Red Ryder Samba Member
Joined: June 26, 2021 Posts: 952 Location: Northern California
Posted: Tue Oct 19, 2021 5:13 pm Post subject: Re: Rear hatch dome light button |
The factory dome lights ARE pretty dim, even after updating with LED bulbs. We went with this to illuminate the cockpit area. Works well.
https://www.amazon.com/dp/B07FTFDJT4/ref=cm_sw_em_...&psc=1 _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
jcannon Samba Member
Posted: Tue Oct 19, 2021 4:35 pm Post subject: Re: Rear hatch dome light button |
Duncan,
You are technically correct and I tried that. The wire behind the air intake louver makes a 90 degree turn to go through the grommet. On the backside of the grommet it must make another 90 degree turn then go to the dome light. I pulled from both ends, as hard as I dared, and the wire would not move in the grommet. To free it appears to require undoing part of the headliner. I could put lube on a q-tip, hold the q-tip with the 12” forceps and try lubing the grommet......
At that point I saw the humor in what I’d gone through and decided not to make it worse (break the wire) or more involved (removing headliner). Splicing the wire where the mice got it was akin to laparoscopic surgery but I made a beautiful solder splice using resistive soldering tweezers and double insulated it with double heat shrink tubing shrunk with a hot air pencil. The mice knew just where to chew.
I’ve checked a few times and the dome lights still come on when the rear hatch is opened.
Yet, it still gets more complicated. The right rear dome light has cracked plastic and the spring tab is missing. They are still available so I decided to order a new one. But wait, the other two will be brittle after 35 years -so why not get three. AND— now that I know how the dome light system works it will be an easy 1/2 hour to add the fourth over the passenger seat. Thus I ordered 4 new dome lights. There goes another $50 with shipping. When I point out the new passenger seat dome light to my wife will she’ll say “I don’t need that, I’ve got my battery powered lantern. Besides, it’s too dim.” So, to justify the 4th dome light I ordered a green LED bulb for it. She’ll think that is great. Useless, but great. I’ll probably add a rear interior switch to turn on all the dome lights at once. Do they make a 12V clapper? |
Posted: Mon Oct 18, 2021 8:50 am Post subject: Re: Rear hatch dome light button |
Glad you got it sorted out. And I love the “ego trip” comment. Your wife definitely has the patience and required sense of humor for those of us similarly addicted. “Hi, my name is Red Ryder and I am a Vanagonholic…” _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
DuncanS Samba Member
Posted: Sun Oct 17, 2021 10:27 pm Post subject: Re: Rear hatch dome light button |
Use the wire you have spliced together as a messenger to pull a new one piece wire so there won't be any failures in the future. Chewed wire could be in another place you didn't see and could fail.
Duncan |
Posted: Sun Oct 17, 2021 6:42 am Post subject: Re: Rear hatch dome light button |
Thanks Duncan S. Eventually I traced out the wire. It goes from the rear hatch, along the engine compartment back lip to the right tail light, up through the channel where the snorkel is, behind and just in front of the the right air intake louver, then into the interior dome light channel though a grommet. The grommet is on the same horizontal level as the dome lights. Finally, the wire connects to the right rear dome light.
If you don't have the rear hatch dome light switch, the factory wire route may be hard to replicate unless you headliner is out.
My van, which is an 87 syncro, has a spot for a 4th dome light over the passenger seat. There is a plastic block off plate in the hole. If you are rewiring your dome lights you can easily add one over the passenger seat. My wife would find it the most useful location.
Mice had also chewed off the wire between the air intake louver and the grommet. They chewed about 2/3 of the foam from the snorkel tube while they were at it.
It was very difficult to reach the wire stump that was left behind the louver and the wire did not want to pull through the grommet. I was able to solder new wire to the chewed stump and the switch works!
Honestly, it wasn't worth the amount of effort it took to fix. I don't need the dome lights to work via the tailgate. My wife said I only fixed it for the ego trip.
I hate mice. I really hate them. Besides clipping the dome light wire in 4 places, and chewing up the snorkel foam, I found they disconnected the snorkel at the bottom elbow. Also, they gnawed large access holes through the plastic panel that has part of the air intake. |
Posted: Sat Oct 16, 2021 8:09 pm Post subject: Re: Rear hatch dome light button |
The brown wire goes to the light. Run a new one from the light to the button switch and it will work. |
Posted: Sat Oct 16, 2021 1:02 pm Post subject: Re: Rear hatch dome light button |
I have the same tailgate switch and it doesn't work. Mice got to the wire and chewed it off near the button. With that fixed, still no light. Tracing the wire it heads left to another chew off, fixed by the PO. But, the PO wired it to the side marker light, which is wrong.
