thermostat
Page: 1, 2, 3, 4, 5  Next
BDSBSS23
BDSBSS23 is offline
PostPosted: Mon Apr 28, 2008 5:06 pm    Post subject: thermostat Reply with quote
how to adjust the thermostat and how do i know that it's working?
58 beetle AKA Black Beauty http://www.thesamba.com/vw/forum/viewtopic.php?t=496780&highlight=black+beauty
65 micro bus (project)
http://www.thesamba.com/vw/forum/viewtopic.php?t=522611&highlight=std
Pillar repair with 65 bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=530360
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Apr 28, 2008 5:10 pm    Post subject: Reply with quote
Use a air dryer to watch it expand.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
BDSBSS23
BDSBSS23 is offline
PostPosted: Mon Apr 28, 2008 5:12 pm    Post subject: Reply with quote
i tried that but nothing
Mr. 010
Glenn is offline
PostPosted: Mon Apr 28, 2008 5:20 pm    Post subject: Reply with quote
Remove the thermostat and pull on the linkage to ensure it's not binding.
When cold the thermostat should be tight and compact. A hair dryer will make it expend quickly.
Glenn
BDSBSS23
BDSBSS23 is offline
PostPosted: Mon Apr 28, 2008 6:11 pm    Post subject: Reply with quote
alright i will try that
mnussbau
mnussbau is offline
PostPosted: Mon Apr 28, 2008 6:20 pm    Post subject: Reply with quote
If the thermostat works it will be about this size when completely cold.
Mike
Sold my sedan
Parts...
68Bug-lite
68Bug-lite is offline
PostPosted: Mon Apr 28, 2008 6:26 pm    Post subject: Re: thermostat Reply with quote
Brett Ross wrote:
how to adjust the thermostat ?
Look here...
http://66.225.214.60/baja/thermostat.htm
BDSBSS23
BDSBSS23 is offline
PostPosted: Mon Apr 28, 2008 6:56 pm    Post subject: Reply with quote
I have tested it it works but not very easily. The main rod that controls the flaps seems to rub against the case what should i do to solve that?
Mr. 010
Glenn is offline
PostPosted: Mon Apr 28, 2008 6:58 pm    Post subject: Reply with quote
You have to make it move freely. If it jams closed, you'll cook the engine.
Glenn
BDSBSS23
BDSBSS23 is offline
PostPosted: Mon Apr 28, 2008 6:59 pm    Post subject: Reply with quote
maybe some bending is required to fix the problem?
Mr. 010
Glenn is offline
PostPosted: Mon Apr 28, 2008 7:00 pm    Post subject: Reply with quote
Or it was installed through the wrong hole in the head.
Glenn
BDSBSS23
BDSBSS23 is offline
PostPosted: Mon Apr 28, 2008 7:10 pm    Post subject: Reply with quote
I am not talking about the theromstat rod i am talking about the rod that connect the two flaps in order to open the flaps at the same time. if you need pics i can get them.
Mr. 010
Glenn is offline
PostPosted: Mon Apr 28, 2008 7:13 pm    Post subject: Reply with quote
Brett Ross wrote:
I am talking about the rod that connect the two flaps in order to open the flaps at the same time.
That should be easy to fix.
Glenn
BDSBSS23
BDSBSS23 is offline
PostPosted: Mon Apr 28, 2008 7:15 pm    Post subject: Reply with quote
I looked at the rod and yep i need to straighten that out and that spring you have in the pic i dont have one. where should i find one?
Mr. 010
Glenn is offline
PostPosted: Mon Apr 28, 2008 7:20 pm    Post subject: Reply with quote
Swaps or vendors.
Glenn
mnussbau
mnussbau is offline
Bus Depot...no photo so you might call them to confirm this is the right part.
http://www.busdepot.com/details.jsp?partnumber=113119279
Mike
Sold my sedan
Parts...
BDSBSS23
BDSBSS23 is offline
PostPosted: Mon Apr 28, 2008 7:30 pm    Post subject: Reply with quote
thanks everyone
bonewso
bonewso is offline
PostPosted: Tue Apr 29, 2008 10:05 am    Post subject: Reply with quote
Glen - do you have an image of the correct hole that the thermo rod goes through?
Mr. 010
Glenn is offline
PostPosted: Tue Apr 29, 2008 10:41 am    Post subject: Reply with quote
No... and i get confused, so I always check the movement before moving on to the next item on the list.
Glenn
BDSBSS23
BDSBSS23 is offline
PostPosted: Tue Apr 29, 2008 10:42 am    Post subject: Reply with quote
I found out the problem why the rod was rubbing on the case. It was installed on the opposite side.
Page 1 of 5
