Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Apr 15, 2008 9:02 am Post subject: |
Just found it.
If you have a 10mm case, and an 8mm cooler, you use the spacer washers.
If you have a 8mm case and a 10mm cooler, you DO NOT use the spacer washers.
The 10mm cooler has the "spacer" built in to the bottom stamping.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
ed stanley Samba Member
Posted: Tue Apr 15, 2008 9:54 am Post subject: |
Good research, Russ! In all the years I've had beetles, I did not know this and i'll bet some others didn't either. Thanks for taking the trouble. |
Posted: Tue Apr 15, 2008 10:49 am Post subject: |
ed stanley wrote: |
Being knowledgable is not know everything. It is knowing where to find the information.
I have a bookcase full of VW manuals and old parts catalogs.
I am in the process of scanning them into digital format. 4 CD's full already.
Searchable PDF format. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Tue Apr 15, 2008 12:31 pm Post subject: |
How much for copies of those CDs?!!! |
CASON Samba Member
Joined: April 13, 2007 Posts: 293 Location: jacksonville fl
Posted: Wed Apr 16, 2008 5:34 am Post subject: |
icekoffee,
How many Quarts of oil did you put in ? You may have the wrong dipstick and over filled the engine with oil. That was the culprit in my situation. To much oil was in the case so it exited throughout the crankshaft pulley due to the wrong readong of oil on the dipstick. |
Posted: Wed Apr 16, 2008 8:20 am Post subject: |
I posted this in another forum, possibly here. All air cooled T-1 dip sticks are the same. 36hp thru to the last. I pulled out some that i had and compared them. 36hp, 40hp and late model with the bigger loop. The marks all line up. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
CASON Samba Member
Posted: Wed Apr 16, 2008 9:14 am Post subject: |
There are different length dipsticks, as you saw in the thread you posted in. I had a short 6" dipstick and should have had a 7". He could have the wrond one in his case. |
Posted: Wed Apr 16, 2008 9:20 am Post subject: |
What enging does that short dipstick fit in?? I have never seen one in over 40 years of working on VW's.
The 3 I posted actually came out of engines i have in the shop, and they were seated in their holes. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
CASON Samba Member
Posted: Wed Apr 16, 2008 9:25 am Post subject: |
I dont know ,but even the picture he posted showed different sized dipsticks. I had that shorter one which was incorrect. 40 years or not , someone made a 6" dipstick that not only myself, but others have seen as well. I dont have an answer to what it fit. |
Posted: Wed Apr 16, 2008 9:26 am Post subject: |
Those ones I posted were all the same length from the ferrel to the end of the stcks and the marks lined up.
Maybe the 6" is some hotrod chrome made in china BS. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
CASON Samba Member
Posted: Wed Apr 16, 2008 9:29 am Post subject: |
LOL Thats funny that you said that, because mine was chrome. PO had it in there. Thats probably why. |
icekoffee Samba Member
Joined: March 14, 2005 Posts: 1239 Location: DeSoto, Missouri
Posted: Thu Apr 17, 2008 3:36 pm Post subject: |
guess what... i measured my dip stick... it is 6 inches long. does that mean my problem is too much oil? (i am using an H case) _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1958 Patina Beetle EJ25
1984 Vanagon Westfalia EJ25
1964 Lifted Mouse Grey Standard
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Thu Apr 17, 2008 9:58 pm Post subject: |
The distance you need to measure is from where it seats on the dipstick hole in the case to the high and low marks. |
CASON Samba Member
Posted: Fri Apr 18, 2008 5:03 am Post subject: |
icekoffee: Do you remember how much oil was put in the case? How many quarts ? Someone may have over filled it using your dipstick not knowing that you should only have 2.5 to 3 quarts in it. If not then do yourself a cheap favor and drain the oil and refill it yourself. Oil is not too expensive and it will also single out the problem of being overfilled. |