Behind the right tail light I found a 9" section of the same brown wire chewed off at both ends. I can't find the original "end". This wire appear to not be in any harnesses.
Does anyone know where the brown switch wire is routed. Again, mine goes from the switch, along the rear of the engine compartment, and ends by the right tail light. |
Timwhy Samba Member
dougass Samba Member
Posted: Fri Oct 15, 2021 2:09 pm Post subject: Re: Rear hatch dome light button |
Bumping my thread for zoning the interior lights & adding 3 position switches. For the hatch, I ended up isolating that zone completely and added a on-off-door switch to the D pillar.
https://www.thesamba.com/vw/forum/viewtopic.php?t=676948&highlight= _________________ '91 GL - 2.1 automatic named Klaus for weekend adventures.
#klausvan & @thisisklausvan |
jwallis Samba Member
Posted: Fri Oct 15, 2021 10:03 am Post subject: Re: Rear hatch dome light button |
Timwhy wrote: |
Another of Allister's pics |
Thank you! I was wondering if those 2 holes had anything to do with it!
I'm actually doing this because I want all 4 doors to trigger the door-open alerts on my security system [not so subtle plug for Van Tracker]. When I was in SF, someone tried to force the tailgate lock.
Fortunately it still works, but it looks like exactly what you'd expect if someone cranked a big screwdriver in that lock cylinder. I'm hoping it looking like that will deter future potential thieves from trying it. _________________ TheVanTracker.com - Kill Switch + GPS Tracker + Door-open alerts, made specifically for the Vanagon!
50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Posted: Fri Oct 15, 2021 9:04 am Post subject: Re: Rear hatch dome light button |
Remember each factory dome light can be individually switched, and each has three positions: On—Off—On with open door. In our Carat there are four door “plunger” switches, including the liftgate. Troubleshooting an issue on this circuit can be difficult. In addition, the plastic dome light fixture can be brittle and easily broken upon removal or reinstallation. Fortunately, replacements are readily available. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red
Timwhy Samba Member
Posted: Thu Oct 14, 2021 5:00 pm Post subject: Re: Rear hatch dome light button |
I'm also trying to add a switch in this location. Can someone please take a picture of the bottom of the rear hatch on a van where this switch came standard? I imagine there's a bumper there that presses this switch that my van doesn't have, curious what it looks like. Here's what mine currently look like:
andy52 Samba Member
Joined: December 17, 2019 Posts: 98 Location: Barcelona
Posted: Wed Dec 09, 2020 3:20 am Post subject: Re: Rear hatch dome light button |
Timwhy wrote: |
dougass wrote: |
Check to see if there is a rogue wire in the engine bay behind the license plate. It’s been a while since I fixed mine, but I recall the connector broken and wire tangled up in there somewhere. |
I tried this yesterday. You can not feel or see a wire for the dome thru the license plate.
Today I'll look in the engine bay for routing and get pics if I can.
Years ago I thought that I wanted to add this switch to my Westy and Allister provided great pics of it location.
Its hard to tell which way that wire routes left or right? Here is one of his pics.
its brown? I think I know which one it is hahah
Its the only one I found that was connected no where, without the terminal ... who knows how it ended that way, I'll try connecting it to the switch and crossfingers!
thanks for the pic! |
Timwhy Samba Member
Posted: Wed Dec 09, 2020 3:06 am Post subject: Re: Rear hatch dome light button |
dougass wrote: |
_________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
andy52 Samba Member
Posted: Wed Dec 09, 2020 1:35 am Post subject: Re: Rear hatch dome light button |
jimf909 wrote: |
FWIW, there is not a plunger switch on my 1990 2WD Vanagon Westfalia...
id prefer that situation, having the switch but not finding the wire sucks haha |
andy52 Samba Member
dougass wrote: |
what colour is it?
there are wires there that go to the rear plate ilumination.. nothing else, so strange |
jimf909 Samba Member
Posted: Mon Dec 07, 2020 10:52 am Post subject: Re: Rear hatch dome light button |
_________________ - Jim
Abscate wrote: |
Posted: Mon Dec 07, 2020 7:21 am Post subject: Re: Rear hatch dome light button |
Check to see if there is a rogue wire in the engine bay behind the license plate. It’s been a while since I fixed mine, but I recall the connector broken and wire tangled up in there somewhere. _________________ '91 GL - 2.1 automatic named Klaus for weekend adventures.
