mailman Samba Member
Posted: Fri May 02, 2008 2:48 pm Post subject: How much head is too much? |
Okay, now that I've got your attention....
I've read lots of posts about building HP engines, and I understand the importance of choosing the right heads....but what do the commonly used numbers really mean?
I've seen numbers like 044, 043, 041, etc. I presume these to be casting numbers, but what are the differences between them, and how does one choose wisely? _________________ '64 Bahama Blue Beetle / steel sunroof
'64 Bahama Blue Beetle Sedan (future ragtop) |
sandnut Samba Member
Joined: April 01, 2008 Posts: 85 Location: fresno,ca.
Posted: Fri May 02, 2008 5:12 pm Post subject: |
in my opinion (which is worth about as much as a day old cup of coffee)choose a head that flows just more air than you need to get to your desired power level.i.e if you want to make 100 hp then get a head that will make up to 125 hp.also make sure it moves said amount of air in the lift range your running as well as your desired rpm range.as for differences in casting numbers,i have no idea.i have 044 but a set of properly ported crappy heads could out do them. |
akokarski Samba Member
Posted: Fri May 02, 2008 5:16 pm Post subject: |
http://cbperformance.com/catalog.asp?ProductID=1241
click on "044 Castings" in paragraph:
Quote: |
044 Castings - Check out the difference between normal Cylinder Heads and 044 Cylinder Heads. |
that should show how 044 casting is different from stock.
Anton |
timsvw Samba Member
Posted: Fri May 02, 2008 10:58 pm Post subject: |
akokarski wrote: |
Anton |
A vendor told me that the 044 CB heads are machined Autolinea castings. Does anybody know if this is true? |
Posted: Fri May 02, 2008 11:39 pm Post subject: |
timsvw wrote: |
akokarski wrote: |
Anton |
Yes that is true, it's stamped inside the rocker area.
Anton |
Posted: Sat May 03, 2008 2:26 pm Post subject: |
That's good info on the 044's.
Any info on the other types that are out there? What's the difference between them? _________________ '64 Bahama Blue Beetle / steel sunroof
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Sat May 03, 2008 7:34 pm Post subject: |
Currently all of the stock type of type 1 heads are either OEM or Autolinia castings. Except the MOFOCO. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat May 03, 2008 8:08 pm Post subject: |
any body use the heads that CB's sells listed as "Los Banditos" they seem like a pretty good deal.
Earthquake _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
dog_jr911 Swamp Donkey Assistant
Posted: Sun May 04, 2008 12:12 am Post subject: |
the 19 year old thinks there is no such thing as too much head.
seriously _________________ AKA Chris™
ROCKIN a ESP LTD F2E |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sun May 04, 2008 1:14 am Post subject: |
dog_jr911 wrote: |
How old are you, again? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
EZGZ Samba Member
Joined: October 10, 2005 Posts: 923 Location: Loveland, Colorado
Posted: Sun May 04, 2008 8:15 am Post subject: |
Ah, can we get back to the heads....... I'm also curious about the Los Bandito's. _________________ 64 custom Ghia, 66 Bug, Sandrail, Barrien tub |
Posted: Sun May 04, 2008 8:45 am Post subject: |
X2 on the Los Banditos.
And what about the other numbers? 041, 042, etc. I've seen the numbers used, but don't know what they mean. I'd like to learn enough about it to make an informed decision when shopping for heads. _________________ '64 Bahama Blue Beetle / steel sunroof
Posted: Sun May 04, 2008 10:26 am Post subject: |
miniman82 wrote: |
dog_jr911 wrote: |
How old are you, again? |
seriously... no such thing as too much. just up your displacement and bolt on a big exhaust. _________________ AKA Chris™
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sun May 04, 2008 11:25 am Post subject: |
I've come to the conclusion or understanding that if you stick with stock or mild heads you save a lot of money and will have a reliable engine...but may lack some of the power you desire.
as i see it the bigger the heads or more porting you do then you need to increase the carburation and then you have increase the exhaust system to get that flow through and these changes usually mean youre probably going with higher compressions too and than you have to get involved with additional cooling and ...well these things all get pricey and exponentially increase the cost of the build and / or trade off of reliability and cool running.
although you can get a lot of extra power from head work at a reasonable cost it will be the other engine components to support that power properly that will push your total engine budget a lot higher
i claim no expertise. this is just my observation |
Posted: Sun May 04, 2008 11:26 pm Post subject: |
you dont have to buy it all at once, and i wouldnt reccomend high compression.
get the bigger heads, dont drop more than 400 in them, thats way too much.
a bigger exhaust system is cheap. you dont need a fancy setup
carbs can and will be gotten later.
your going to kick yourself for not getting those heads, you can always clean them up and use them on the next engine. like carbs, and exhaust. take care of them, and they last.
trust me, i let my engine have the ability to add all those "options" when i had the cash. dont limit yourself.....
plus, i beat the sh!t out of a new jetta today.... lol a vette was just following and watchin, laughin his ass off. _________________ AKA Chris™
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Mon May 05, 2008 5:50 am Post subject: |
Call one of the head guys like Steve Tim's or Darren at DRD and tell him your combo, and deck height. They will prescribe the exact head for you.
You heads should be optimized for your combo, not just bolted on. For many combinations this means STOCK heads will do the job just fine. A lot more theory is involved than valve size. PORT VELOCITY will affect performance. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
