55veedub Samba Member
Joined: May 12, 2008 Posts: 583 Location: North Bay, Ontario, Canada
Posted: Wed Apr 21, 2010 9:56 am Post subject: |
Are the early 68-71 interoirs mounted in the same way? Are they interchangable? ie. could you put a late interior into an early bay?
just wondering as i am looking at an early bay without an interior but they guy has a few later westys with good interiors. Just wondering if they would fit the early bay.
thanks
mike |
subwayaz Samba Member
Posted: Thu Apr 21, 2011 2:24 pm Post subject: |
Thanks much Eric for the excellent tutorial. You answered every question I could have come up with; so I now know how to do my interior.
Two thumbs up |
highlandmurf Samba Member
Joined: April 08, 2010 Posts: 296 Location: Hudson Valley, NY
Posted: Wed Jun 08, 2011 7:09 am Post subject: RE: Ice box cooler drain pipe |
Awesome photo tutorial. It will be a huge help when I pull mine.
Of course one view that I need to see is missing.
Anyone got a photo of how the icebox drain comes out of the cooler cabinet and goes through the floor.
Or, can anyone describe this area in detail?
I was under my bus last month and noticed that my Icebox drain pipe is missing. Glad I saw it before I filled it up with ice.
Are there fittings or gaskets below the icebox or does it just hang down and go through the floor?
Also, any ideas on what type of hose is good to replace it with?
Thanks _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Wed Jun 08, 2011 8:20 am Post subject: |
It's seriously just a straight pipe that goes from the ice box to outside the bus. That's it.
_________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
kruton Samba Member
Joined: March 27, 2011 Posts: 230 Location: Titusville, FL
Posted: Wed Jun 08, 2011 11:32 am Post subject: |
Thank you sooo much EZ Gruv!! I got my first bus and the interior was totally stripped out. Thanks to your thread I was able install the cabinets with the correct hardware! Ohh and btw your interior looks awesome! _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=460364
Florida Licensed Solar Contractor
NABCEP Certified Solar PV Installer |
Posted: Wed Jun 08, 2011 3:51 pm Post subject: |
Thanks.
Glad to see I can occasionally come up with something helpful. _________________ Eric
dopiotogo Samba Member
Joined: July 28, 2010 Posts: 6 Location: santa clara, CA
Posted: Tue Sep 06, 2011 10:05 pm Post subject: removing westy interior |
thanks EZ Gruv! just finished sound deadening and insulating all the doors/hatch and now need to re-lamintae the cabinets....this helps alot with some other tips on removing/replacing laminate...
but I do like all that space... _________________ 77 ASI Riviera camper
2.0 FI, hydraulic lifters
Automatic |
Tvättbjörn Samba Member
Posted: Sat Mar 24, 2012 8:36 pm Post subject: |
I did remove all my interior and noticed that the upper closet was bolted onto to fridge / cooler unit .
Is that factory? |
Posted: Sat Mar 24, 2012 8:40 pm Post subject: |
Tvättbjörn wrote: |
Is that factory? |
Yes, that was factory. I missed it in the original post because I removed those bolts previously., but it was covered later in the thread. _________________ Eric
Phat Pat Samba Member
Joined: December 26, 2012 Posts: 2 Location: Fort Lauderdale
Posted: Sun Jan 06, 2013 12:56 am Post subject: Need help with propane connection |
Just got a '78 Champagne Edition camper, cannot figure out the right way to undo the propane connection at the floor. I was able to unscrew it from the stove end using two wrenches in opposite directions. The connection at the floor is so difficult to get a good angle on. I've even had my wife holding the bottom bolt under the bus while I attempted to crank it from the top with an open ended wrench, and it won't move.
I'd appreciate any help or insight. At this point I'd also need to know where to get a replacement propane line from the floor to the stove, because it got twisted up in the process. |
Posted: Sun Jan 06, 2013 9:50 am Post subject: Re: Need help with propane connection |
Phat Pat wrote: |
That one is a bugger. I recall using two wrenches on the inside of the bus, or you could use a wrench and maybe some thin pliers.
For a replacement, I went to my local trailer supply store. They had many to choose from on the rack. It was less than $5.
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sat Feb 16, 2013 9:21 pm Post subject: |
Awesome thread!
I really need to replace my laminate but was dreading taking everything out but this thread helps tremendously!! |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Sat Feb 16, 2013 9:34 pm Post subject: |
Very cool stuff, gonna use this thread post haste. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Sat Mar 23, 2013 9:43 am Post subject: |
This should maybe go in the stupid question thread, but I'm hoping to get a quick answer.
Can you remove/install the rear side cabinet without removing the sink and icebox/storage units? _________________ 1976 Westy
1966 Beetle |
Posted: Sat Mar 23, 2013 9:47 am Post subject: |
Bala wrote: |
Can you remove/install the rear side cabinet without removing the sink and icebox/storage units? |
Yes, but you still have to remove the upper (head-banger) cabinet. _________________ Eric
Bala Samba Member
Posted: Sat Mar 23, 2013 9:56 am Post subject: |
EZ Gruv wrote: |
Bala wrote: |
Yes, but you still have to remove the upper (head-banger) cabinet. |
Sweet, that's probably a bit easier. _________________ 1976 Westy
1966 Beetle |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Thu Feb 19, 2015 6:22 pm Post subject: |
Came across this thread when I did a search on how to remove the sink cabinet. I couldn't figure out what was hanging up. Your tutorial saved me a bunch of time and aggravation. Thanks EZ Gruv. I just wish I would have known about it before I started removing any of the cabinets. I started with the head banger and worked my way to sink cabinet. I could have shaved another half hour off this project. You gotta love the Samba. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin |
Posted: Thu Feb 19, 2015 6:24 pm Post subject: |
Glad this thread is still helpful! _________________ Eric
driverinmyhead Samba Member
Posted: Fri Feb 20, 2015 1:05 pm Post subject: |
Thank you for this!!!!
It'll be a while, but I plan to remove my Westy interior to clean, replace hoses and inspect everything as well as do some light restoration. (someone added a fluorescent light when the old one quit working).
Awesome write up! You make it look so easy! |
Posted: Fri Feb 20, 2015 1:10 pm Post subject: |
driverinmyhead wrote: |
It is! _________________ Eric
