risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Sun Apr 27, 2008 6:48 pm Post subject: welding in adjusters... what size is the adj bolt? |
Welded in some adjusters today and forgot to put the inner pieces in! (empi type) can they be knocked in from the end of the torsion tubes? Any tricks here or am I gonna have to cut the tubes and reweld?
Thanks, risk
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sun Apr 27, 2008 8:13 pm Post subject: |
Are you refering to the Aluminum collar that sits in the center of the beam? If so, yes you'll need to knock out the original and insert the new collar into place. |
risk Samba Member
Posted: Mon Apr 28, 2008 9:13 am Post subject: |
well, I cut an extra 4" out to narrow the beam, so I cut the og collars out. The new adjusters I welded in came with new collars but I left em out on accident
any ideas?
like this one:
Posted: Mon Apr 28, 2008 5:40 pm Post subject: |
If you don't have any welding slag inside the beam tubes, you can just insert those collars back into place. Of course you'll need to remove any bearings that might be on the ends of the tubes to gain access |
risk Samba Member
Posted: Mon Apr 28, 2008 6:39 pm Post subject: |
thanks rareair!! if there's any slag in there i'll just try a bigger hammer..... |
Cliff@BrownBags Samba Member
Joined: June 14, 2007 Posts: 649 Location: glen burnie maryland
Posted: Mon Apr 28, 2008 7:26 pm Post subject: |
your best bet if you cant get it in that way is to just make a new cut away from any cuts you had before and bevel the edge again and re weld. sucks , i did the same thing lol |
risk Samba Member
Posted: Fri May 23, 2008 9:19 am Post subject: |
anyone know what size the adjuster bolt is? I really want to put a shorter one in the bottom before i rip mine off. I think its M14 x 1.50 .. can anyone confirm this?? |
ivsamhell Samba Member
Joined: June 12, 2006 Posts: 858 Location: hesperiaCA
Posted: Fri May 23, 2008 5:45 pm Post subject: |
risk wrote: |
heres what i do, find the length you want the bolt via adjusting to desired ride height, then remove the bolt and thread a nut onto it, cut and/or grind it to the desired length/shape, removing the nut should clean the threads up enough. done. |
