EverettB Administrator
Joined: April 11, 2000 Posts: 69822 Location: Phoenix Metro
Posted: Mon Apr 21, 2008 4:33 pm Post subject: 25hp/early 36hp Fuel pump tin |
I picked the black one below this weekend at Kelley Park. Then I noticed it's different than my other one.
Does anyone know the different applications? The bolt holes are identical but they are slightly different sizes and one is constructed of more than 1 piece of metal.
Photos
Note length here:
_________________ How to Post Photos
doveblue3 Samba Member
Posted: Mon Apr 21, 2008 6:00 pm Post subject: Re: 25hp/early 36hp Fuel pump tin |
EverettB wrote: |
Photos
Note length here:
i know that when i tried a 36er one on a 912, they didnt work, although at first glance they are the same. not saying thats necessarily what you have, just giving another option. |
billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Mon Apr 21, 2008 10:38 pm Post subject: |
the black one looks like a cut down 25hp one ! some one has cut the front edge down on it and relocated the hole, an easy fix if you have a good one to refer to, heres a pic of an intact one, the slightly larger one looks like an early 36hp one, the later 36 hp ones had the drip gutter down the center
_________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
HeSa Samba Member
Joined: January 15, 2007 Posts: 466 Location: FINLAND
Posted: Tue Apr 22, 2008 4:52 am Post subject: |
billmetric wrote: |
Agree, I just disassembled a similar to the right one from an untouched 3 Feb 1954 industrial engine. It has quite a lot of transitional features like hex nuts for the heads, 36hp looks thin lip 9,5mm crank pulley, spot welded upper tin indents for the head nuts, 54-55 only fuel pump, thin slot big nut generator with 9,5mm pulley, fan similar to 25hp etc. |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1272 Location: Lamorinda CA
Posted: Tue Apr 22, 2008 9:24 am Post subject: |
The one on my car is EXACTLY the same as the black one Everett... right down to the little lip and the fact its made of more than one piece of metal and welded... it looks precisely the same. So I dont think that one is a one off. _________________ DB
9/1950 Hoffman Standard
11/1966 Porsche 912
10/1966 Porsche 912
7/1968 Type 265 Double Cab
10/1958 Type 117 |
Posted: Fri Apr 25, 2008 3:59 am Post subject: |
OK, I checked on why there would be a reason to have different locations for the modified screw location on Everetts tin, my photo of the one piece tin came off of a July '52 split, the difference with the screw locations can be explained by the early cylinder tins and heater box bottom tin having 3 screws instead of the later 2 screw type, The tin piece photo I posted shows the front most screw hole which has to be screwed down to the MIDDLE screw on a 3 screw cylinder tin, the tin with the extra hole spot welded on it could be used on two or three hole cylinder tins and heater boxes since it uses the left most screw hole and not the middle one, this must have been a very late 25hp part, the only thing I cant figure out is that the rear "breast plate" is specific to this tin piece, the other one in Everetts photo would not fit with a 3 screw breast plate, very strange, I checked my matching 3 screw rear tin and the right hand side also uses the midle screw only on the cyl 1 & 2 side so I cant figure out why a 2 screw 25hp fuel pump tin would be necessary especially when there is already an early type 36hp tin, the only thing I can think of is that they had some 25 hp tin left over when they switched over to 2 screw heater boxes, the problem with that is that the rear tin for that fuel pump tin only fits a 3 screw heater box, very strange that another one of these have turned up, what was the production date on 52HoffmanSplits car? _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
Posted: Fri Apr 25, 2008 7:41 am Post subject: |
billmetric wrote: |
OK, I checked on why there would be a reason to have different locations for the modified screw location on Everetts tin, my photo of the one piece tin came off of a July '52 split, the difference with the screw locations can be explained by the early cylinder tins and heater box bottom tin having 3 screws instead of the later 2 screw type, The tin piece photo I posted shows the front most screw hole which has to be screwed down to the MIDDLE screw on a 3 screw cylinder tin, the tin with the extra hole spot welded on it could be used on two or three hole cylinder tins and heater boxes since it uses the left most screw hole and not the middle one, this must have been a very late 25hp part, the only thing I cant figure out is that the rear "breast plate" is specific to this tin piece, the other one in Everetts photo would not fit with a 3 screw breast plate, very strange, I checked my matching 3 screw rear tin and the right hand side also uses the midle screw only on the cyl 1 & 2 side so I cant figure out why a 2 screw 25hp fuel pump tin would be necessary especially when there is already an early type 36hp tin, the only thing I can think of is that they had some 25 hp tin left over when they switched over to 2 screw heater boxes, the problem with that is that the rear tin for that fuel pump tin only fits a 3 screw heater box, very strange that another one of these have turned up, what was the production date on 52HoffmanSplits car? |
Mine is a July 3 of 1952. But It's not original to the car. When I bought my Split there was no rear breast plate OR Fuel pump tin on it.... I got it off ebay.. _________________ DB
11/1966 Porsche 912
10/1966 Porsche 912
10/1958 Type 117 |
HeSa Samba Member
Posted: Fri Apr 25, 2008 3:54 pm Post subject: |
billmetric wrote: |
These are the heater boxes from the Feb 1954 engine that had the pump tin seen on the right in Everett´s picture. Still 3 screw and look identical to 25hp.
Posted: Thu Feb 09, 2012 9:33 am Post subject: |
Another one a friend owns.
It doesn't fit most of my 25hp/early 36hp rear breast plates at all.
Gap:
But I have this one rear tin where it does fit, so both of these parts are possibly very early pieces, 1950 or ?
The shape of the white tin is different here, it may be hard to see, but the angle where it curves up to the heat riser section is different:
Also the middle hole for the white (earlier?) 3-hole tin is solid instead of a U-shape:
3 hole tin versus later 2-hole tin:
More information or exact years these fit welcome... _________________ How to Post Photos
Grant Reiling Samba Slow-Change Artist
Joined: November 28, 2003 Posts: 491 Location: behind the wheel
Posted: Wed Dec 04, 2013 6:08 pm Post subject: |
Nice!….Rotate 90º and you have a Salvador Dali. |
52 split Samba Member
Joined: December 19, 2007 Posts: 150 Location: the best island in the world, vancouver island
Posted: Thu Dec 05, 2013 6:39 am Post subject: |
thank you Everett. that would have been me. |
