ohlone Samba Member
Joined: April 17, 2018 Posts: 5 Location: Santa Cruz CA
Posted: Sat May 26, 2018 9:30 pm Post subject: Re: DIY - Red Tek conversion |
Howesight, Wow! Many thanks for this crafted forum response.
A question for you / others:
Your instructions state to put a can of Red-Tek into the high-side service port. I'm a complete A/C noob but from what I've scoured online I thought it was a universal and dangerous no-no to add refrigerant to the high side of any A/C system ?
Gracias. |
Abscate Samba Member
Posted: Sun May 27, 2018 3:37 am Post subject: Re: DIY - Red Tek conversion |
When the system is evacuated it’s safe to add to the high side port. But it’s safer and slower to use the low side,especially for us occasional ACtechs.
Our Volvo fleet doesn’t even come with high side ports, but you can monitor pressure in software _________________ .ssS! |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sun May 27, 2018 7:37 am Post subject: Re: DIY - Red Tek conversion |
You can fill on either side, but the compressor needs to be off if you want to fill on the high side.
It's just sound principle to never fill on the high side. |
blurat Samba Member
Posted: Sun May 27, 2018 4:32 pm Post subject: Re: DIY - Red Tek conversion |
It has been mentioned a few times so if anyone misses it........
Install first can to a vaccuumed system on the high side....WITH THE ENGINE OFF, NOT RUNNING, NO SOUND COMMING FROM THE MUFFLER, NO KEY IN IGNITION IT IS IN YOUR POCKET SO YOU KNOW WHERE IT IS.
Otherwise you cant pick your nose anymore. |
Jon Folks Samba Member
Joined: January 01, 2018 Posts: 13 Location: Bay Area, California
Posted: Tue Jun 05, 2018 11:42 pm Post subject: Re: DIY - Red Tek conversion |
Hi guys, having trouble with my redtek conversion. Just rehabbed by AC: new compressor, drier, expansion valve, trinary switch, parallel flow condenser. I flushed the lines and evaporator.
With everything hooked back up I ran a vacuum pump for 1.5 hours and the system held vacuum for 48 hours.
When I went to add refrigerant, the system only took about ~1.5 cans before I get pressure readings of 30 low 120 high. Doesn't seem right, what could I be doing wrong? Since I am already at 30PSI I stopped adding refrigerant for now.
Thanks! |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Wed Jun 06, 2018 4:09 am Post subject: Re: DIY - Red Tek conversion |
Jon,
Add more. By weight it will take 18 ounces, each can is 6, assuming you got all of it in. Go by vent temps, not pressure readings. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
Westaru Samba Member
Posted: Fri Jul 20, 2018 1:18 pm Post subject: Re: DIY - Red Tek conversion |
I was ready to install today but I've read the whole thread but still have an unanswered question - the Redtek kit comes with a low-side fitting only. How are you all filling through the high side? _________________ 1984 'Westaru' Vanagon Westfalia EJ22
@UtahWestfalia on IG |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Fri Jul 20, 2018 1:23 pm Post subject: Re: DIY - Red Tek conversion |
Stock low and hi are the same. Fittings added for R134A are size diff, perhaps you can get an idea on that. I didn't care much for the upsidedown hi side trick, went from the low side. BUT, could have. Don't forget the box fan... I used 2.. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Fri Jul 20, 2018 1:35 pm Post subject: Re: DIY - Red Tek conversion |
bobbyblack wrote: |
Stock low and hi are the same. Fittings added for R134A are size diff, perhaps you can get an idea on that. I didn't care much for the upsidedown hi side trick, went from the low side. BUT, could have. Don't forget the box fan... I used 2.. |
This is an EJ22 conversion, 134A fittings, and the high and low are different sized. Out of the box the RedTek adaptor will only fit the low side. I was trying to use the Howesight writeup but the high side is a nogo with this as it sits.
Thanks for the heads up. _________________ 1984 'Westaru' Vanagon Westfalia EJ22
Posted: Fri Jul 20, 2018 1:36 pm Post subject: Re: DIY - Red Tek conversion |
the Utahn wrote: |
bobbyblack wrote: |
On the low side, Redtek says to use the can upside down - but everything else I've read says to NOT do this since you can introduce liquid to the compressor. Does anyone have thoughts on this?
Thanks for the quick reply _________________ 1984 'Westaru' Vanagon Westfalia EJ22
mbwesty Samba Member
Posted: Fri Jul 20, 2018 1:38 pm Post subject: Re: DIY - Red Tek conversion |
What, no, not the high side! I hope ur just joking, and if I don't hear back from you I would assume you may be in the hospital!
ohlone wrote: |
Gracias. |
Posted: Fri Jul 20, 2018 1:42 pm Post subject: Re: DIY - Red Tek conversion |
I'd say that the up-side-down thing sounds scary no matter what, but I do believe it CAN be employed with success. Anyway, I got my adapters off an EJ22, and neither of them fit the stock stems hi or low. I scrounged up a Freon filler, and adapted back to the newer stuff from that. Nuts, yes, but worked just fine from low side, it DID take a LONG time tho. Patience payed off tho, super cold. I'm happy! TWO box fans, seriously. More if you can figure out how! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Fri Jul 20, 2018 1:45 pm Post subject: Re: DIY - Red Tek conversion |
I think I also used more than 1.5 can, may be it was like 3. The pressure reading was hard to conclude I remember as it fluctuated a bit. May be watch to make sure that it doesn't get above 35's the way to go. Also, I had a cheap HF guage, I don't think it was made for the Redtek stuff, so it's gonna be off.
