vwible Samba Member
Joined: January 02, 2005 Posts: 160 Location: East Windsor, NJ
Posted: Thu May 08, 2008 4:39 am Post subject: Which fuse is on the switched accessory circuit? |
Car is a 1976 standard beetle.
I want to hook up the radio properly to a circuit which is switched on by the ignition switch.
Which fuse should I tap into on the 12-fuse panel under the hood?
I might also use the same circuit to power a relay for a new six-fuse block for other accessories such as a 12V outlet for iPod power, a power amplifier for the stereo, and other electronics.
Thanks _________________ 1970 Tin Top Walk Through Bus |
DeanJ Samba Member
Joined: February 28, 2008 Posts: 49 Location: Rochester, NY
Posted: Thu May 08, 2008 8:45 am Post subject: |
I'd use your volt meter, or a test light. If its off when the ign. is off and on when the 'acc' is on, then its what you want.
You do have a meter or test light when you install electrical equipment, right? |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Thu May 08, 2008 8:50 am Post subject: |
There is no "Acc" circuit on a beetle. As noted above just use a test light and find a fused terminal that is hot with the key on and not when it's off. _________________ Midwest Autosavers, Inc. Woodstock, IL |
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Thu May 08, 2008 9:13 am Post subject: |
It would be the second from the left (looking at the fuse panel from inside the trunk) on the '76, I do believe. |
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Fri May 09, 2008 10:48 pm Post subject: |
It's possible to create an acc position with a small relay and the buzzer wire from the ignition. Accessories stay on till you remove the key.
I hooked my voltmeter up to this as well so I can monitor my battery while listening to the stereo and running the gas heater.
Since I wasn't using the buzzer as a key in warning I moved one wire at the fuse box and now it buzzes when I open the door with the lights on. Saved my battery many times so far.
Jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
