gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1468 Location: San Carlos, CA
Posted: Thu May 01, 2008 5:31 pm Post subject: Scored some Okrasa heads...now what |
Hello-
The good news is that I scored some Okrasa heads this afternoon. The bad news is that they're kind of rough, and I don't have the rest of the kit. I've seen some repro parts (air cleaners, valves, cams) but linkage and manifolds seem to be less common. Other than Mr. Okrasa (sorry, I don't have that much money ), is there a good source for these parts?
Thanks,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
Posted: Thu May 01, 2008 6:30 pm Post subject: |
There is no source for these parts. As far as finding the parts, you need to hunt and place wanted ads. You may end up paying more in the end than if you found a complete engine. Parts are hard to find, and good ones are expensive. It is easy to get shitty parts and if you need to redo them, you pay out the nose.
You probably bought the $100 heads that were advertised. You are going to have to spend some decent cash to get them up to snuff. Go cheap, and you will end up paying for it later. _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Fri May 02, 2008 1:17 am Post subject: |
I think Alejandro Martin (almar9) has made some repro intakes, linkage is easy to make yourself or maybe he does that too. Check judson registry and I think you will find Alejandros addres. |
