gobeatle Samba Member
Joined: November 04, 2007 Posts: 97 Location: Mid MIchigan
Posted: Wed May 21, 2008 10:19 am Post subject: |
Problem solved. The rod connection on the flap, that curved piece (mine was a "c" shape) should be bent in a loop. If it's in the shape of a "c" then it got stretched out from its circular shape when the shroud was taken off without the rod being disconnected first. Simple when you know. It work fine now. Thanks everyone for your input and your patience. |
Posted: Wed May 21, 2008 10:25 am Post subject: |
Oh, by the way. Does anyone have any of those clips that attach to the flaps and they also secure the flaps bar (bar between the two flaps on either side of the shroud) to the flaps. Or where I can get some. I need a few. Thanks |
Busdepot Samba Member
Posted: Wed May 21, 2008 10:56 pm Post subject: |
Thanks, I've got the thermostat. I need the clips you see outside the shroud that are on the flaps and the bar between the flaps. Anyone have any not being used? Are these still available? |
Panta Rhei Samba Member
Posted: Thu May 22, 2008 12:19 am Post subject: |
Ace Hardware has clips that will work fine on the flaps and control arms. |
Posted: Thu May 22, 2008 8:19 am Post subject: |
Yea, I was just trying to stick with original stuff when I can, even though I would be the only one that would know that behind my shroud a original retaining clips. Yes, I'm sick. Just thought I would check with everyone. PM me if you have clips. Thanks |
trn Samba Member
Joined: June 13, 2008 Posts: 25 Location: Los Angeles
Posted: Fri Jun 13, 2008 7:16 pm Post subject: |
On a related note, here's the state of my fan. The photo is viewed from the bottom of the fan housing:
You can see that everything except the flaps themselves is gone. This includes the thermostat, connecting rod, and the rest of the hardware and spring. To add to it, one of the flaps is rusted:
Judging by this thread, the best I can do is buy the parts piecemeal and just figure out how they all go. Anybody know of a kit with instructions, or something that might make it easier? _________________ 1971 Bug in restoration: http://vw-restoration.blogspot.com |