Anyother thing, I refill it basically once a year with one can, the low side would go from 20 back up to 30psi and I call it good. The van gets cooler...I hope this help!
Jon Folks wrote: |
Thanks! |
Posted: Fri Jul 20, 2018 1:55 pm Post subject: Re: DIY - Red Tek conversion |
Thank you all for the comments.
Mbwesty, Howesight recommends installation of the first can with engine off in his writeup on pg 50 (I can't figure out how to direct link to that thread).
So is the trick simply using all 3 cans through the low side, non-inverted and it taking a long time? Heating cans with hot water? _________________ 1984 'Westaru' Vanagon Westfalia EJ22
Posted: Fri Jul 20, 2018 2:30 pm Post subject: Re: DIY - Red Tek conversion |
Ah, si, the system is still in a vacuum environment. I think the only time I ever used the high side was for the first filling, and it was just to be sure of the high side pressure was legit. I think with the system in a vacuum, the Redtek would just escape into the system. The first can I put in had oil I believe, I also filled the compressor with oil first. I am also very sure that I filled it with the can inverted and didn't use hot water...
the Utahn wrote: |
So is the trick simply using all 3 cans through the low side, non-inverted and it taking a long time? Heating cans with hot water? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jul 20, 2018 5:32 pm Post subject: Re: DIY - Red Tek conversion |
the Utahn wrote: |
That'll work. If unsure AT ALL, safety first...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Fri Jul 20, 2018 7:05 pm Post subject: Re: DIY - Red Tek conversion |
the Utahn wrote: |
A subie conversion here too, with R134 connectors. I used the Harbor Freight manifold and gauge set. Makes life very easy to fill either side - just NEVER fill the high side when the engine is on. I use Envirosafe rather than Redtek, but it's the same sort of stuff - I put one can upside down into the high side while the vacuum is still there, then the rest I do with the cans upright (gas only) into the low side as 'normal'.
A side note for those without a shop fan or with huge bumpers and foglights - on my '84 you can't bridge the radiator switch connector to get the high-speed fan running, as this simultaneously opens the 'compressor off' relay. Some re-wiring has to be done if that is the preferred method of cooling the condenser. I rewired mine with an extra relay in parallel with the high-speed relay which works fine - and still turns the compressor off if the system overheats. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Sat Jul 21, 2018 4:32 pm Post subject: Re: DIY - Red Tek conversion |
Thank you all for the tips! I attempted the Redtek install yesterday and hit some speed bumps.
First, the background: I installed the Smallcar AC kit and originally had the R134A installed. However the air could have been colder and wouldn't keep the kids in the back seat cool (especially when 100* here) and the pressures were high enough that the high speed fan would run almost continuously even when on the highway (at 100*).
I decided to give the Redtek a try to lower pressures, reduce fan operation and hopefully reduce temperatures further.
The first 2 cans went in to the low side fine, 1st quickly and the 2nd took slightly longer. Both were held upright and put in bowls of hot water to help them discharge. Took roughly 1hr for both, first when the car was not running (discharged into 28# vacuum) and running on the second. Discharge temps after the second was around 64*, box fan running, low and high speed fan cycling periodically, and garage temps of 99*. Lowside pressures were 22-25 and high side was 225-250 (depending on operation of high speed fan).
Third can is where I screwed up. I started the filling, went to check temps, and noticed it had climbed to 74* at the vent. I went back and turned off the valve but for whatever reason this can discharged much quicker and was nearly empty. Almost 3 cans total, 31-33 psi low side, 225-275 psi high side. I tried to bleed off some refrigerant slowly but couldn't do it slow enough without releasing oil. I then noticed that the high side gauge had filled with refrigerant in the sight glass. Waited an hour, and was still full of refrigerant when I disconnected it.
To summarize, basically I have no idea how much refrigerant I have in the system other than 'too much', releasing it doesn't seem to be working without losing oil, and it works much less well than the R134A did.
I'm evaluating my options now and debating on releasing slowly and measuring the oil released (catchcan), and then trying this again with Redtek/Envirosafe or just going back to the R134A and be done with it.
Is there that much performance gain to be had with Redtek/Envirosafe vs R134A? My system has barrier hoses and is designed for either, so it's really a performance question at this point.
Secondly, have any of you had the high side hose fill your sight glass/hoses with refrigerant? Assuming I did something wrong but would like to learn exactly what!
Lastly, is Envirosafe comparable performance wise to Redtek? The shipping times with Redtek took a while last time (2 weeks).
Thanks for any advice you can give. _________________ 1984 'Westaru' Vanagon Westfalia EJ22
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32635 Location: Reading Pennsylvania
Posted: Sat Jul 21, 2018 6:45 pm Post subject: Re: DIY - Red Tek conversion |
FWIW, I had similarly poor vent temps until I tried charging with the engine
cover laid in place (to keep engine heat out of the cabin) & hatch closed as
much as possible (to recirculate cooled air inside cabin). YMMV...
"The WonderVan"
