EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Sun Nov 16, 2008 11:04 am Post subject: |
Thanks Karl. If you have them, please let me know. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Sun Nov 16, 2008 12:06 pm Post subject: |
I have only 1 left front lower. I have no 72-74 right front lowers with the square hole. I have 3 79 Cal right front lowers without the square hole which is good for FI engines.
BTW, the right lower tin is also different for 72-74 carb'd engines and 79-83 FI engines.
Carb'd engines have a hole for the 3rd line off the fuel pump:
FI engines do not have the hole:
Posted: Sun Nov 16, 2008 12:27 pm Post subject: |
Quote: |
I have only 1 left front lower |
Is that part O in the diagram?
Quote: |
I have no 72-74 right front lowers with the square hole. I have 3 79 Cal right front lowers without the square hole which is good for FI engines. |
My 77 is FI, so I could use the 79 version.
Quote: |
Carb'd engines have a hole for the 3rd line off the fuel pump: |
My new right lower does not have the extra hole, so I'm good there. _________________ Eric
Karl Samba Member
Posted: Sun Nov 16, 2008 1:32 pm Post subject: |
Yes, O is the left front lower.
Here are some pics to show what they look like and the differences:
Here is the 72-74 lower tin, notice the curve at the front where the screw holes go to the front lower tin.
Here is the O tin, the correct 72-74 left front lower.
Here you will see where the tin screws match up.
Here is O but this is the 79-83 Calif ONLY left front tin. [Bus Boys is wrong when they say 72-74 is the same as 80-83 ALL]
Here is the left lower, 79 Calif ONLY. Look at the curve where the holes are to mount it to the left front lower tin. It has a narrow lip on the left side.
Here is the same piece except it is 80-83 Vanagon Calif ONLY. Same curve on the front edge, but a wider lip on the left.
Here is the 79 Calif ONLY left side together to show the screw alignment.
This is why Bus Boys is wrong. Here are the Calif ONLY left side tin stacked on top of each other. The lower one is Vanagon with the wider lip. Both show the exact same front edge curve. Both use the same left side exhaust manifold with the cat under the head.
jimjxsn Samba Member
Posted: Sun Nov 16, 2008 2:26 pm Post subject: |
Karl wrote: |
Karl - I am also interested in one of the right lower tins from a 79... PM sent _________________ _____________________
'76 sunroof bus |
White99z Samba Member
Joined: August 17, 2008 Posts: 735 Location: Bus hunting in the USA!!!
Posted: Tue Nov 18, 2008 11:00 pm Post subject: |
Does anyone that has done this have an approximate cost for the swap? I am facing these same issues right now. |
Posted: Sat Nov 22, 2008 4:48 pm Post subject: |
Hey Karl, thanks for the tin pieces! They were way cleaner than all the other parts that I have for this swap!
Here is a pic of just about everythig:
One issue though: I pulled the heater boxes out of storage this morning and found this on the right side box:
Looks like the casing is coming apart at the seam! Oh boy, what to do now? _________________ Eric
Karl Samba Member
Posted: Sat Nov 22, 2008 5:10 pm Post subject: |
Carefully open the crimp and rehook the bottom lip. Then close the crimp with vise grips. |
Posted: Sat Nov 22, 2008 5:13 pm Post subject: |
Karl wrote: |
Sweet! _________________ Eric
RZAR Samba Member
Posted: Sun Apr 19, 2009 9:20 am Post subject: |
Karl wrote: |
Bringing this thread back!
I just removed my engine because of a broken cam gear after only 7000 miles. The engine is coming back together and I am going to convert to the 72-74 HE's using a Fed 79-83 crossover so I can still pass smog. I have all the tin pieces from my doner 72 engine. I was wondering what is that square hole for on the lower tin? BTW I am still looking for that crossover pipe |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
vw76westy Samba Member
Posted: Mon Apr 20, 2009 1:26 am Post subject: |
how different are the tins from a 80-83
could you use tin from these years |
RZAR Samba Member
Posted: Sun Apr 26, 2009 9:53 am Post subject: |
Ok I have the chance to do this conversion due to an early engine failure on my fairly new rebuilt engine. The engine is fixed and dressed except for the exhaust. I had all the "new" '72 tins powder coated to match my OG tins and the '72 HE's will be done Tuesday. One question I have is there another support bracket for the HE's other then the ALT/HE support? The exhaust system is supported on the right side by the atl. braket but what about the other side? |
germansupplyscott Samba Member
RZAR Samba Member
Posted: Sun Apr 26, 2009 4:03 pm Post subject: |
Nice, I'll order one up tonight. Are there any other support brackets to be aware of? |
Posted: Sun Apr 26, 2009 4:38 pm Post subject: |
RZAR wrote: |
not for '72-'74. there are two other, different brackets used on '75-'78. _________________ SL |
RZAR Samba Member
Posted: Sun Apr 26, 2009 7:55 pm Post subject: |
Just ordered it from your site. Thanks. |
Posted: Sun Apr 26, 2009 11:05 pm Post subject: |
Quote: |
not for '72-'74. there are two other, different brackets used on '75-'78. |
hi scott will you point those out |
Posted: Mon Apr 27, 2009 5:33 am Post subject: |
sure, will do. we have reproductions coming for both of them. _________________ SL |
RZAR Samba Member
Posted: Fri May 15, 2009 8:18 pm Post subject: |
Finished the conversion and all I have to say is what a difference in heat output! The early HE's are a much better design. There was nothing wrong with my OG 77 heater boxes but since I had the engine apart and had a complete 72 setup I went with the conversion. Also it is so much simpler than the later setup I replaced so no more exhausts leaks. So no I have awesome heat just in time for Summer in San Diego. |
