -8,-6 A.N. fitting. |
DesertGuy Samba Member
Joined: June 07, 2006 Posts: 149 Location: Palm Springs, CA
Posted: Thu Apr 17, 2008 1:50 pm Post subject: |
Is the AN fitting on the fuel rail itself, or is it just an AN banjo fitting off the regulator on a stock fuel rail?
In the pic, my fuel line coming from a 30Micron filter goes to the banjo fitting
[/img] |
Posted: Thu Apr 17, 2008 2:23 pm Post subject: |
The Fuel rails are looped togeter. And the AN fitting is is part of the fuelrail.
I drew a pic hope it helps |
Posted: Thu Apr 17, 2008 3:31 pm Post subject: |
its set up just like this motor |
