Troytempest69 Samba Member
Posted: Fri Feb 16, 2024 2:40 pm Post subject: Any information on this clutch pedal bearing seal 211721395 |
Parts book has a seal for LHD split vans. Can’t find any pics, references, or for sale in any supplier. There is some information for an ’A’ variant but this is for a bay window.
It looks like a rubber o ring type seal but would be good to know if people are using it, and where from? |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Feb 16, 2024 3:32 pm Post subject: Re: Any information on this clutch pedal bearing seal 211721395 |
Appears to be Bay only
http://oacdp.com/pdfs/5867s7.pdf |
Posted: Fri Feb 16, 2024 3:43 pm Post subject: Re: Any information on this clutch pedal bearing seal 211721395 |
Yeah, it’s strange. It’s in the splittie part book but other than that it’s like this part never existed. I’ve dug out my Bentley and there’s no sign of the seal in the pictures on in the section that discusses removing or installing the clutch pedal linkage.
On the bright side…it’s a part I don’t now need to find |
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
Posted: Sat Feb 17, 2024 2:35 am Post subject: Re: Any information on this clutch pedal bearing seal 211721395 |
Thanks Michael….nice to know I wasn’t going crazy. If I’ve understood your solution the plastic spacer has an inset that the rubber o ring sits into? |
mdege Samba Member
Stocknazi Samba Member
Posted: Sat Feb 17, 2024 9:32 am Post subject: Re: Any information on this clutch pedal bearing seal 211721395 |
I've found these on a couple buses, mostly badly deteriorated.
I substituted a piece of rubber radiator hose and it does seem to seal things up some.
Very neat solution with the home made plastic spacer/o-ring.
You could probably sell a few of those if you were so inclined. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
70bus Samba Member
Posted: Sat Feb 17, 2024 11:32 am Post subject: Re: Any information on this clutch pedal bearing seal 211721395 |
My 65 had one when I took off pedals, it was cup shaped IIRC; Pedalwerks supplied a length of hose sized properly to replace, I had a bay seal in my parts bin but it was too big.
With Pedalwerks seal:
_________________ Craig K
70 Neunsitzer
65 Pritschenwagen
"If Von Dutch was alive, he'd walk in there with a pistol and shoot these people."
-Robert Williams |
